Question about HP ScanJet 2300C Flatbed Scanner
Scanned image comes out all black
Error message
"Scanner could not be initialized because its internal hardware could not find home position"
Any suggestions would help
  • 585 Answers
The scanner has a locking device for transport. If it has inadvertently gotten flipped it will cause this issue. Look for the little green or blue tab labeled "Lock" "Unlock" making sure it is unlocked.
Posted on Dec 29, 2008
  • Bruce Volkers
    Bruce Volkers Dec 30, 2008
    If the lock was not the issue, then there may be a problem with the drive, (some scanners have a belt, others have a screw drive) or the "limit switch" that detects the end of travel, therefore the "home" position. Your answer may lie there. My local thrift store sells scanners for $10.00 and under, therefore I find it hard to justify spending any money on repairs here. Maybe you could find a similarly cheap replacement?
  • syedfarazulh Apr 14, 2011
    where I can find blue or green tab ?
I am getting call service 17 message on my scanner cum printer Panasonic KX-MB1500. Please suggest a solution?
Toner cartridge rack error.Error detection when the black cartridge home position sensor is not set to on within 3 seconds after the rack motor has started to operate during initialization of the toner cartridge rack position.
Nov 03, 2013 | Minolta magicolor 2300W Laser Printer
Service call C0650
Error code C0650 Konica Minolta bizhub 160 Black
Faulty scanner home
position sensor.
• The scanner home position sensor (PS100) does not go
from HIGH to LOW when the scanner motor (M4) is energized
for a given number of steps after the sequence to
bring the scanner back to its home position has been
started at the end of a scan motion and during re-shading.
from LOW to HIGH when the scanner motor (M4) is energized
for a given number of steps after a scan motion has
been started at the end of a PS100 home check scan
THANK'S
Jun 26, 2013 | Konica Minolta bizhub 160 Black Drum...
My hp2840 scanner not working display message : scanner error 3 turn off and on please advice
Scanner Error
The device has experienced an internal hardware error.
  • Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.If the error persists, replace the scanning assembly.
Jul 09, 2011 | HP LaserJet 2840 Printer
My hp scanjet 2400 stops at warming up then shows unexpected error. please help
Try connecting it on direct wall outlet.Not a surge protector or power strip
Try below solutions
An Unexpected Internal Error Has Occurred' Error Message Displays
Issue When attempting to scan, or, during the scanning process, the error message An unexpected internal error has occurred may display on the computer screen. There are three scenarios where this issue occurs. This document covers each scenario where this error may occur and provides links to the appropriate documentation for resolving each scenario. Solution one If you have multiple versions of HP Image Zone software installed on your computer, click here to download a patch that might resolve this issue . If you do not know if you have multiple versions of HP Image Zone installed, follow the instructions below.
  1. Click Start , point to Settings , and then click Control Panel .
  2. Click Add/Remove Programs .
  3. In the list of programs that displays, look for the following entries:
    • HP Image Zone
    • HP Photo and Imaging Gallery
  4. If there is more than one entry listed, then there are multiple versions of HP Image Zone software installed on the computer.
  5. Click here to download the patch. Follow the on-screen instructions to download and install the patch.
  6. If the issue persists, try the next solution.
Solution two Clicking Scan picture or image in the HP Director software results in an unexpected internal error or causes the computer system to stop responding. Click here to resolve this issue (c00369826). Solution three When accepting a scan from the HP Scanning preview window, the scanner may start to scan and then lock up with the lamp approximately ½ way down the scanner bed. This results in an unexpected internal error or causes the computer system to stop responding. Click here to resolve this issue (c00373192). Solution four When accepting a scan, the scanner completes the final scan and the lamp returns to the home position; however, when the image is being processed or sent to the receiving application (that is, HP Photo and Imaging Gallery), an unexpected internal error occurs. Click here to resolve this issue (c00373192). Solution five Immediately after clicking Scan Picture from the HP Director when using an HP Scanjet 3970 with v2.2 software, an unexpected internal error occurs.
Try also this link
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00259434&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=297430
I hope you issue should be fix to lessen your frustrations.You can do it
Regards
Your's Truly,
Christian from HP
Say "Thanks" by clicking the thumb icon in the post that helped you.
