Question about Dryers
Whirlpool electric dryer will not start.
Turned dryer on ran for 30 seconds then it shut off. Did this for 2 days now it will not start at all.
  • 145 Answers
If you can hear a HUM sound when you press the start button, your motor is probably bad and needs to be replaced.
Posted on Dec 12, 2008
I have had battery and alternator checked, both are good. Battery was dead, jumped car, started and ran fine. Drove 30 minutes, shut off and sat for 2 hours. Started fine again, just went to gas station...
Most likely you have a bad battery. The second option is that you have a faulty wiring and there is a constant load that takes a lot of power, but it does not make a short circuit. Check the electrical relays, maybe it's in them.
Sep 06, 2017 | Cars & Trucks
Dryer is a week old. ran a cycle and dryer turned off. didn't trip breaker. wouldnt turn back on. so turned breaker off for a while then turned it back on. now dryer powers on but for only like 10 seconds...
A week old dryer should have, in its warranty, a condition that you can get them to exchange this for an identical (hopefully working) model free. Do it now, that is a short time window. It's usually one month.
Nov 16, 2013 | Samsung DV50F9A8EVP 27" Electric Dryer...
My dryer is a whirlpool electric dryer that was brand new in 1998. The dryer was on, working fine...suddenly it just stopped. It was making a clicking noise. It refused to cut back on when I pushed the...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 27, 2011 | Whirlpool GEW9250 Electric Dryer
Just purchased a used Whirlpool Duet dryer(2 to 3 yrs. old). I hooked it up and placed it on a normal automatic cycle. The unit started up a little noisey but quitened down in approx. one min. Shortly...
try replacing the power cord, and make sure that you have a "dedicated" power sorce for the plug. The system board will shut the dryer down if a power supply issue is detected. This feature is to prevent fire hazards. Make sure your electric box is grounded and up to code.
Jun 26, 2009 | Whirlpool GEW9250 Electric Dryer
I have a whirlpool duet gas dryer that will not turn on. When I press the start button it makes a beep three times then the lights go off.
I had the same problem with mine. As it turned out the dryer door wasn't completely shut. You really have to push them hard when they are brand new and you should feel a second "click" when it pops in all the way.
Jun 12, 2009 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Knemore 80 series dryer won't start every time
Go to www.repairclinic.com and enter your model number and it will show you all your parts, but I suggest you change your thermostats and basically have the dryer cleaned out of possible lint build up on the interior
Mar 20, 2009 | Kenmore Dryers
Whirlpool over the Stove Microwave
This sounds like the unit is defective and if I were you I would return for replacment!
Dec 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool electric dryer runs only when holding start switch
if you've replaced the board replace the relay to right of bd the one with 2 blue wires to ck before replacing just switch relays the other one with red wires controls the heat
Oct 25, 2008 | Whirlpool LER4634J Electric Dryer
Dryers Logo
Top Dryers Experts
