Printer red light is flashing paper got jamed
    Novelist:
  • 59 Answers
Hi hicksaa,
When paper gets jammed, the best course of action is to open/remove the paper tray and pull out the jammed or misfed sheet(s). Then close or replace the tray. Depending on the model, the printer may start by itself, or you may need to press the "online" button.
If you can tell me the model of your printer, I can give you more specific instructions. In the meantime, I hope this helps!
H2H
Posted on Dec 12, 2008
Dp8020 wrench icon flashing and add paper red light on
You have a problem in paper casette,mechanical problem.Remove the paper casette and verify jamed paper or paper sensor blocation.
Apr 12, 2012 | Panasonic DP-8020E Black and White Copier
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Red light constantly on and not printing. changed
do you print CD or plain paper, red light is mean jamed paper or change cartridge. Open the top door >press drop ink symbol> look at printer head show on ink ink tray.
Aug 01, 2009 | Epson Stylus Photo R200 InkJet Printer
Alternate flashing red lights on epson stylus photo 900
Flashing alternately? Need reset waste ink. SSc ver 4.3 support this model. Find at indoreset.blogspot.com.
Jun 26, 2009 | Epson Stylus Photo 900 InkJet Printer
Alternate flashing lights on epson stylus photo 900
Reset waste ink using SSC ver 4.3. Find at indoreset.blogspot.com.
Jun 26, 2009 | Epson RX620 All-In-One InkJet Photo...
Red light on left hand side keeps flashing
check the catridge or any paper is jamed in ur printer
Jun 07, 2009 | Epson Stylus C64 InkJet Printer
Kyocera fS-920KX. Not printing
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem
YBC (/\)
Jun 01, 2009 | Kyocera FS-920 Laser Printer
PAPER JAM
open the front door and remove inkl cartridge then check thr is not any paper jam .thn refix the inkmcartridge.
Mar 12, 2009 | HP Deskjet 450 wbt Printer
Printer problem
Are you getting any fault codes?
There are several things I can think of off hand. But with a fault code I could narrow it down for you.
Thanks
Nov 29, 2007 | Xerox Phaser 8400 Laser Printer
1,136 people viewed this question
jasbo
jasbo
