SOURCE: Dead battery or starter?
Take the battery out and have it charged up. reinstall it and you should be allright. Your car has discharged it completely, and it will need a recharge to start. The gauge is only measuring voltage, and not the status of charge.
SOURCE: How do you check if altenator is charging battery,
Most vehicles if you get the car running and unhook the positive battery cable it will stay running that is because it is running off the alternator. if it dies like your talking about I would most definitely say your alternator needs to be replaced. Most likely when you jumped your father in laws pick up there was a bad ground somewhere and your alternator got a surge of electricity and it fried it. Hope this helps.
SOURCE: 2000 ford f250 w/ triton v-10
check glove box light if equiped, interior lights that no off when you close the doors, also some radio, cb, dvd, etc. if all good check alternator for possible drain
SOURCE: 2001 Jimmy - No power & can't remove the key from ignition
the key cyliner lock out will not function w/o power
put battery charger or cables on it and key should come out
SOURCE: 1962 CHEVROLET TRUCK with points
If/How long will it crank over before it stops? Are you saying it will crank over, but very slow? Has it been sitting quite a while. Got good spark, and fuel?
