Question about Canon imageRUNNER 2200
Can not scan documents using Canon Image Runner 2200
I don't know how to set the copier to scan. The copier is networked.
  • 168 Answers
You need to down load the network scan gear tool www.imagerunner.com support downloads office /production then look for canon network utilities... down load scan gear tool [ not color}this file will have to be unzipped then run it... this will set a program in your program files open the one that says scan gear tool when opens either type in the device ip adress or you can select discover. once you do this you select it as the scanner in your scanning software Adobe Pro etc. you also must select scan on the copier then online before scan will happen
Posted on Dec 17, 2008
Can I use IP scanner for scanning to network folder
Yes. Ten years ago K/M business printers were capable of scanning to FTP server, Windows share or email, without any utility software. I'm sure such capabilities have only been expanded.
Feb 19, 2015 | Konica Minolta bizhub Office Equipment &...
Tip
How To Enable SMTP SSL Port on Sharp Network Scanner
From time to time I will get an odd error when setting up scanning to email on a Sharp copier that says:
(SMTP-SSL) Port is disabled. Consult your system admin.
http://i.fixya.net25408640-smf2r4tpyjjq4h3ju4xuhwdx-5-0_0.png
I'll admit, this error had me puzzled the first few times I saw it, and I thought the problem was within the router, not in the Sharp printer. The first time I saw the error I worked around it and used an SMTP server that didn't require SSL. Since those servers are becoming more and more difficult to find lately, I decided to figure out why this error was being generated by my copiers. The solution was simpler that I originally thought it would be. It was in an area of the web interface that we technicians don't normally fumble around in, the security settings.
The Solution
If you're getting the "(SMTP-SSL)Port is disabled. Consult your system admin." error, here is the quick fix. Before we get started you'll need to know the Sharp copier's IP address. I'll assume you already know how to get into the web GUI if you're setting up scan to email, but if you don't know the IP address of the copier you can print a NIC page with this information on it.
Here is a YouTube video(with my monotone voice-over) on how to run through the procedure described below:
1. From the Sharp's IP accessed web interface first login as an administrator by clicking Login at the top right corner. The default administrator password is "admin" by default.
http://i.fixya.net25408640-smf2r4tpyjjq4h3ju4xuhwdx-5-2_0.png
2. Next, click Security Settings at the bottom of the left menu, then click Port Control underneath Security Settings.
http://i.fixya.net25408640-smf2r4tpyjjq4h3ju4xuhwdx-5-5.png
3. Scroll down on the Port Control page to find the Client Port area, then look for the SMTP-SSL option, enable it, then click submit at the bottom of the page.
http://i.fixya.net25408640-smf2r4tpyjjq4h3ju4xuhwdx-5-9.png
At this point you should be able to scan to email with an SMTP server that requires SSL. I'm not sure why this port setting is disabled from time to time, but at least it's a quick fix.
To verify your connection to the SMTP server click Network Settings on the left menu.
Scroll down to the SMTP section, and click Execute on the connection test. A popup will ask if you want to run the test with the displayed DNS servers, say OK, then you should have your successful reply.
In conclusion, this is a rare issue, but has a simple solution. If you'd like to lease a copier in Houston just request a quote or contact me. I'll get you fixed up quickly and I'll match or beat any price you've been given on a Sharp copier.
on Feb 09, 2015 | Sharp Office Equipment & Supplies
I want to know how to connect my ssid pasphrase located on the back of my router and when i tried to conect it to my ps3 conole it said it was weak and it couldnt find the acess point or something so can...
i'm going to assume that you are asking "how to connect your ps3 to your home network?"
if your home is set up with wireless modem or router and your computers are connected wirelessly its pretty simple to set up. more likely you or someone who set it up probably set it up securely meaning with security key and password. So you do have to know few things about your home network. like what is the name of your home network (SSID). the security setting of your home network. and finally the password of your network. if you don't know these things about your home network you will not be able to get connected wirelessly. but if you do have these info on hand read along....
JUST MAKE SURE YOU DO HAVE A WIRELESS HOME NETWORK... it definitely wont work if you don't have a wireless setup and u are trying to connect wirelessly. people overlook this no brainer.
Turn on your ps3 and from the XMB...
1) go to Settings
2) Scroll down to Network Settings and press X
3) Scroll down to Internet Connection Setting and press X. confirm on "O.K."
4) easy *it may or may not give you a message reading "checking network configuration"
5) wireless
from this point on you need to know few things about your network.....
6) scan -- once scanned it'll give you wirelss access point for you home network and some other near your home along with few information such as....
...SSID (which is what you set your network to be -- i.e. "the jones" or "linksys" or "summer home" or "my connection" etc etc) ...SECURITY (this is the password you set up your network with) ...SIGNAL STRENGHT (usually your network will be the strongest among your neighbors since you are closer to your router)
7) highlight your network and press x . (you should know what it is) selecting on the other network probably wont do you any good since it'll probably be all locked with password and such. yours should also be locked and have password on it too.
8) SSID which means service set identifier basically mean the name of your network. if your home network is set up with security and password your home network will not show up under SSID (this is one of the things you need to know about your home network. if you don't know ask the person who set up your home network)
9) on WLAN SECURITY SETTING page (this is another thing you should know about your home network or ask the person who set it up) -- most people i deal with have a WPA-PSK / WPA2-PSK security password. Yours may be different so choose the one that you used.
