Make a pen bootable
I don't have a floppy disk reader and the asus P4S800 only uses afudos to flash bios... but it detects for boot usb disks
    Problem Solver:
  • 12 Answers
I have got a solution this day for an other member.
Fist select in the BIOS SETUP the BOOT SEQUENCE and place in the firt place the USB drive to the secon your HDD ou CD-ROOM drive ans so one.
Be sure you have format your USB device as SYSTEM and have the system on it. Thats all.
You can download a light version of WINDOWS XP and put it on the USB flash drive or external USB disk.
Posted on Dec 17, 2008
Setting of USB boot
http://support.fujitsupc.com/CS/Portal/supportsearch.do
A6110/A6120 BIOS Guide
Boot Menu
Nope. No option for booting from USB
1. Floppy Disk Drive
2. Drive0: (Harddrive)
3) CD/DVD Drive
4) NETWORK
5.
6.
7.
Excluded from Boot Order:
USB MEMORY
USB Harddrive
Back before USB thumbdrives (Flash Drive, whatever), came on the scene; the Floppy Drive was used. Then the Optical Drive came out.
(CD/DVD drive)
Transfer the boot data to floppy disks, or a CD/DVD disk.
Make sure they are bootable..........
Regards,
joecoolvette
May 06, 2013 | Computers & Internet
Bat bios checksum problems solve
Step 1:
Update ASUS BIOS b> Insert bootable floppy disk or USB drive. Copy the updated BIOS file to floppy disk or USB drive.
(Note: BIOS file and boot files should fit on a floppy disk. If the BIOS file is too large to fit with boot files, consider using the EZ Flash method described below.) Insert the motherboard support CD into optical drive. Copy AFUDOS.EXE from CD to a floppy disk or USB drive. Reboot. When the DOS prompt appears, type the following: afudos /i[name of BIOS file]For example, "p4c800b.rom" might be the name of the new BIOS file. "afudos
/ip4c800b.rom" is the command that will install it. Wait. Your monitor will display the update's progress with a series of messages: "Reading file," then "Erasing flash," then "Writing flash." The "writing flash" message will be followed with a percentage counter that tells you how far the write has proceeded. The final message will be
"Verifying flash." DO NOT switch off or reboot at any point in this process or you will ruin your motherboard. After the update is complete, the utility will return to the DOS prompt. Remove your floppy disk and reboot. Enter the BIOS Menu and load "Setup Default." Save and reboot. You're finished. b> Update Using EZ Flash Copy your new BIOS files to a floppy disk or USB drive. Reboot. When the system is at POST, press "Alt" + "F2" to enter EZ-Flash. Alternatively, on late model motherboards you may press "Delete" to enter BIOS setup, then access EZ-Flash from the "Tools" option on the navigation bar. (Select Tools > ASUS EZ Flash 2 > YES) Wait for your system to check current BIOS information. Insert your floppy or USB with the new BIOS file. Select the drive letter with the BIOS update file, then select the file. Wait for your system to check the update file. After the file check is finished, click "Yes" to update your BIOS. Wait. Let the update procedure run until it finishes. Do not switch off or reboot or you will ruin your motherboard. When the update is finished, remove the floppy or USB drive and reboot. Enter the BIOS Menu and load "Setup Default." Reboot. You're finished. b> Update Through the Internet If it isn't installed already, install the ASUS Update utility. You can either download it or use the copy on your motherboard's support CD. Close all Windows applications if any are running. Launch the ASUS Update utility from the Windows desktop by clicking "Start>Programs>ASUS>ASUSUpdate>ASUSUpdate." The "ASUS Update" main window will then appear. Select "Update BIOS" from the "Internet option" drop-down menu. Click "Next." Select the ASUS FTP site nearest you, or choose "Auto Select." Click "Next." From the FTP site, select the BIOS version that you wish to download. Click "Next." Start the update. Wait for it to complete.
http://support.asus.com/technicaldocuments/technicaldocuments.aspx?root=198&SLanguage=en-us
Feb 05, 2013 | ASUS Eee PC 900 Notebook
Bootable device has not been dectected
When the PC cannot see a boot file/disk on either thehard disk or floppy drive it gives an error message "No bootable device. Insert boot disk and press anykey" First thing, check to see if the is a floppy disk inthe floppy drive, if so removes this disk. If there was no disk in the floppy drive then it maybe a hard disk problem.
