Question about Sony CPD 400PS (White) 19 in.CRT Conventional Monitor
Image center drifts, bad keystone, jiggles
My Sony multiscan 400PS has been working well for years but now it has developed a problem with image geometry and stability. The monitor is used with a mac mini and with a pc clone with a clone vga card. The monitor exhibits the same behavior regardless of which of these computers it is hooked up to. Furthermore, the behavior is the same no matter what screen size and refresh rate is chosen. No apparent live source of EM interference is around the monitor. The monitor is plugged into a line-conditioning UPS, and it doesn't change if I plug it straight into the wall. Giving it the occasional gentle or not-so-gentle whack on the side doesn't fix it either. For several months now, the image has occasionally started to jiggle slightly up and down, which was pretty annoying, but somehow after about an hour or so it would calm down and go back to "normal". Sometimes the jiggling would be there but in almost imperceptible amounts. About three months ago, I woke up the computer from an overnight slumber and the bottom of the image was bouncing up and down. After repeatedly turning it off and on, I gave up and let it rest for a day or so. Subsequently, the bouncing diminished considerably, but the screen geometry was altered and a bad keystone effect was taking place. In addition, the image had to be "centered" by entering near-edge parameters into the monitor's image options (little buttons that let one shift the image to the right and left). Somehow, after about a week or so, the monitor seemed to get better on its own and went back to more or less normal. Then a couple of days ago, the bouncing effect returned, and once again, it is almost impossible to center the image on the screen. The keystone correction is now set at 100% but it still doesn't fully correct. New monitors are cheap nowadays ($200!) but I prefer not to add to the big pile of discarded stuff prematurely, so if repair is possible and reasonably priced, I'd love to hear about it.
  • 326 Answers
Hello, the repair seems possibble to me. One of common reasons for the above mentioned error can be bad soldering (contact). Ask a pro to do the job for you. If you need more info please advice. Arpi
Posted on Mar 22, 2007
Keystone not working
Installation>Wall Screen>Keystone
The automatic keystone adjustment may not be carried out correctly
because of the ambient temperature and the installation
conditions of the projector and the screen. In such cases, correct
the keystone manually.
• When the projector is projecting images where acceleration is
present, such as in a vehicle and aircraft, the automatic keystone
adjustment may not function correctly. In such a case, set AUTO
KEYSTONE in the INSTALLATION menu to OFF and correct the
keystone manually.
• You can correct the vertical keystones. However, their adjustment
ranges are limited in such correction.
When the keystone adjustment is carried out, the adjustment
value is indicated. Note that this value doesn't mean a projection
• The allowable range of the adjustment value in the keystone
adjustment varies depending on the installation conditions.
• When the keystone adjustment takes effect, the resolution
decreases. In addition, stripes may appear or straight lines may
bend in images with complicated patterns. They are not due to
product malfunctions.
• Noise may appear on the screen during the keystone adjustment
because of the type of the video signal being projected and the
setting values of the keystone adjustment. In such cases, set the
keystone adjustment values in the range where the image is displayed
without noise.
• When the keystone adjustment is carried out, the image may not
be displayed correctly because of the type of input signal.
Mar 13, 2014 | Mitsubishi XD250U-ST DLP Projector
Ghost-image on VPL PX31
There is dust in RGB Panel,that ghost image is actual dust.It need to clean.
Mar 16, 2010 | Sony VPL PX31 Multimedia Projector
It makes a loud buzzing noise and image distorts
It's a problem with image stabilizer. It's a hardware problem, so I'm afraid you will have to give it to Sony for a repair. Contact your local Sony service center. If the camera is not under warranty, it could get expensive.
I work in Sony service center.
Sorry for the bad news.
Aug 01, 2009 | Sony Cyber-shot DSC-H9 Digital Camera
Screen image on GPS 400 PS jiggles
Make sure that the driver is updated. Then if it is, contact apple.
Feb 08, 2009 | Sony GDM-400PS 19" CRT Monitor
How do i center the colors, red, blue and green?
Replace Both of your convergence ICs STKs, big black ICs.
STK392-560, also CK pico fuses around ics you may have 1or2 bad .
Jan 01, 2009 | Sony KP-61HS10 61" Rear Projection...
Screen always bleu
ok.. most probably the data cable of your monitor is damaged.. try to check it if the pins are still in tact.. if not, then you should replace it with new one..
Jan 20, 2008 | Sony GDM-400PS 19" CRT Monitor
Sony Multiscan E400
back light or inverter problem Dont know about repairs though.
May 20, 2007 | Sony CPD E400 19" CRT Monitor
Monitor wont turn on
Check with another monitor, you will know where the fault is then.
Apr 02, 2017 | Sony GDM-400PS 19" CRT Monitor
Sony CPD 400PS (White) 19 in.CRT Conventional Monitor Logo
114 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
