The inputs on my TV show grainy black and white, not color anymore.
Sounds like you have a faulty cable. replace it and it should resolve your issue.
Posted on Dec 12, 2008
Ps3 plays in black and white with av composite cable
Some newer TVs do not have the traditional "yellow" video input, known as an "AV" connection. Even without that input, you should be able to use the standard three-color Wii AV Cable that came with the system.
What to Do:
  1. Look for "component" inputs on your TV. These connections have a row of five differently-colored inputs (green, blue, and red for video, white and red for audio). If you have more than one set of component inputs, it's the first set that generally works with standard AV cables. Look for a set that has a green input with yellow around it, or the word "video" just above or below it.
  2. Plug the yellow end of the Wii A/V cable into this green "Y" input. Plug the white end into the audio "L" and the red into the audio "R." Leave the blue and second red holes open.
  4. Turn on your Wii console and set your television to the input select being used.
  5. If you are seeing the image from the Wii in black and white, try the following to get the image in color:
    • Cycle through your television's input channels (usually with the "Input Select" or "Source" button on your TV's remote control) to find the input select that has the image in color.
    • If you're only finding the image in black and white, you may need to switch the setting of the input select from a component signal to a standard AV signal. This can be done by:
      • An on screen menu option. This is often accessed by using the "Menu" button on the remote.
      • A button on the remote that switches between the standard and component signals. These can be labeled such things as "AV" or "Video."
Jan 28, 2018 | Haier HL22R 22 in. LCD TV
N64 colors do not work when hooked up to Vizio TV.
You probably have the RCAs in the component video hookups. Its easy to confuse them as they are similar ports. They are usually red, blue, and green. Look for the yellow, white, and red hookups. Those are for RCA connections as they don't work in the component hookups for HD video. i.e. blue-ray, PS3 That will cause the video to look grey and grainy.
Sep 14, 2012 | Nintendo 64 Console
Why cant i get my wii console to work in color
Well it might either be the tv or the av cables that is causing the wii system to be in black grey and white then.
Picture Is Black and White or Does Not Appear Situation:
  • The console powers on and shows a black and white image on the television screen
  • The console powers on and there is no image on the television
What to do:
  • Determine whether the Standard AV Cables (packaged with the system) or the Component Cables (sold separately) are being used.
  • AV Cables
    • Ensure the yellow, red, and white cables are connected to the correct corresponding inputs on the TV. (How To)
    • Try another set of inputs on the TV, or hooking the Wii console up to another TV.
    • If the TV does not have the yellow, red and white inputs, it will most likely have component inputs which allow standard AV cable use. Try these AV hookup steps. (How To)
  • Component Cables
    • Ensure the red, blue and green video cables are connected to the correct corresponding inputs on the TV. (How To)
Still Not Resolved:
  • If the television is continues to show a black and white image when powering on the Wii console, then the problem is likely with the system and it will need to be repaired. Please call 1-800-255-3700 so that we may assist you further.
Mar 06, 2012 | Nintendo Wii Console
LG tv shows av inputs as black & white
you need to plug all three colors in not just yellow
red blue green need to be pluged in their respective colors
Nov 28, 2009 | LG 27LC2R 27 in. LCD TV
Tv went to black and white
It may be a wire has come loose. Check your video inputs. Especially if you have animals or small children. On certain video inputs you lose color if one wire comes loose.
Jul 20, 2009 | LG RU-44SZ63D Television
Black and white grainy output to new samsung lcd
Your DVD player is using a PAL or NTSC variant which is not supported by your display. Somewhere hidden in the depths of the options in the DVD player should be an option to change the composite output type.
Jul 07, 2009 | Insignia 32" 720p Flat-Panel LCD HDTV
Xbox original not showing color screen
Put the xbox on another tv. If it is in color then, the AV inputs may be bad. If that is the case, you may need to buy an AV-UHF/VHF converter, or plug them into a VCR.
Aug 17, 2008 | Microsoft Xbox Console
When I input s-video cable into RCA tv, the screen shows just black & white color, not full color that used to show. I tried to connect my laptop and dvd player with new s-video cable, but it didn't...
Take a flashlight and magnifying glass and look at the S-Video connector on the back of the TV. Check to see that there aren't any pins or other debris stuck in the four holes.
One pair of holes is for the brightness (luma) signal, which gives you the black and white picture, and the other pair of holes is for the color (chroma) signal, which seems to not be functioning.
If there's nothing in the holes, then the internal connection may be flakey. Try gently wiggling the plug on the TV side and see if color returns, even briefly.
Does your TV have other inputs like component YPbPr?
May 08, 2008 | Televison & Video
RCA input suddenly changed to black and white.
Mine is doing the same thing. I have a 2 year old RCA 27" and I was told to do a "hard reset" I am trying it right now. All you have to do is unplug the power cord to the TV for 4 hours. See if that will help.
Sep 22, 2007 | Akai LCT2785TA 27 in. LCD Television
Black and White
There some thing that you had done to get black and white on your tv with the dvd ,check your connections.if the connections are properly connected then the tv could be having a problem in the video input, have a tech look at it.
Apr 03, 2007 | Zenith C13A05LG 13" TV
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