10) WPA KEY - which basically means password. input the password you used to set up your home network (this is another thing you should know about your home network or ask the person who set it up)
**it'll give you "checking network configuration"
11) if you input all the correct info you should get the "setting list" screen
12) press "X" to save the setting
13) do the connection test and if all things were entered correctly you should have success.
all this seems complicated just reading but if you follow it step by step its easy. you just need to know the name of your home network, the home network setting, and the password of your home network.
on the other hand if you are setting up a wired connection it makes it a whole lot simpler. you don't need to know your network name, security key, and password.
make sure you have the ethernet cable plugged in to your ps3 and to your modem or router
1) go to Settings
2) Network Settings
3) Internet Connection Setting. confirm on "O.K."
5) wired
6) auto-detect
7) automatic -- for the IP address setting
8) do not set
8) automatic -- DNS setting
9) automatic -- MTU
10) do not set -- PROXY SERVER
11) ENABLE -- UPNP
save connection setting
test connection
if your home network is set up and u got the ps3 connected it should work
Sep 01, 2011 | Sony Playstation 3 (PS3) Console
I have a Arris TM722 modem and I need to know my SSID number and password? please help me!
An SSID is the name of your wireless network connection and doesn't have to be a number. As I don't believe that this modem supports wireless connectivity, it should not prompt you for an SSID or a password. If the modem is plugged into a wireless router however, and a wireless network has been set up, the SSID will be related to the wireless router.
Generally most devices can scan for the SSID when attempting to connect to a wireless connection. If there is an "automatic" setting or a "find networks" button, you can try that and choose your wireless connection from the list provided. For a password, you may need to ask whomever helped set up your wireless network.
Jun 01, 2011 | Office Equipment & Supplies
How to set ip address in canon ir 2830 i want network scan in this machine and send me complete information about net work scan
I need fax facility of my canon ir2830 network machine. pl let me know how to setup for fax in my canon ir2830
Dec 31, 2010 | Canon imageRUNNER 400S Copier
Cannot scan items to an ipaddress
There could be a number of things causing this, including port blocking at your server level - check with your IT professional.
It would help to know how you're trying to scan (i.e. scan to e-mail, scan to FTP, scan to desktop), if the C351 has an EFI (Fiery) print server incorporated and how it's set up for scan interfacing with the copier. There's so many variables, it would be very difficult to pinpoint any one solution without knowing just how the copier and your network are set up.
Aug 07, 2009 | Konica Minolta bizhub C351 All-In-One...
Can not make bizhub c252 scanning trough e-mail feature
Can you print to your PC? if yes you know how to assign ip address to the copier. I suggest is to go web browser and type the ip adress of the copier. log in to adminstrator the password 12345678 click network scan you have choices which scanning you want. SMB, ftp scan to email. If choose SMB first you have create Folder to your desktop and name it SMB all upper case and right click sharing and permit everyone . Then back to copier web browser click tab scan and type all the names you want. Scan to e-mail you have to click network and enable the scan to email enter the SMTP leave the port 25 do not change assign a valid email address to copier and enter email address of the administrator user id and the last is the pasword. Note: everytime you visit this page you should enter the password. then click the scn tab and enter all your email address. enjoyprograming!!!
Jun 01, 2009 | Konica Minolta bizhub C250 All-In-One...
BizHub won't send scans to Macs
first, int the mac must have the "share for windows" checked, in the network settings.
second, you'll have to create a folder name SCAN into the 'home' folder onto your mac. then , you ll have to have your user and password of your mac.
then, you ll have to enter in the bizhub:
- Ip of your mac
- gateway of your mac
- mask of your network
on the copier
- in the utiliy/counter // register 1 touch, book adress, SMB (don t remeber exactly the path .. but just not so far of these paths), :
IP server: Ip mac
path : SCAN
user: user'sMAC
password: password of the user's mac (CAN NOT BE EMPTY)
and ormally, that's all folks :-)
Dec 03, 2008 | Konica Minolta bizhub C351 All-In-One...
Unable to set up scan feature.
First question is do you have universal send on the copier. If you have a Send tab on the touch screen you have it, if you only have a scan tab you do not.
With the send tab you can set the device up to scan, create a file and send it to a network destination. With the scan button you have to install the color network scan gear program on your computer.
http://downloads.canon.com/cpr/software/imagerunner/CNSG230.exe
This software is just a twain driver that interfaces with the copier through the network. It does not give you any software to drive the scanner, it only gives you a choice for the copier in your list of scanners. You have to use some other program (i.e. Acrobat standard or MS document imaging) to drive. After you install it open it up, let it discover the machine on the netowrk and close it. The interface only points to the device on the wore, it is not directly used for scanning.
If you have a send button I would recommend for your situation that you scan to a shared folder on your desktop. First you create the shared folder, and make sure you can see it from another PC on the network. If your other PC's can't see it the copier won't either. Create a user on the computer with the shared folder for the copier to use. Set that users password to never expire.
Press the additional functions hard button
Press the touch screen button for address book
Add an address to address book # 1
The type of address will be SMB
Register a name for the address (Scan to PC is fine)
there should be a browse button on the screen, press it
Use the up and down arrow to browse up and down the tree
when you see your network browse from the domain to the PC you are scanning to
When you try to expand the PC you will have to enter in the user and password you created for scanning
point to the shared folder you will use
OK your way back out to the user screens
Have fun scanning
Aug 20, 2008 | Canon imageRUNNER C3220 Color Copier
Canon imageRUNNER 2200 Logo
1,076 people viewed this question
old marine
old marine
