The player will not play certain DVDs, mostly newer ones like Toy Story 3. I have checked the codes and they appear correct. However, there are days when it will suddenly play those same DVDS. For example, one day it will play "Ratatouille" and then the next day it will not, and then two weeks from now, it will again. It does, however, play older DVS on a consistent basis. I have used a DVD cleaner also numerous times.
See the causes and remedies and fix it: God bless you
SOURCE: dvd player won't read dvds
There are 2 things you can do as an end user.
1. Clean the DVD's or CD's that you are using. A fingerprint or any other debris or marks on a disc can cause playback problems. Most retailers that sell DVD and CD players also sell disc cleaning kits.
I use another method that works very good, as good or better than the cleaning kits. Use a small amount of windex on the data side of the DVD or CD and then a soft cloth like a bath towel or terry cloth to clean it. It really is important to keep your disc's as clean and scratch free as possible. If that does not help you can move on to the next step.
2. Clean the lens of the laser pick up. You can do that with a cleaning disc that is sold at most all stores that sell DVD players. It is a disc that you put into the player just like any other disc except that it had some very fine brushes on it that cleans off the lens. Let it run for around 20 to 30 seconds.
If neither of those things help, you have a problem that can not be fixed without some good electronic skills.
Something else you may want to keep in mind if you are thinking about taking it to a service center for repair.
Unless you paid more than $200 for it, it may not be worth fixing.
I have been repairing electronics (car and home audio systems) for over 17 years and repairs on these type of units normally run anywhere from $90 to $175 (depending on the problem).
You will also only get a 30 to 60 day warranty on the repair from most repair centers, as opposed to the warranty of a new piece of equipment which is normally 90 days or 1 year.
I hope this helps you fix your DVD recorder or at least make an informed decision. If you need any more help feel free to ask and a good rating would also be greatly appreciated. Thanks.
SOURCE: region 4 videos
What your friend needs is a region hack...Go to www.videohelp.com have your friend put in the model number, hit search, scroll down, look to the right. If any one has a hack for this they do.
SOURCE: HELP HELP HELP!!! JVC DVD PLAYER
I think i just go and get a new DVD player.
My nerves are blank.
THX anyway for your answer.
Regards Ilea
SOURCE: Does the JVC HR-XVC27U play multi-region dvds?
It’s capable of playing REGION1 disks and disks that marked as ALL REGIONS. It will not play any other disks.
SOURCE: DR-MV150B DVD Video Recorder, DVD plays back OK on
Insert one of the recorded disc and try to finalize. If it accepts, that means they are not finalized.
