Question about Microsoft Xbox 360 Console
XBOX 360 ethernet
My 360 shows cord connected, and says that the system shows connected, but it won't connect. Any ideas?
    Problem Solver:
  • 10 Answers
Do u need a wireless adaptor to set up xbox live??
No, a Xbox 360 Wireless Adapter is not required to access, and set up Xbox Live, but you will need an internet connection. If you are close enough to a modem or router, you can buy an Ethernet cord, and plug it in to both the modem/router, and firmly into your Xbox 360 console. You will either need the Xbox 360 Wireless Adapter, or the Ethernet cord. Ethernet cords are very cheaper, much cheaper than a Wireless Adapter, but the Wireless Adapters are much or easier to reason with. So choose wisely with money.
Jul 06, 2011 | Microsoft Xbox 360 Console
I dont know how to set up my xbox live with an eathernet cable can you help?
Hi there
Turn off the Xbox 360 by pressing the power button on the front of the console. Afterward, shut off your modem by unplugging its power cord.
  • 2 Insert one end of the Ethernet cable into the Ethernet port located at the back of your Xbox 360 console. After that, insert the other end of the cable into your modem.
  • 3 Replug the power cord into your modem to turn it back on. Once it is active, press the power button on your Xbox 360 to turn it on.
  • 4 Navigate to "My Xbox" then "System Settings." Afterwards, select "Network Settings" then "Test Xbox LIVE Connection." You will be notified on-screen if the connection is successful.
  • Read more: How to Set Up Xbox LIVE with an Ethernet Cable | eHow.com http://www.ehow.com/how_6714462_set-xbox-live-ethernet-cable.html#ixzz0xBK8Zctz
    GOODLUCK!!
    Aug 20, 2010 | Microsoft Xbox 360 Console
    How to connect xbox 360 to the internet with laptop
    I'm not sure if you can connect an Xbox 360 to the internet with a lap top. What I would do, is get a router (guessing that you already have one). But if you don't, it's basically a splitter for Ethernet cords. You plug the router into the Modem (the box that makes the internet), buy an Ethernet cord, plug it from the router to your Xbox and you should have internet. Or, you can get a wireless router, and get a network adapter for your Xbox to get internet wireless. But I don't think you can just get internet from your laptop.
    Jul 10, 2010 | Microsoft Xbox 360 Console
    I have a Cayman 3347w wireless router and I am trying to use one of the wired slots to connect my xbox 360 to the internet. the xbox will not connect. is this router xbox compatable?
    Please try the following steps below;
    To make a router connection to Xbox LIVE:
    1. Before you connect any cables, turn off your router, modem, PC, and Xbox 360 console. (Unplug your modem from its power source to turn it off.)
    2. Connect one end of an Ethernet cable to the Ethernet port on your modem and the other end to the Ethernet input port on the back of your router.
    3. With another Ethernet cable, connect one end to one of the router's Ethernet output ports. Connect the other end to your PC's Ethernet port.
    4. With the third Ethernet cable, connect one end to another of the router's Ethernet output ports. Connect the other end to the Ethernet port on the back of the Xbox 360 console.
    5. Turn on your modem, then your router, then your PC.
    6. Make sure your PC can access the Internet. If not, you may need to configure the router for Internet access. For help configuring the router using your PC, check the instructions that came with the router.
    7. Turn on your Xbox 360 console and sign in with your profile.
    8. If this is the first time you've turned on your Xbox 360 console, see Create Your Gamer Profile to get started with both the Xbox 360 system and Xbox LIVE play.
    If you're unable to connect to Xbox LIVE, you can try to diagnose the problem right on your console. Go to My Xbox and open System Settings, then select Network Settings (setup XBOX using Automatic Configuration DHCP), Test Xbox LIVE Connection.
    Hope this helps!
    Mar 28, 2010 | Netopia Cayman 3347W-Ent Wireless Router
    Xbox 360 wireless ownt work
    xbox 360 wireless adapters are usally the worst to get.
    i suggest buying a long enough ethernet cord and using that, a 50m ethernet cord is around about $25. so pretty cheap.
    Sep 25, 2009 | Microsoft Xbox 360 Console
    How To: USB hookup for computer while having ethernet hookup to Xbox 360.
    USB to PC is fine, make sure you have the original installation disk for it. Then you can connect the Xbox via network cable. There shouldn't be any problem as your modem can take 2 connections by the sound of it.
    May 21, 2009 | Westell Wirespeed LiteLine 6100...
    Can't connect with network
    if u dont hav e a router that is ur problem. to get ur xbox 360 to connect to vista media center you cannot connect an ethernet cord directly to ur 360, u must have ur computer hooked to a router with one ethernet cord and a whole different ethernet cord connecting to the same router the computers hooked up to. after you do that go to ur vista media center, turn active sharing on, make sure your router is connected to the internet. then go to ur xbox 360 and follow the on screen instruction from the the connect to media center screen.
    if your wanting to connect to xbox live and stuff like that, and u enter ur ip address and security information and it tells u that the ip adress u entered is already in use by another device, and that ur xbox 360 needs to be assigned one, do this: simply go to were u put in ur ip address and set it to get the address automaticly (or in other words choose automatic). then go to test connection (ur router should automaticly assign ur xbox 360 an ip address) and ur router should connect to the internet. if it connects to the internet but not xbox live then u have not yet sign up for an xbox live account.
    by the way when u make an xbox live account please send me a friend request. my xboxc live account name is: ghdude22
    glad i could help!!! :3
    Feb 06, 2009 | Microsoft Xbox 360 Controller
    Trying to get xbox live
    You have to purchase an xbox live membership, and then you can connect with an ethernet cord right to the consel from your modem, or purchase the wireless adapter for it.
    Jan 27, 2009 | Microsoft Xbox 360 Console
    Ethernet connection stopped working
    Mine has quit working to and xbox says I need to send it to them
    Apr 12, 2007 | Microsoft Xbox 360 Console
    Link Your Console to Another Console
    Console-to-Console Connection: Wireless Some Xbox games offer console-to-console, or system-link, play, in which two or more players (depending on the game) can wirelessly network their consoles for multiplayer use. Console-to-console wireless networks are also known as ad-hoc networks. In ad-hoc networks, a wireless adapter on one device connects directly to a wireless adapter on another device. An Internet connection isn't shared with this type of network, and the console-to-console connection is typically temporary. For console-to-console play, you need: Two Xbox 360 consoles. Two Xbox 360 Wireless Networking Adapters. An Xbox 360 game that supports system link play. To wirelessly connect your console to another console: Attach an Xbox 360 Wireless Networking Adapter to the back of each console as described in Use Your Xbox 360 Wireless Networking Adapter. On each console, go to the System area to enter your network settings. (They will be the same for each console.) If all settings are correct, exit the System area. The consoles should now be wirelessly connected to each other.
    Nov 20, 2005 | Microsoft Xbox Console
    Microsoft Xbox 360 Console Logo
    16 people viewed this question
    Top Microsoft Video Game Consoles & Games Experts
    Tre Elkins
    Martin Murray
    Stu Morris K
    Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
