Question about Kodak EasyShare DX4530 Digital Camera
Kodak screen shows error#41
What the heck is error#41
  • 30 Answers
That error means that you have a lens motor error. there is a way to fix it but you need a precession screw driver. Be careful when doing this and only attempt if you are confident you can pull it of. Open up the camera and find the BROWN RIBBON CABLE that runs from the lens to the edge of the camera case. Then you will see a small philips screw that is in the middle of the ribbon cable, remove it. Right under the philips screw under the BROWN RIBBON CABLE you will see a SMALL THIN METAL SLIDE RESISTOR. now move the lens to the OUTERMOST POSITION then attach the slide resistor and the ribbon cable back exactly how there were reassemble the camera and you are good to go.
Posted on Dec 12, 2008
What does code: H4-00 mean
The H4-00 is a low temp error in the fuser. This can normally be reset by doing the following at the machine:
On the button panel hit
pound, star, C, star
then enter 14, hit start, then execute on the screen.
This should clear any one-off errors
www.equipmybiz.com EquipMyBiz
Aug 04, 2014 | Sharp MX-4101N Multifunction Printer Color...
My Kodak EasyShare C813 keeps coming up with Lens Error 115,0,0,351. What does this mean?
Hello Branden, The problem is in the drive assembly. The drive gears strip and the pieces of plastic jam the motor causing the error codes. The camera is toast, Repair will be costly.
Best Regards, Russell
Dec 30, 2012 | Kodak Easyshare C813 Digital Camera
Mon apn affiche error lens 41 lorsque je zoom et apres s'eteint
Problem: dust in the gaps near lens which makes it jammed. Effect: the sceen shows blk color. Solution: just blow over it or vaccum it.
Aug 18, 2010 | Kodak EasyShare C763 Digital Camera
Keeps showing on screen, "camera error # "
If this camera just show blue screen it means that the LCD or he mainboard of the camera is defective., is this error code display also a number., usually it will also display the error code number.
If you have this error code please call tech support toll free 1 800 235 6325 and send the camera for repair
Nov 13, 2009 | Kodak EasyShare P850 Digital Camera
Unplug machine error 41 brother 3100c
Error 41 means the head drive voltage has not been turned from Low to High within the specified time.
It is a major problem for Brother and they are well aware of it.
It boils down to this... It needs a new print head and 4 new cartridges to prime it with. Call Brother and complain like heck! There have a been a huge amount of these head failures! A new head costs around $100.00 but if you call Brother, they will replace it.
Oct 06, 2009 | Office Equipment & Supplies
Lens error: 22
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 12, 2009 | Kodak EasyShare CD33 Digital Camera
Error 41 is showing up on the screen. says to contact brother. It's a intellifax 1820c.
Error 41 means there is a major problem with the printhead, usually
requires a print head replacement. My advice is to take it to a
Brother service centre while it is under warranty. If it's out of
warranty then it is cheaper to purchase a new, non Brother model. If you have been using non-Brother cartridges or refills, they can have too much water in them and it erodes the print head after a while. Usuall y just after warranty has expired!
Apr 21, 2009 | Brother IntelliFAX 1820C Plain Paper...
Error e5 showing
Step 1 : Push Power switch by continue (Tekan Power On/Off)
Step 2 : inserrt plug(Masukan Power, Power Tetap di Tekan)
step 3 : Tekan Tombol Reset 1x, lepaskan Tombol Pwr, Tekan Reset dua kali lagi Sampai Menjadi 0 (tekan tombol tanpa jeda)
Step 4 : Push + display change from 0 to 1 (tekan tombol + untuk merubah 0 ke 1)
Step 5 : Push Power switch again , Printer will be print 1 page(tekan tombol power –> tombol start sampai ngeprint 1 hal.)
step 6 : Open cover (buka tutup printer)
Step 7 : Unplug (cabut kabel power)
Step 8 : Take out ink 40 and 41(lepaskan catridge 40 dan 41)
Step 9 : Insert plug again (pasang kabel power)
Step 10 : Push power switch (tekan tombol power)
Step 11 : Open cover (scan cover) (buka tutup scaner)
Step 12 : Inksert ink 40 , 41 again (masukan catridge 40 dan 41)
Dec 07, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Camera error
what exactly is error #41 on dx4530
Mar 17, 2008 | Kodak EasyShare DX4530 Digital Camera
Kodak EasyShare DX4530 Digital Camera Logo
202 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
