Question about Maytag PAV2300 Top Load Washer
Water is coming out from underneath my Maytag washer.
Whenever I wash, water comes out from underneath the washer. After the second load in a row, it floods out.
  • 750 Answers
Hello shelleyg537
Welcome to Fixya
My name is Huum,
You have a hose loose under the washer! or a hole in the hose
Thank You For trusting us with your guestion
Please remember to leave a rating before you leave!
Posted on Dec 16, 2008
Leaking Washer
There is a pump underneath the machine. The pump might be bad. Pretty easy fix. It was a top load washer.
Apr 05, 2014 | Maytag Neptune Washer
I have a front loading Maytag Neptune washer. I am constantly gettings the "SUDS" message even when I am hardly putting any soap in. I will also get the "No Drain" message, which used...
This typically happens when you use regular detergent instead of HE detergent, which stresses the pumps. Are you using HE detergent?
Also check for blocked drain hose or clogged water filter.
Apr 21, 2011 | Maytag Neptune MAH5500B Front Load Washer
Washing machine leaks from underneath after rinse cycle...wash cycle runs fine, but when it drains out after rinse cycle, it leaks from underneath
i would 1st look to make sure the drain hose is not loose or broken. be sure it is staying in the drain pipe in the could be a cracked housing on your pump. hope this helps
Jul 11, 2009 | Maytag Neptune MAH5500B Front Load Washer
Leak from under the washer
tub seal has gone bad, will only get worse. Expensive fix,
Jul 02, 2009 | Maytag PAV2300 Top Load Washer
Maytag top load washing machine leaking water from bottom
The machine is leaking water from the bottom, I think the leak is in the area near where the motor is mounted. Before we noticed the water comes from underneath the washer, we smelled like burning rubber.
Al Bana
Jun 26, 2009 | Maytag PAV2300 Top Load Washer
No cold water to my Maytag Top loading washer
Pull the washer out from the wall and disconnect the water lines from the washer. Check to see if a build-up of minerals is clogging the screen on the cold water line where it enters the washing machine.
May 14, 2009 | Maytag PAV2300 Top Load Washer
Washer is leaking while it is just setting still.
The first thing that I would check, is the hot & cold water hoses, that connect in the back of the washer, to see if they are tight. If they are tight and still leaking from there, then the rubber washer, inside the brass fitting part needs replaced. If that doesn't help, then disconnect the power, and water hoses, then turn the washer over and check the water hose underneath, to see if its leaking. One of these hoses has to be the problem.
Jan 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune front load odor
its better do a maintenance, or put it to wash without cloths, only water and clorox, and varsol with the max level (water)
Nov 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washer stops spinning in the middle of the spin cycle
Doe,s the water come on when it stops, it may have something to do with the balance of the washing load, if the water comes on it,s trying to rebalance it self.
Jun 01, 2008 | Maytag Dependable Care LAT9706
Maytag PAV2300 Top Load Washer Logo
57 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
