Question about RCA D52W19 52" Rear Projection Television
No Power My TV won't power up. The power light comes on and a noise is made in the back of the unit. Then the light goes off, and nothing. Can you help! Thanks, Larry
  • Lawrence Williams Apr 21, 2007
    Thanks, but I figued it out. It's the flyback Transformer that went bad. Had it replaced along with a few capacitors for about $200.00.
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 5 Answers
Whenever issues like this pop up, the first thing to do is look for ruptured or bulged capacitors. But be very careful not to touch anything unless you know how to discharge the set! Often when capacitors dry out, they don't filter voltage properly, and a ripple detection circuit kicks in shortly after power-on and shuts down the system. Look for a capacitor (they look like litte short batteries) oozing any rust-colored stuff or bulging out the top or bottom (tricky to see, but if the set is discharged a dental mirror helps). Usually the big ones go first. They are cheap to replace, and often fix the problem. If it's more complicated then that, I can't help you
Posted on Apr 21, 2007
SOURCE:
What is wrong with my tv
if there was a storm ,there is every possibility that there was a power surge that has fired parts of the circuit board
I suggest that you have it check at an electronic shop and get quotes for repairs.
Aug 05, 2015 | Panasonic Viera TC-L37X1 37 in. LCD HDTV
Dryer won't start..light clicking noises
There is a switch inside the unit that stops it when the belt breaks or comes loose. Check that.
Mar 15, 2017 | LG Home Applaince LG DLE2101W 7.3 Cu. Ft....
PN50B550T2FXZA won't power up
The continous red light merely means power is getting to your TV. From your description, it is likely the internal power supply has failed
Dec 31, 2012 | Samsung Televison & Video
Will not come on it worked fine earlier.
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
May 17, 2011 | Sanyo DP42849 42 in. HDTV
Panasonic TH50PX85U power shuts off and won't come on.
power board failure, common in this model, replace power pcb then check VS and VA voltage could be X or Y driver causing power pcb to fail.
Aug 09, 2009 | Televison & Video
TV will not Turn On.
same thing,tv won,t come on,unplug the tv, nothing at all,just yesterday my tv was fine, this is the first time this has ever happen
Mar 13, 2009 | Samsung HC-P4363W 43 in. TV/DVD Combo
Toshiba 32A32 won't turn on
just fixed one with that problem it was the vertical output ic Q301
that was shorted. try wicking it out. it is a LA7833S.
Postings say to be sure to use the Toshiba part
Feb 27, 2008 | Toshiba 32A32 32" TV
Philips 42 in. Plasma shut down
did u cheak the input cables does it do it on dvd input as well as others ?
Feb 01, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Yet another hissing/buzzing noise from back of TV
Good day.
Check for the horizontal output transistor, flyback and filter capacitors.
Any of these being shorted can cause the problem.
chris
Jan 20, 2008 | RCA F32TF720 32" TV
RCA D52W19 52" Rear Projection Television Logo
47 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
