Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Replace the cp150 cap.
Im trying to replace the cp150 capactor. i have found it on the top of the board but i cant find it on the bottom of the board
  • RCA Master
  • 5,138 Answers
It has to leggs Neg and pos side unsolder and install new one neg- on one side positve on other do not put in wrong way. you also need to replace cp114 cp120 220uf 35v
Posted on Dec 25, 2008
My tv turns on for a few seconds then shuts off and then turns on and then shuts off and stays off....what is the problem and how do i fix it
Look for Bad Capacitors on the Deflection Board,Bad caps will be vented,swollen or puffed up on Top. CP150 2200uf 16v use 25v
CP114 CP120 are 220uf 35v replace all 3 if CP150 is Bad.
Deflection Board is the bottom board on Left hand side,will have FBT flyback Transfomer on it.
Oct 07, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV WON'T STAY ON AFTER TURNING ON. IT'LL COME ON AND GO OFF 3 TIMES. I WAIT AWHILE AND TRY AGAIN AND THE SAME THING HAPPENS. WHAT COULD BE THE PROBLEM. IT'S BEEN A WEEK SINCE I'VE NOT BEEN ABLE TO TURN...
Bad Capacitors on the Deflection Board CP150 2200uf 16v use 25v
Cp114 CP120 220uf 35v If CP150 is Vented ,swollen,or Puffed up on top then replace all 3 caps.
Deflection Board is Bottom Board on left hand side Has FBT flyback transfomer.
Oct 04, 2010 | GE D52GW12 52" Rear Projection HDTV-Ready...
Tv wont turn on most of the time it will try three times then you have to wait a minute to try again
On yor Deflection board CK capacitors cp114 cp120 220uf 35v and cp150 1000uf 16v if cp 150 is swollen or puffed up on top replace all 3 caps Deflection board is the bottom board on left hand side with FBT flyback transfomer
Aug 12, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv won.t turn on on switch turns on makes noise then turns off
Look for Bad capacitors on your Deflection Board. it will be the bottom left hand Board that has FBT flyback Transfomer CP150 2200uf 16v use 25v
CP114,120 220uf 35v If they are Puffed up on Top Replace all 3 caps.
Mar 24, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Our hdtv 52 in rca won't turn on, Our tv was working great this morning but tonight it won't turn on we checked power outlets and changed battries in remote and manuelly tryed to turn it on it like no...
Deflection Board. Call UED for replacement Board 1-800-648-6657 or CK 3 capacitors on that board cp150 2200uf 16v 114,129 220uf 35v If cp150 is puffed up on top it is Bad so replace all 3 caps. Call Mats for them 1-800-628-1118
Dec 03, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 50 floor model....goes off after about 10
Your TV is Projection if it is a 52W19 Not LCD,# capacitors on deflection Board 3 of them cp150 114,120
cp150 2200uf 16v 220uf 35v if cp150 is puffed up on top it is Bad Mats Parts 1-800-628-1118 for caps , UED 1-800-648-6657 to replace whole board.
Dec 03, 2009 | RCA D52W19 52" Rear Projection Television
37mf23id magnavox takes 15 min to come on . its a magnavox which is made by philips
You need to replace the power board,Or replace the capactors on it.
Replacing the capactors is the best idea.They are under rated at 10volt insted of 16volt or higher. They cost less too. If you replace the board,you will still have the same problem again later. They are usualy 680uf 10v,1000uf 10v,2200uf 10v,and 3300uf 10v. Replace them with the same uf but 16v or 25v EXPANPLE use... 1000uf 16v or 1000uf 25v
They are polorised Blak spot on board is the - side of cap. Stripe on cap is -. The caps. swell if they are bad. The tops round out,or the X on top breaks anfand black or brown goo comes out. Top should be flat. It I can assist you further please feel free to ask. toddthetvmd@yahoo.com
Oct 27, 2009 | Philips Televison & Video
D52W20 52 in. won't come on. Green light only blicks but no TV. Something broke inside I suspect. Fuse is good.
Ck capacitors cp150 2200uf 14v if it is swollen or puffed up on top it is Bad replace cp114,cp120 as well 220uf 35v. resolder all pinns on FBT flyback transfomer this caps are on the deflection board First bottom board to the left.
Sep 22, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca d52w20v 52 in proj tv
The capacitor you are looking for is on the Deflection Board on bottom is 2 boards on left is Deflection board on right side is SSB board it has the turners on it.cp150,cp114,cp120 these are the 3 capacitors to replace if cp150 is puffed up on top.
Jan 04, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
My 52" RCA rear projection TV will not turn on. Why?
Check cp150 on the Deflection board its the first board to left on bottom. If cp150 is puffed up on top then it is bad so repalce cp114 and cp120 also cp150 2200uf 16v other 2 caps 220uf 35v.
Dec 30, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
