Question about Zanussi FS1255S Front Load Washer
  • 2 more comments
  • mark_bubbles Dec 12, 2008
    it is a zanussi electrolux essential 1200 6kg
  • mark_bubbles Dec 13, 2008
    my uncle stripped in down but he couldnt find away of getting the outer casing around the drum as there is not any screws to get it of n he too all of the rubber of around the door to c if there was any way through that way but there isnt tried the sump hose but couldnt feel it through there either and it is rubbing on the drum wen it is goin around
  • Barry Coates
    Barry Coates May 11, 2010
    You won't get it out that way.
    To give you more info I need to know the model number of washer plz.
  • Zanussi Master
  • 3,463 Answers
Unless you can hear it catching as the drum is going round I would leave well alone, it will probably just get lodged near the heater and not cause any problem.
If the m/c has a removable rear panel then you can get access into the drum by removing the sump hose fastened onto the bottom of the drum. you might find it stuck there.
If no removable panel, then it is a strip down job, Not recommended, unless you know what you are doing.
Posted on Dec 13, 2008
I have a bra wire stuck in my machine, i cant feel it through the holes, but can hear it scraping on the drum. How do i remove it, i have a zanussi lindo 300
Remove the complete agitator. Unscrew the top of the agitator and you will get to the screw that holds the entire module. You will need an extension bar to get to the screw with a ratchet set. The head should be 5/16" and then you can get to the item.
Dec 21, 2017 | Zanussi Washing Machines
MY zanussi, ZWI1125, FRONT LOADER, now makes such a noice on washing and spinning. the plumber has relevelled it but it still makes a noice esp on spinning. Why?
This could be something stuck in the drum ie ,A bra wire or could be bearing trouble an engineer could tell you within seconds.
Oct 30, 2013 | Zanussi Washing Machines
Hi We have a zanussi washing machine and a bra
This is very good polish washing machine
A quick solution is to bend a piece of wire (2 pcs), preferably a rigid hanger for example,) if they can fold back the flap gum can try to pull up underwire
Probably the rear cover is removed, remove the drum, and also use a piece of wire or other tool ... This is a typical problem for women;) can be found a few minor by the way;)
May 05, 2011 | Zanussi ZWF1430W Front Load Washer
We have a Zanussi model ZWF1621W washing machine and a piece of bra bone(wire) has gone through the holes in the drum and is stuck and rotating with the drum against the drum outer body how do we get it...
DONT RELEASE SEAL. Tilt machine and remove sump hose get someone to rotate drum in hope you can catch hold of wire. be careful of fingers on drum as they are like cheese grater. good luck this is best way and a little patience will do the job
Feb 12, 2010 | Zanussi ZWF1630 Front Load Washer
Bra wire stuck between inner and outer drum how to remove Hotpoint WMF760
Depends where it is stuck. If near the very front you can sometimes get them by removing the door seal to gain a small access between drums. Other ways is remove the outlet pipe from the bottom of the drum or easiest and most probable area where it stuck is remove heating element. Provides a better view and bra wires normally get stuck on them.
Jan 24, 2010 | Washing Machines
Wire from bra stuck in drum
no. this type of machine has to stripped down.
May 12, 2009 | Zanussi ZJD1219 Front Load Washer / Dryer
Rattle on fast spin
Hi mate the rattle could be caused by a coin are a bra wire regards a coin you would have to take off the main pump hose connected to the drum our else take the heater element out and see if you can find it if it is a bra wire just rotate the drum until you see it and pull it out
Jul 25, 2008 | Hotpoint Aquarius WD63 Front Load...
Bra underwire stuck
Switch off machine and unplug it from the wall socket. Remove back plate and identify the heating element. It should be located at the bottom of the outer drum. Remove element and you will have limited access to the space between the drums. Rotate the drum slowly by hand untill the bra wire gets to the bottom of the drum. Remove obstruction with hook or long tweeser.
Oct 31, 2007 | Bosch WFMC6401UC
Bra wire has between drums
you will need to call in an on site tech.but from my exp.the tub assembly would need to be replaced if you want to solve this problem.
Jun 23, 2007 | Hotpoint WMA54 Front Load Washer
Obstacle wire stuck in drum (model FLS1183W)
you will have to split the case u will find 6 8mm bolt under the lid remove the 2 rear looking from the front then down the sides u will see 2 round plastic covers remove them by putting a small screw driver in the centre of the lug there r another 8mm bolt in each side use a small screw driver to remove the mains and valve block now the cabinet will split u will need a 10mm socket to remove the heater and a claw hammer to get the heater out of its housing use the claw by caerfully placeing it under the terminal 1side @ a time and the heater will come out u will be able to get the bra wire out from there u may need a set of long nose plyers good luck and make sure u have unplugged the machine b4 u start any dissmanteling
Nov 28, 2006 | Zanussi FS1155W Front Load Washer
Zanussi FS1255S Front Load Washer Logo
262 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
