Question about Hampton Bay 52 In. White Redington III¿ Ceiling Fan w/ Remote Control & Light Kit
Wall switches do not control fan
I have 3 Hampton Bay remote ceiling fans UC703T. The remotes work, but not the wall switches. How do i get the fans to work from the wall switches. I'm tired of looking for the remotes.
  • Dan Todd May 11, 2010
    Are the wall switches remote? Or do they simply turn them off and on?
Some fans will not operate without the remote, however, I'm not sure if the Hampton Bay brand is one of these or not. Below is how you will bypass the remote if the fan will operate without the remote.
You can try disconnecting the receiver in the canopy of the van (the cover that fits snug to the ceiling) once you have shut off the power source remove the canopy and find the remote receiver.
Most likely it will be a rectangular box with white, black, and blue or red wires attached. Disconnect all wires from the receiver and lay it to the side.
Now reconnect the wires directly to the fan, white to white, black to black, if you have a red wire (or a second black wire) in the ceiling box connect it to the blue wire from the fan.
If you do not have a red wire (or second black wire) in the ceiling box, connect the black and blue wire from the fan to the single black wire in the ceiling box. This method will require you to pull the chain to operate the fan separately.
Posted on Jun 07, 2009
Need to program Hampton Bay Ceiling fan remote control CHO88T7030T, HELP!
Change the battery. This is the first step when troubleshooting a ceiling fan remote. The easiest fix to any remote control problem begins with battery replacement. A 9-volt battery is needed to operate all Hampton Bay ceiling fan remotes.
Check the light switch used for the ceiling fan. The light switch found on the wall must be in the "on" position. This allows the ceiling fan to be operated by remote control
Re-program your remote. If battery replacement fails to get your remote working again, try to reprogram the remote. Open the battery cover you will see 4 dip switches. These switches must be set to the same position as the receiver on the fan. Use the screw driver to move the dip switches either up or down.
Follow the previous step to change the frequency if the ceiling fan is randomly turning on or off. Other electronic devices such as garage door openers can interfere with the ceiling fans receiver, causing it to randomly turn on or off.
Sep 10, 2011 | Televison & Video
Fan remotes
mcdevito75 here, If the thermostatic switch was controlling another ceiling fan then yes it should work, it"ll have to hook up to the wall switch. I'd double check with a hardware store in the area for more advise.
Jul 19, 2010 | Hampton Bay 24002 Ceiling Fan
Missing remotes for hampton bay ceiling fans
https://www.google.com/search?q=remotes+for+hampton+bay+ceiling+fans&rlz=1C1PQHB_enUS689US689&espv=2&biw=1536&bih=748&source=univ&tbm=shop&tbo=u&sa=X&ved=0ahUKEwik3qiMx4bTAhXh5oMKHV3vDJ4QsxgIGg
Apr 02, 2017 | Hampton Bay 52 In. White Redington...
Hampton Bay Redington IV ceiling fan remote won't work
the reciever is under the cover for your fan to the ceiling. Try pulling the switches on you fan then using the remote after each try. then check your wall switches,,, it could be wired to one.
Aug 16, 2009 | Hunter 28156 Cote 54' d'AzurĀ® Ceiling Fan
Unable to get fan to respond to remote Hampton Bay 54
these fans must be reset as follows remove the battery from the remote manually turn off the wall power switch put the batteries back in the remote turn on the wall power switch press the remote buttons...if this doesn't work let me know
Jun 01, 2009 | Universal Remote Control Hampton Bay...
Unable to get fan to respond to remote Hampton Bay 54".
There is most likely a wall switch which you will need to ppush to the on position to send power to the fan, then the remote will do as it is supposed to do. If you find that it is not the wall switch, then I would check the electrical panel for a circuit breaker that has kicked partway off or blown fuse.
Apr 26, 2009 | Universal Remote Control Hampton Bay...
Hampton Bay Classic Collection 52" remote ceiling light/fan
rechecked wiring, but blue with blue, white with white, etc., now lights work with remote,but fan only works with wall switch - so why doesn't fan work with remote,if lights work the remote & receiver must be ok?
May 30, 2008 | Hampton Bay 52 In. White Redington...
Hampton bay Mod. # 587-186
The dip switch is on the receiver box which is located inside the housing on the ceiling, inside the remote control, and inside the wall switch if you have a wall switch made to control the fan.  All must have the same dip switch settings.
Dec 23, 2007 | Hampton Bay 24750 Huntington III Ceiling...
Hampton Bay Ceiling Fan At Slow Speed
I recently replaced my hampton bay fan for the same reason (slow at all speeds) and discovered scorched and melted capacitors and wiring inside the fan. My suggestion is to stop using fan and replace immediately.
Aug 10, 2007 | Hampton Bay 52 In. White Redington...
Hampton Bay 52 In. White Redington III¿ Ceiling Fan w/ Remote Control & Light Kit Logo
360 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
