Question about GE Cooktops
We use the cooktop for about 5 mins. then it starts beeping
The letter F starts flashing and we can't cook anymore
    Scholar:
  • 111 Answers
You have a failure that needs to be read by a technician. Call GE Consumer Service 1-800-432-2737 as these guys know the product unlike any other and can translate the fault code (there's more behind that "F" that you won't see until the unit is put into "tech mode")
Posted on Dec 16, 2008
Stopped working, flashing code F7 and beeping
Hello Michelle, thank you for your inquiry!
Typically error code F7 indicates that your Frigidaire range is experiencing a failure with either the potentiometer or UIB (User Interface Board). Let's try resetting you range by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. It is best to wait approximately ten minutes and then turn on your appliance. If the error code persists, it would be advisable to contact an experienced appliance repair tech to assist further.
Best regards - Z
Mar 16, 2014 | Frigidaire Stove/Oven/Range Cooktop -...
Hi I have a Samsung ceramic hob that when I have the oven on and cooking veg in saucepans it cuts out randomly displaying SE flashing I'm guessing its overheating but how can I fix this ? It makes
An SE error message on the display of a Samsung ceramic hob means the control panel sensor has been on for too long.
There are a few reasons why the sensor could be saying it's been on for too long:
  • Touching the key area for more than 10 seconds.
  • Leaving a wet cloth on the touch key area.
  • Spilling a liquid on the key area.
  • By touching 2 or more keys together. All of these can be fixed by turning the hob power off at the wall, then back on again.
Jan 30, 2018 | Cooktops
Error message on my electrolux INDUCTION STOVE TOP
Hello - Typically error code E on Electrolux induction cook top indicates an error with the user interface board/control board. Contact a professional to move forward accurately and properly diagnose/repair the unit.
Oct 30, 2012 | Electrolux ICON Designer Series E36IC80ISS...
Error 11 Electrolux induction cooktop
You will need to consult a professional to have the following repaired:
1. Test flex cable betweenboards.2. Change right board.3. Change center board (on 36"models only).4. Change left board.
Jul 23, 2012 | Cooktops
Hey, what can I do if on a ceramic hob there is no error message but a letter "L" at each section? The control buttons don't respond I only can switch off and on again but nothing happens. Please...
You've probably accidentally activated the child-lock "L". It would help to know which model you have as the deactivation method can vary on different models. However, this is the process for activation or deactivation on the EKI-848 which looks like the one in the above picture:
Switching off the childproof lock
1. Press the ON key.
2. Then immediately press the Plus key of the cooking zone at the left-back and the Minus key of the cooking zone at the right-back simultaneously.
3. Then press the Minus key in order to deactivate the childproof lock. The "L" will go off.
If this doesn't work or you have a different model, please post back and I will let you know the correct deactivation method for your model.
Hope this helps.
Regards,
BElectric
Nov 23, 2010 | Kuppersbusch Glass ceramic induction hob...
My Neff induction hob has prgressiely getting worse. All the lights start flashing and only hob will work. But after 10 mins the other hobs start working. The flasing gets worse if you try to start with...
Hi, if you take off the magnetic knob & let it flash a little longer, then switch off & on again it will work. Ours is doing the same. The book says it needs cleaning, as do the customer services people but I've cleaned & cleaned it & I assure you it's spotless. You don't have to wait 10 minutes though to start cooking, just 1 after switching off. It is very annoying though & I think we will be getting an engineer out to look at it.
Nov 29, 2009 | Neff 23 in. T1443 Electric Cooktop
Burn fuses
Something inside is short-circuited. All components look fine thans to burned fuse. Don't try it anymore with new fuses. You need to get a repairman to check it out.
Apr 02, 2008 | Sunpentown 11 in. SR-1330 Electric Cooktop
Magic chef range
f1 is the code for a failed clock most of the times you must replace the clock most of them have a five year warrenty check your owners manuel for warrenty info
Mar 12, 2008 | Cooktops
Cooktops Logo
150 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Dave Harrison
Are you a GE Cooktop Expert? Answer questions, earn points and help others
