Question about Pelonis WM-HO202C Oil Filled Radiator Heater
Doesn't do anything
Worked and now it doesn't.
light does not go on- and does not produce heat.
does it have a overheat setting that could have tripped a fuse
inside the unit?
    Genius:
  • 1,199 Answers
Look under control pannel for a fuse! I am not sure about your model but most of these heater types have a fuse
good luck!
Posted on Dec 12, 2008
2 Suggested Answers
SOURCE: just stopped working
i have the same problem. was working great for one week then it just stopped working. really pisses me off how things are made so badly these days. there is no reason why something should break after using it for a week. any soultions before it goes to the curb??
Posted on Nov 22, 2008
Our dryer works but it does not heat up.
Here are the most likely problems, starting with the most common to the least common.
The inspection, testing, and repair will require dismantling the machine.
1) The heating element has failed, needs replacement.
2) One of the "overheat thermostats" or "fuse" has tripped, needs replacement.
3) A wire has burned in two inside the back or bottom of the machine, needs repair. ( Near the heating element)
4) A wire has burned in two inside the back of the machine where the electrical cord is attached, needs repair.
5) A circuit breaker has tripped in your fuse box or circuit breaker box, wherever that is in your house/apartment.
Be blessed.
Jul 16, 2013 | Dryers
Admiral dryer super capacity dryer won't heat up and light doesn't stay on. It happened when we first brought it home years ago and the repair may said to reset some button but I don't kn
see this causes and fix it. God bless you
Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Thermal Fuse / Thermal Cut out
On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel or behind the front panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing or is sometimes round and made of metal and plastic.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse this is the most common reason for blowing the fuse. (You can't re-set this type of fuse.)
Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Sep 28, 2012 | Admiral Dryers
Admiral heavy duty super capacity dryer won't heat up.
see this causes , fix it. God bless you, use the common sense
Door Switch
Wiring
No heat when drying
Power From The House
Door Switch
Wiring
Sep 27, 2012 | Dryers
Maytag Neptune dryer was always drying on high heat, now won't turn on
Door Switch
Wiring
Sep 27, 2012 | Maytag Dryers
Oven not producing any heat
just the oven? then more than likely the element. if the stove eyes are not working as well, then your looking more at a sensor, thermostat, fuse, breaker, etc. almost always an element though
Mar 20, 2012 | Electrolux Ovens
Heat doesn't work ..dryer spins but no heat is produced
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Aug 01, 2009 | Dryers
My dryer is not producing heat. Just cool air!
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Jul 17, 2009 | Dryers
Just stopped working
Sep 26, 2008 | Pelonis WM-HO202C Oil Filled Radiator...
Pelonis WM-HO202C Oil Filled Radiator Heater Logo
144 people viewed this question
Top Pelonis Heating & Cooling Experts
Paul Carew
Mack Baxter
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Pelonis Heating and Cooling Expert? Answer questions, earn points and help others
