Question about Sony XR-C7350X Cassette Player
Problems with wiring schematic when replacing a factory stereo
I'm replacing a factory stereo out of a 2004 econoline van with the xr-c7350x stereo. however i'm having problems with the wiring. the factory wiring is a lot longer and i can't find the end to disconnect. i thought about splicing together the main connections however, there are 15 factory wires where the new stereo only has 13. not sure which ones don't get connected.
  • amitchell200 Dec 12, 2008
    I do have the new harness adaptors. I just can't locate where they plug in to.
  • 10,594 Answers
Here are detail of XR-C7350X harness wires...
You can check it on Sony Support as well.
Pin Number Wire Color Function 1 White Left Front Positive 2 Green Left Rear Positive 3 Violet Right Rear Positive 4 Grey Right Front Positive 5 Blue/White Amplifier Remote 6 Blue Antenna Remote 7 Red Accessory 12 Volts 8 Black Ground 9 White/Black Left Front Negative 10 Green/Black Left Rear Negative 11 Violet/Black Right Rear Negative 12 Grey/Black Right Front Negative 13 Sky Blue Telephone Mute 14 Orange/White Illumination 15 Not Used Not Used 16 Yellow Constant 12 Volts
Good Luck.
Posted on Dec 12, 2008
    President:
  • 1,450 Answers
Do you have the harness adaptors? it is best to use these rather than cutting harness. you can swap factory radio back in at later date and they will tell you the wiring ,if not i will try and locate the diagram for you
  • TripleTauto
    TripleTauto Dec 12, 2008
    they plug into the radio end. your factory radio should have connectors at the radio that unplug. also most aftermarket radios will not use the illumination wire this is usually orange
On my 1987 ford econoline 350. im replacing my stereo. what does each color wire do. which wire connects to the new wiring, harness
There are many wires that do diffrent things, i would get a harness connetor, this connector will connect to van wiring and then plug into the new radio connector, this way theres no splicing of the wires, i will enclose a wirng diagram also that will show you what ever wire is for , good day.johnjohn2_133.gif
Jun 12, 2011 | Ford Econoline Cars & Trucks
1997 E250 ford van radio wiring diagram color code
1997 Ford Econoline Van Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink/Light Blue
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Green
Car Radio Illumination Wire: Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 6? x 8? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Car Audio Rear Speakers Size: 6? x 8? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
This info came from website: http://www.modifiedlife.com/1997-ford-econoline-van-car-radio-wiring-diagram/ ----I used this site for my 01 grand marquis, and it was accurate.
Jun 02, 2011 | Ford E-250 Cars & Trucks
I was needing a fuse wiring diagram for a 75 ford econoline ambulace van
a haynes manual will have a rough version of the factory wiring diagram, the factory fuse box is marked. the aftermarket parts of the ambulance will have to be traced out.
Sep 04, 2010 | Oil Filter Ford E150 Econoline Club Wagon...
Installing a after market stereo and need a color diagram of existing wires ithad an am/fm with cassett. Radio is missing and all I have is a bunch of wires to look at! I have more wires than places to put...
1995 Ford Econoline Van Car Audio Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Audio Front Speakers Size: 6′ x 8′
Car Audio Rear Speakers Size: 6′ x 8′
Jun 12, 2009 | 1995 Ford Econoline
Need a stereo wiring diagram for my van.
http://www.the12volt.com/installbay/vehiclewiring/1/yeard/Mercury.html
here is wiring information for you I found it for me to use with the same problem.
Mar 27, 2009 | 1993 Mercury Villager
Brake and turn signal lights stopped working on my 1996 Ford E150
You might have cut a wire or it could have broken or disconnected. Try tracing the wiring where you hooked up the trailer you may find one broken or disconnected.
Mar 26, 2009 | 1996 Ford Econoline
I have an old 96 s10 and it had an older sony xplod in it and it was stolen out of my dash. There is a wire harness with a total of 14-pins. But its split into 3 parts, two have four and one has 6 and i...
Constant 12V+ Orange Switched 12V+ Yellow Ground Black Illumination Gray Dimmer Brown Antenna Right Front Front Speakers 4" x 6" Dash Left Front (+) Tan Left Front (-) Gray Right Front (+) Light Green Right Front (-) Dark Green Rear Speakers 6 1/2" Front Doors Left Rear (+) Brown Left Rear (-) Yellow Right Rear (+) Dark Blue Right Rear (-) Light Blue
Jan 14, 2009 | Sony XR-C7350X Cassette Player
After market stereo with factory nav
GO WITH THE FACTORY ONE,OR YOU WILL HAVE AFTER MARKET PROBLEMS.
May 23, 2017 | 2004 Honda Pilot
Sony XR-C7350X Cassette Player Logo
222 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
