Question about Epson Stylus DX4850 All-In-One InkJet Printer
Scanner not working cannot find scanner WINDOWS XP
It worked all fine for two years on xp
dx 4850 printer works scanner not disconnected printern scanner uninstalled software
reinstalled scannersoftware on epson instrucrion
connected scanner restarted installed drivers
restarted computer nothing works (printer works scanner part not
he cannot find the scanner
started LINUX UBUNTU connected epson 4850dx printer and scanner work without installing so i asume printer is not broken
  • karansu Mar 31, 2009
    my scanner has worked perfectly for a couple of years but a week ago it appears as if my computer cannot find the scanner , I have uninstalled the printer and reinstalled several times but to no avail.
    I removed the power from the printer and removed the usb cable and restarted mycomputer, replaced the usb cable and the power , I could see that the computer had automatically uninstalled the driver and then found and installed the driver on restart but again to no avail .
    I can see in the device manager that my epson stylus is listed but when I go to scaners and camaras from the controll panel it is not shown.
    If I bring up the insall wizard it cannot find the scanner.
Cannot scan  on IMac with Epson Stylus CX3900?
Posted on May 15, 2009
Hp scanjet4850 won't install on windows 7
This fix below will work for Windows 7 and Windows 8 and 8.1 guaranteed, the original software was for Windows XP only. HP have the necessary drivers and Vuescan is a third party scanner program, that is every bit as good as the OEM software, in fact I think it is better.
(1) Download and Install HP Scanjet 4850 Driver: setup_basic_4800_14-5.exe from http://www.hp-drivers-download.com/download/hp/setup_basic_4800_14-5.exe.html
(2) Download and Install Vuescan 64 bit: download from http://download.cnet.com/VueScan-64-bit/3000-12511_4-75328364.html
Sep 19, 2012 | HP Scanjet 4850
My HP C4480 scanner only returns a black image (on
Did you repaired old drivers? if so first uninstall your products drivers and also its folders from program files, then uninstall "wrong update" and reinstall scanner. sometimes built in scanning modules comes wrong but everything works with original scanning software, use different software to scan and some of them may work perfectlly.
Feb 20, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
Problem is apparently HP solutions center. I have a 6940 printer and 4850 scanner. I finally got the printer to work, but it reinstalls the printer drivers at every startup. When I try to scan, the link...
Try uninstalling the drivers for the scanner and the printer. Restart the computer without either the scanner or printer pluged in. After restart install the drivers and only plug up the USB cable for each device when asked by the software.
Jan 21, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Omnipage not recognising Epson DX 4850 scanner (all in one)
Go to the Omnipage sight, they should post the scanners that have problems with their software. If you ahve the packaging, the guide should tell you or direct you a site that carries this information. Call Epson DX scanner or go on line to their site and query them about the problem, they should help. Go to the Contact Us. This should help you good luck
Jun 17, 2009 | ScanSoft OmniPage Pro 14
My cd for Umax Astra 4800/4850 does want to work anymore
Click on one of the links below to download the software.
Run the software after downloading, it is the same software contained on your CD.
UMAX Astra 4800/4850 Scanner
Note:this scanner does not have Vista drivers, but it works fine on XP.
Feb 25, 2009 | Umax Astra 3400 Flatbed Scanner
Hp5300c scanner-can't use HP software on new PC (XP Pro SP3)
Are you using the software from HP? It sucks. If the HP software is not working correctly, then Use the one provided my your operating system works great. Go your Control Panel, Printer and other Hardwares and click Scanners, make a shortcut to your task or start menu and Scan Away. For Faxes, etc. import in outlook or other email client, etc.
Feb 19, 2009 | HP ScanJet 5300C Flatbed Scanner
Blue background
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 06, 2009 | HP Scanjet 4850
Scanner problem
Try uninstalling and reinstalling the scannner. Scanner's can be tough. Try disconnecting USB cable and reconnecting too. How recently did the scanner work? Try reinstalling the scanner software/driver. Also see if you can trouble shoot by right clicking on scanner icon from control panel, scanner.
repost if none of these work. thanks.
Sep 02, 2008 | Sharp AL 1631 Copier
All in One Scanner/Printer problems
Go to this link and type "cannot communicate with scanner" in the search box. Click Search. Then select the "ERROR: Cannot communicate with scanner" link. You will see several things to try to correct your problem. Usually, this error shows up if there is another USB device connected which prevents the computer from "seeing" the scanner, even though it can print without problem. So do try to disconnect any other USB device (except mouse or keyboard) and reboot the system.
May 20, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Scanner Problems
uninstall the device and reinstall it
you need to reinstall the drivers
Mar 09, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Epson Stylus DX4850 All-In-One InkJet Printer Logo
1,417 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
