Question about Sirius Sportster 4 SP4-TK1 Satellite Radio Receiver with Car Kit
Remote Code for Sirius dock
I have an Onkyo receiver universal remote, and I'm trying to find the remote code for my sirius radio (Sportster IV). Anybody know where to find this?
  • 20 Answers
SOURCE: sirius sportster sp-tk1, always displays "acquiring signal"
Hi guys!! I am a sirius satellite radio employee and unfortunately, when this happens (usually when the receiver is about 2 years old) the radio is pretty much shot. It is a common problem with the older sportster models, but not so much with the newer one. As the receivers are probably more than a year old, they are now out of warranty and the only resolution is to call us at sirius and say you want to cancel the subscription on the radio. When cancellation is imminent, we will offer to send you a replacement (although it will be a different unit not compatible with you current docking stations) at no cost to you. Sometimes an antenna replacement will actually stop the problem, but it will happen again very shortly afterward, and thus it is only a temp fix to a permanent problem. Hope this helps you out!!
Posted on Feb 20, 2008
  • 20 Answers
SOURCE: Sportster 4
Did u go to the menu to get the Sirius ID# or ESN# or did u get it from the box or back of the unit itself?? I used to work in activations department for sirius and the most common reason that a plug and play unit would not activate is a mismatch in ID #'s. I have seen units with one ID number, but the box or the back of the radio actually being labeled with a different number. By the way,only one signal can be sent to the radio every 20 minutes or so and most reps you talk to don't even know this. So after sending the first signal, all they are doing is clicking a button on the screen and getting a message back that says "Duplicate Provision" meaning that the signal cannot be sent because it is already sent. If you were hearing audio on channel 184 when the signal was sent and you made no adjustments during this time, and the SID or ESN number is the correct one for your unit, and the radio doesn't activate, I would get a replacement. But this never happens in my experience unless there are other signs of defect.
Hope this helps!!
Posted on Feb 29, 2008
  • 20 Answers
SOURCE: sirius radio
Cliff, If you mean a schematic then u are going to have a tough time finding that. It is manufactured by Directed Electronics, so you might try to contact them, but they might not be willing to divulge that info.
  • 2794 Answers
SOURCE: Sirius Sportster 5 won't power up.
Check the fuse in the power to the dock. They blow out all the time.
Posted on Mar 18, 2009
  • 4 Answers
SOURCE: my sirius sportster ( SP-R2 ) satelite radio
did you try going into the menu and increasing the volume output
Posted on Feb 13, 2010
Sportster 5 turns on and off randomly every few seconds hooked to a dock.
Sportster units get very hot ! If you use it in the boombox stop ! Take the radio unit out - remove the silver cover from the boombox ( don't overlook the 2 hidden screws under the speaker grills ) take a dremel tool with a cutting wheel - and cut all the shrouding away around the top of the reciever. This will allow the radio to run way cooler ! I also drilled several holes thru the swivel mount to allow better air-flow !
Jan 02, 2012 | Sirius Satellite Radio Sirius Sportster...
It tells me there is no antenna not detected
Antenna not detected could be caused by one of three things: The antenna, the docking station, or the receiver. If you have other equipment to troubleshoot, you can narrow down what is causing your issue and replace it. is a good source for parts and trouble shooting ;)
Jun 14, 2011 | Sirius Satellite Radio Sirius Sportster...
The sportster will loose power / disconnect with no warning. i am able to get t to turn back on by shaking the entire unit. I had the sportster removed and installed it in a car unit at a best by and the...
Get a new dock if you think its the dock. If that doesn't fix it, then your dock connector has a broken solder joint from years of wear and tear. It's common, and a very easy repair. Just resolder the connector to the board.
Dec 30, 2010 | Sirius Satellite Radio Sirius Sportster...
When I connect the sirius radio to the docking station (sirius connect home kit) I can hear the sound for a few seconds then the docking process engages and I loose the sound. I have the tuner set to...
Hello, I am sorry about your issue. I suggest that you contact Onkyo at 800-229-1687 option #3 so that we can troubleshoot with you. Thank you, Onkyo USA
Jul 03, 2017 | Onkyo TX-DS575 Receiver
It will not hold the signal as long as it used to.
I would try cleaning both the dock and the receiver pin connectors with alcohol, then drying and try that.
Jan 01, 2010 | Sirius Satellite Radio Sirius Sportster...
I had acciently hit the reset and it clearedmy
Call Sirius, and explain to them. They will resend you an activation code and you will pick up right where you left off. Happy listening.
Sep 01, 2009 | Sirius Satellite Radio Sirius Sportster...
Mar 16, 2009 | Sirius Sportster 5 Satellite Radio...
Broken Sportster 4
I'm afraid those things are throw away items. They cost more to repair than they cost to get a new one.
You can get a new dock and remove the piece off the Sportster yourself.
May 25, 2008 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
Sirius sportster sp-tk1, always displays "acquiring signal"
Sirius does not stand behind their products, There is no out of warranty repair for their radios,  and they do not offer sites for repair. Seems  like this is a definite problem with this model. Their solution is to buy a new radio,(with all the new-docking,boombox etc) accessories. also they charge $75.00 to change to the new radio.I liked my sportster 1 because of the FM modulator. It just had to be centrally located and all the radios in my home picked it up(no docking) the new radios require $50.00 docking stations for each stereo location and radio location, unless you bring a boombox everywhere, and the sound isn't the same.    I feel there should be a class action lawsuit against Sirius for these reasons and I might look into it. What do all you think?
Dec 03, 2007 | Sirius Satellite Radio Sirius Sportster...
Satellite radio antennas do tend to fail sometimes. In the early days of Sirius/XM they were made a lot better, but now I've had problems with them a lot more frequently. If the antenna is plugged in securely and it still shows the 'antenna' error code, you most likely need to replace your antenna. It is possible that something else along the antenna signal path is causing your problem - Sometimes the antenna connections in the dock or the receiver itself can cause the issue, but most likely it is the antenna.
Feb 25, 2007 | Sirius Satellite Radio Sirius Sportster...
Sirius Sportster 4 SP4-TK1 Satellite Radio Receiver with Car Kit Logo
46 people viewed this question
Top Sirius Audio Players & Recorders Experts
Scott Thompson
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