Check the BIOS to see if the hard disk is detected, if not open the case andre-seat the data cable on the hard drive and also where it connects to themotherboard disk controller.
If it still gives this error message and the BIOS does not detect this harddrive, then the hard drive is probably faulty.
A further check on the hard drive, remove the hard drive and connect it to anUSB hard drive adapter and connect it to a working computer's USB port, if thiscomputer does not detect it as an external storage device then the hard driveis faulty.
To get the computer operating again, install a new hard drive in your computerand then install Windows on this hard drive plus the computer's devicedrivers and your programs.
Aug 24, 2011 | Intel D946GZIS Motherboard
I always have failure to boot and have beep sounds. Already installed asus update v6.10.02, still shows overclocking failed on start up and requests to configure BIOS. My system includes: inno3D-FX5500...
1-Does your computer show any sign of response after power button press?
2-Is your power cable properly connected and have main power switched on both your power supply unit and the wall plug?
3-Is the 20/24-pin ATX power connector has been connected between your motherboard and power supply?
4-Can The standby power LED (Green blue) light up continuously after the mains power is connected? (Note: Both flashing and off are no good here)
Fix 1
(1) Isolate The power going into your system ( i.e. connect your system to the wall plug directly, without sharing the power with any other devices via power extension cable.)
(2) Check if the power supply and power cable functions correctly, and have the input of your power supply set to the correct position (either 100/110V or 220/240V, depending on your country)
(3) Please try replacing your power supply.
Fix 2
1. No POST
1.1 Please clear CMOS to have a try (refer to motherboard manual for details)
1.2 If the problem still persists, please contact your retailer for a check
2. There is error message during POST: BIOS ROM checksum error. Detecting floppy drive A media... Insert system disk and press enter
2.1 If the support CD supplied with motherboard is available
2.1.1 Please restart system and put support CD into optical drive, then the system will recover BIOS automatically using CrashFree utility
2.2 If the support CD supplied with motherboard is not available
2.2.1 Prepare a formated floppy disk, then unzip the BIOS file downloaded from ASUS website into the floppy disk.
2.2.2 Please restart system and insert the floppy disk into floppy drive, then the system will recover BIOS automatically using CrashFree utility
2.3 If it is not helpful after the troubleshooting as the steps 2.1 or 2.2, please clear CMOS( referring to the manual introduction)
Fix 3
Please try the latest BIOS. I recommend you to use AFUDOS to update BIOS. You need to unzip it to get the ROM file.
You should use the command as follows:
AFUDOS /i[biosname]
or, afudos /i A:\BIOSNAME.rom(if the BIOS file is in the floppy disk)
You can store your BIOS into a floppy disk or a hard disk with FAT format. Then, you will be able to use AFUDOS to access the BIOS ROM file.
If it is not convenient for you to use DOS and AFUDOS, you can try to use EZ Flash. You can save the BIOS file into a flash disk then boot the system and enter BIOS, then you can update your BIOS by EZ Flash which is in the BIOS Tools page. Please load the default settings in BIOS after you have succeeded updating BIOS.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 22, 2010 | ASUS P5VDC-MX Motherboard
How to boot hp nx9010 from usb to install windows xp because it's cd drive is not working
1. The PC has to support booting from a USB flash/pen/key drive. There may be anywhere from 1-3 items to change in the BIOS to make this possible assuming your BIOS supports it. Some bios's may refer to your flash drive as a USB floppy or USB zip. Of course there are exceptions, perhaps some are covered here.
2. The USB flash drive must support booting from it in general.
3. The flash drive must contain the boot/system files.
4. The flash drive must have bootsector area. This is done with special utilities.
5. References to "A:" drive lines in the autoexec.bat and/or config.sys files you copy to the drive after you make it bootable may result in errors.
6. You "may" have to format your floppy disk first in WinXP before you create a bootdisk as XP may "not" like working later on with a disk formatted otherwise.
