Question about Dryers
I have a Kenmore front-load dryer (Model# 86880800/Stock# 68808) that has blue ball-point ink all over the inside of the drum. What is the best way to remove the stains?
  • 145 Answers
"Goo Gone" usually works on issues like this.
Posted on Dec 12, 2008
11076812693 drum won't turn.
Kenmore Dryer Model 110.76812693 (11076812693) Drum ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Drum-T...
Kenmore Dryer Model 110.76812693 (11076812693) Drum & Tub Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Kenmore Dryer Model 110.76812693 (11076812693) Motor ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Motor-...
Includes pulley for dryer drum drive belt. Other shaft has reverse threads for blower wheel. Common symptoms of a bad drive motor are: -Dryer stops turning ...
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will ...
? 6:29
https://www.youtube.com/watch?v=bOShDc4kLfk
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Service a Kenmore Dryer with some of the following issues: Heats but ... Kenmore, Whirlpool Dryer Repair - Heats properly,drum will not turn - 11068202794 ..... Whirlpool Kenmore Maytag Amana Dryer Won't Start - Easy Fix ...
How To Fix Dryer That Won't Tumble ' Dryer Repair
www.partselect.com/Repair/Dryer/Will-Not-Tumble/
Feb 08, 2016 | Kenmore Dryers
Drum gap
what is the model number?
Dec 09, 2012 | Kenmore 83142 Electric Dryer
Dryer makes lots of noise when drying..squeaky ans sometimes a "thump"
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Dec 07, 2010 | Kenmore 64882 Electric Dryer
The inside of my dryer is turning blue!
It sounds like a fountain pen may have exploded in there. If the drum is blue from something like ink, the best stuff I have used to remove ink from a dryer is some stuff called "Goo Gone". You can find it at department stores like Wal-Mart, etc. Hope this helped and best wishes.
Aug 15, 2009 | Dryers
How to remove ink from dryer
None of the chemicals you describe should be used. The heat or spark from the motor could cause a explosion.
Put some old laundry material in there and run it multiple loads with no heat it will eventually wear it off.
Apr 06, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
My kenmore series dryer is making noise as it runs. It heats but makes a noise as if coins are in the dryer. I cannot see anything from inside the dryer, is there a way to remove the front face of the...
there's 2 basic ways to removing the front panel. First is 2 screws at the very bottom of the front panel, when removed the panel can be lifted and un-hinged from the top. The other is by using a flat screw driver and prying the top up at the edges on the front side the removing 2 screws or hex screws located inside the front panel toward the top. make sure you undo door swich wires before completely removing the front panel. then in the middle of the drum on the inside of it either 1-3 screws hold the drum to the back. Remove belt first then screws then pull drum straight out. The noise may be from your rear drum bearing or coins have gotten in the paddles of the drum(inside) paddles can be removed. I had coins in one of my paddles, made 60some cents lol at same time found perfctly round lint balls. Good Luck
Mar 02, 2009 | Kenmore 63942 Dryer
Kenmore dryer
could be;
belt slipping
over loading
tumble veins inside drum broken
Dec 13, 2007 | Kenmore 62802 Electric Dryer
Ink in Dryer
wet towel add about 1/2 cup of bleach, put in dryer.... the ink completely gone in less than 10 minutes
Sep 28, 2007 | LG DLG5988 Stainless Steel Gas Dryer
Dryers Logo
136 people viewed this question
Top Dryers Experts