Please click "YES" in solution that solves your problem as "was this helpful?"
(Although I am employed by HP, I am speaking for myself and not for HP)
Apr 10, 2011 | Office Equipment & Supplies
Cannot scan documents
go to device manager look for imaging device (scanner) right click and uninstall. / click scan for hardware changes tab, found new hardware must be appeared and click next / select don't search, i will choose the driver to install / click show compatible hardware and choose scanner driver found and click next. and finish.
Feb 11, 2010 | Fujitsu M3091DC Path-Through Scanner
One image appears stuck on a page. We could not
Try reinstalling the driver and application software again.
Nov 10, 2009 | Fujitsu fi-5120C
Editing text
Windows
» HP Scanjet Scanners Supported and not Supported in Microsoft(R) Windows XP s.gif » Resolving 'Missing MSIEXEC.EXE File is Linked to Missing Export: MSI.DLL.222' Error Message During Installation of the HP Director Software s.gif » Resolving 'Scanner not supported' or 'Unsupported operating system' Error Messages s.gif » Resolving Image Zone Install Error 1402, 1406, 1714, 1904, 1935, 2203, or Unknown Error s.gif » Error 'The System Cannot Find the File Specified' While Attempting to Install the HP Photo & Imaging Software in Windows 98, 98se, or Me s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Error Install Failure' Message for the hpznfx01.exe Software Module Displays on the Computer When Installing HP Image Zone s.gif » The message 'Fatal error during installation' or 'Error Install Failure' Occurs When Installing HP Image Zone s.gif » A 'Fatal Error' or 'Error_Install_Failure' Error Message Displays on the Computer When Installing the Image Zone Software s.gif » The Error Message 'Error_Install_Failure' or 'Fatal Error' Occurs when Installing Image Zone Software s.gif s.gif
Macintosh
» Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Scanner could not be initialized' Message Displays in Mac OS X when the All-in-One Software is Installed s.gif » Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif s.gifs.gif
Jun 13, 2008 | HP 4570C Flatbed Scanner
ERROR CODE C0660
This is a scanner problem, try the following...
C0650, C0660
Step Check Item Result Action
1 Scanner can be moved manually.
NO Correct drive coupling (Scanner
Belt tension, pulley operation,
drive cable tension)
2 Scan motion: initial scan motion after the
Power Switch has been turned ON or Front
Door has been opened and closed.
NO Carry out misfeed/malfunction
troubleshooting procedures.
3 Connectors are connected properly on
Scanner Motor Drive Board: PWB-IC
PJ1IC, PJ2IC, and PJ3IC.
NO Check connectors for connection.
4 Scanner Motor turns when the Start key is
pressed.
Change motor. Change
Scanner Motor Drive Board.
5 I/O check for Scanner Home Sensor: the
voltage across PJ6C-2 on Image Processing
Board and GND is DC 0 V (home position)
when the sensor is blocked and DC 5
V when the sensor is unblocked.
YES Change Image Processing
Board.
NO Check sensor for installation.
Correct detecting plate.
Check sensor connector for
connection. Change sensor.
6 “IR Area” check:
Malfunction when Power Switch is turned
ON after “Top Image” has been set to 0 and
“FD-Mag.” to 1.000.
Apr 03, 2008 | Minolta CF2001 Copier
Officejet 7310: Scanner Failure
If you get a "Scanner failure" message then the problem is the motor itself. Notice how the motor works fine when the scanner is moving slowly, like copies or faxing with the original laid on the glass. HOWEVER, the scanner failure comes up when you use the automatic document feeder on top. Why? Because the scanner assembly has to move to the other side of the printer at high speed to get into position, and it's the high speed movement that triggers the error on the printer. The motor is expensive, part number Q3450-60003. Many other models use the same motor, maybe you could find one cheap somewhere and swap the motor?
Jan 10, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Scanner 3770 hardware problem
Hi, it is possible that your scanner has a transport locking lever or knob underneath which might have been keeping the carriage locked in place. Try checking and release if there is one. Hope this works for you. Pls post again how things turn up. Good luck and kind regards.
Jul 30, 2007 | HP Scanjet 3770 Flatbed Scanner
HP ScanJet 2300C Flatbed Scanner Logo
306 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
