Question about Sega Dreamcast Console
DREAMCAST EVERY TIME I TURN IT ON IT WILL STAY ON FOR SIXTEEN MINUTES THAN IT WILL SHUT OFF WHAT PART DO I NEED TO FIX THIS PROBLEM
  • 57 Answers
Check the power supply. Have it checked by a certified local technician in your area.
Posted on Mar 09, 2007
SOURCE:
I was given a sega dreamcast everything works but when it says install disc i put the disc on the wheel close the door and the cd wont stay on the wheel
If I recall the Sega Dreamcast wheel is a clasp type wheel. You need to push the disk down onto the wheel and you will hear it secure itself onto the wheel. Then close the wheel and you should be good to go. Don't just place it on the wheel... push it down until you here that little clicking sound and it should stay on the wheel.
Aug 10, 2011 | Sega Dreamcast Console
My friend has a sega dreamcast which turns on, shows the menu, but then turns off after only 10 seconds. I've seen reports of a dreamcast turning off during game play, but they all say it's 15-30...
Most likely it is over heating due to a fan that stop spinning or dust in the vents. Make sure the fan is still working and clean it out with compressed air.
Here is a great site all about repairing it - http://www.ifixit.com/Device/Sega_Dreamcast
May 06, 2011 | Sega Dreamcast Console
My Dreamcast is able to play any game for a couple of minutes, then resets to the main title screen after a period of time (this varies from around 1-10 minutes), sometimes just showing a black screen. I...
Sounds like your dreamcast is getting cut of from its power, the dreamcast sometimes gets a build of of dirt around the power connector pins that supplies the entire unit with power, try this youtube guide here for cleaning http://www.youtube.com/watch?v=3rizeLEQyzs&feature=related you don't need to do the bending section of the pins. just clean them and the actually plastic socket section where the pins go in.
Regards,
Omeil
Nov 07, 2010 | Sega Dreamcast Console
2006 factory dodge radio sat quit working
soft reset. get in turn on truck with door shut turn on sat radio on ch 184. turn off radio turn off truck and take keys out. next open door fully for 90 seconds. shut door. turn on truck. turn on radio and have sirius reset it. its called a soft reset.
Dec 25, 2008 | Eclipse SIR-ECL1 SIRIUS Radio Receiver
Dreamcast just resets
hey man this is the best soloution
Oct 16, 2008 | Sega Dreamcast Console
Dreamcast wont power on
sounds like a fuse gone
there's one on the plug? (In uk there is)
There is a glass fuse inside the machine
So take it apart and look at it (close to the where the power goes into the machine
If there is no wire in the glass take it out and get a replacement at an electric shop.
DO NOT JUST PUT ANY OLD BIT OF WIRE IN THERE!
Aug 18, 2008 | Sega Dreamcast Console
Sega Dreamcast console problem
First off, NEVER store a game console on top of a subwoofer. It is like a giant magnet, and electronic devices do not handle magnetics. I don't think i've ever heard of a VGA box, Sega brand or not, killing a console. Millions use aftermarket AV cables and adaptors on all consoles without problem. I think it likely died from being on top of the sub. Relocate it and you should be fine. Running it for a few hours isnt likely either unless you had the vents entirely blocked.
To the guest who's drive isnt spinning, I would say your drive motor has burnt out. This doesn't indicate a defect in Dreamcasts, per se, it just means bad luck or excessive dust which killed it. Either buy a different Dreamcast or see if you can find a drive replacement.
Hope this helps.
Feb 28, 2008 | Sega Dreamcast Console
Black Screen On Start Up!
Please post pictures, and where did it fall out from, and did you put a game in and the turn it on? Maybe it could be the main board being faulty, and might be fried. Please add more details.
Nov 01, 2007 | Sega Dreamcast Console
Dreamcast Randomly Resetting
this the best solution it work for me
Jun 11, 2007 | Sega Dreamcast Console
Sega Dreamcast Console Logo
Top Sega Video Game Consoles & Games Experts
tamaracrum
Level 1 Expert
Reggie brown
Norman Worley
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
