While restoring file computer was shut down before finished. when turn on it show boot up screen but will not boot complete.
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue
then select restart if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode
click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell
you what has occurred and the time it occurred
you might use the system restore to restore your system to an earlier time click start all programs
accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work
if the system restore fails
test all power and data leads that attach to your hard drive IDE,SATA
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty
computers need data and power to travel through every working device and to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty power connection or faulty fan lead can cause you problems
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer ram modules make sure they are securely seated
on some motherboards cmos batteries are soldered in
hope this helps
SOURCE: cisnet contact
Looks like you are running Microsoft XP Home SP2.
If you recently bought the computer (just over 30 days ago) you might be getting this message because you need to activate windows.
Look on your start menu under system tools for an "activate windows" icon and follow the prompts.
Another Guru on this site recommended this link:
http://www.ztsystems.com/Default.aspx?tabid=750
For Manufacturer contact information.
Remember, your computer is under a 1 year warranty.
SOURCE: turn on computer; health screen appears, says boot from disc, stp
I know the didn't include the XP cd with the computer, but they should have provided a system restore disk for you. That is the CD you need to boot and restore your system with. With no restore disk you will need obtain a new copy of XP, and use that to boot from and install a new copy. If you decide that's what you need to do, you should delete all partitions on the hard drive and then format it all as one partition. That way you will have more space on your hard drive.
Thanks for using FixYa,
I hopes this helps,
Eric
SOURCE: My CISNET Computer shows errors and then shuts down
can you tell us more about your problems? we cannot really help a lot unless you provide more details about you problem.
SOURCE: computer would not boot up, only showed red light
I'd say power supply first.
If you have an expansion slot filled with a video card, remove the video card (provided you have onboard video connector as well) then try to reboot. I just went through similar issues with an GForce video card, it went bad, but the machine appeared to boot althugh I couldn't see the screen. Removed the card & it came up using minimal VGA drivers provide with WinXP.
Obviously you cannot check the video driver if you're not booting up...and seeing the screen.
Find a buddy with a regular monitor and hook it up and try to boot. Dell monitors sometimes require their propietary drivers, so write down the model when you take your pc to a friend's place, and DL the driver and install it (provided you got it to boot up)
Brad
Welcome to FixYa!
Using Dell PC Restore by Symantec
Use Dell PC Restore by Symantec only as the last method to restore your operating system. PC
Restore restores your hard drive to the operating state it was in when you purchased the computer.
Any programs or files added since you received your computer-including data files-are
permanently deleted from the hard drive. Data files include documents, spreadsheets, e-mail
messages, digital photos, music files, and so on. If possible, back up all data before using PC
Restore.
NOTICE: Using PC Restore permanently deletes all data on the hard drive and removes any applications
or drivers installed after you received your computer. If possible, back up the data before using PC
Restore.
To use PC Restore:
1 Turn on the computer.
During the boot process, a blue bar with www.dell.com appears at the top of the screen.
2 Immediately upon seeing the blue bar, press .
If you do not press in time, let the computer finish restarting, and then
restart the computer again.
NOTICE: If you do not want to proceed with PC Restore, click Reboot in the following step.
3 On the next screen that appears, click Restore.
4 On the next screen, click Confirm.
The restore process takes approximately 6-10 minutes to complete.
5 When prompted, click Finish to reboot the computer.
NOTE: Do not manually shut down the computer. Click Finish and let the computer completely reboot.
6 When prompted, click Yes.
The computer restarts. Because the computer is restored to its original operating state, the
screens that appear, such as the End User License Agreement, are the same ones that
appeared the first time the computer was turned on.
7 Click Next.
The System Restore screen appears and the computer restarts.
8 After the computer restarts, click OK.
Good Luck