7. Included below is a bootable ISO of DOS 7.1 which may be used with some of these methods if you do not have a 1.44 drive.
Nov 17, 2010 | HP Compaq nx9010
How can i make bios k8n-vm.rom to motherboard because i cant read from flopy this file , thank you
anaging and updating your BIOS
The following utilities allow you to manage and update the motherboard
Basic Input/Output System (BIOS) setup.
1.
ASUS EZ Flash
(Updates the BIOS using a floppy disk during POST.)
2.
ASUS AFUDOS
(Updates the BIOS in DOS mode using a bootable floppy
disk.)
3.
ASUS CrashFree BIOS 2
(Updates the BIOS using a bootable floppy
disk or the motherboard support CD when the BIOS file fails or gets
corrupted.)
4.
ASUS Update
(Updates the BIOS in Windows
environment.)
Refer to the corresponding sections for details on these utilities.
prepare the motherboard support CD or the floppy disk containing the updated motherboard BIOS before using this utility.
• Make sure that you rename the original or updated BIOS file in the
floppy disk to K8NVM.ROM.
Recovering the BIOS from the support CD
To recover the BIOS from the support CD:
1. Remove any floppy disk from the floppy disk drive, then turn on the
system.
2. Insert the support CD to the optical drive.
3. The utility displays the following message and automatically checks
the floppy disk for the original or updated BIOS file.
4. Restart the system after the utility completes the updating process.
DO NOT shut down or reset the system while updating the BIOS! Doing
so can cause system boot failure!
more details read http://dlcdnet.asus.com/pub/ASUS/mb/sock754/K8N-VM/e2537_k8n-vm.pdf
Aug 22, 2010 | ASUS K8N-VM Motherboard
Reset bios without running hard disk first
2 options:
  1. create a bootable cd with the bios rom file, and a dos based flash utility (included with bios download). Boot to cd and flash.
  2. Connect a usb floppy drive and create bootable floppy. Copy rom file and flash utility to floppy, boot to floppy and flash......option 2 may be easier if you are not familiar with creating bootable cd's.......Let me know if this helps or not.
Jul 31, 2009 | Acer Aspire 5610-4648 Notebook
I am unable to update bios of my p5rd1vm mboard it update every time but nothing happen
You need to download AFUDOS and the new ROM for the BIOS (both can be gotten from the Asus website). It is easiest with a floppy disk but since I couldn't find any store that carried them I created a bootable CD (search around at www.bootdisk.com for the different ways to do this) and added AFUDOS and the ROM to it. Once this was burned, I rebooted and booted from the CD and was able to flash the BIOS using the instructions that came with AFUDOS. Of course this is only required if you can't get the EZ Flash utility to work which I could not.
Apr 12, 2009 | ASUS P5RD1-VM Motherboard
R4000
yes u can run a usb from the boot menu
u will have to configure the bios.........
u may have to make some changes to ur external hard disk
u will have to use some ones comp to do these aas urs is not working...................
i got this from the net and this should work
Make your flash drive bootable using Bart's mkbt util:
http://www.nu2.nu/mkbt/ | Alt: mkbt20.zip Put a bootable floppy disk in your A: drive or create one using Windows.
Download mkbt20.zip and unpack to to new temp folder you create.
Go to the temp folder.
Extract the bootsector from the bootable floppy disk. eg Open a DOS Window and go to the directory where you extracted MKBT. Type:
mkbt -c a: bootsect.bin
The boot sectors from the bootable floppy disk have just been saved to a file in the temp folder you created.
Format the flash drive in FAT or FAT16.
Copy the bootsector to the flash drive. Open a DOS Window and go to the folder where you extracted MKBT. Type:
mkbt -x bootsect.bin Z:
"Z" represents the flash drive drive Letter. So if your flash drive has another drive letter, then change the "Z" accordingly.
Now you can [grin] "should" be able to copy the utils you need to the pen drive.
Oct 18, 2008 | Compaq Presario R3000 Notebook
Computers & Internet Logo
103 people viewed this question
David Payne
David Payne
