Question about Pioneer SD-533HD5 53" Rear Projection HDTV
My sd-533hd5 keeps blowing the 5 amp 125v fuses
My tv keeps blowing the 5 amp fuses in the back of the tv. The tv goes to standby and won't turn on, this started happening a while ago found out it was the was the fuses. The fuse would last usually a couple of months and then blow, then it became more frequent now the fuse only lasts a couple of hours. Is there something else causing the fuse to blow and if so what is it and is it worth fixing. Thanks
  • Anonymous Dec 20, 2008
    i turned the tv on and it works for 10 mins the it goes to stand bye. then i shut it off the tv for 1 min then turn it on and it apears to warm up then flips to stand by. help me find the fuse
    Genius:
  • 1,199 Answers
Yes! it sounds like a power supply problem! or the flyback in the main board needs replaced ( part is in the $70.00 range
Posted on Dec 12, 2008
Tv only stays in standby mode
Replace Fuses 302 5amp and 303 5 amp Resolder all poor connection on power supply board and Replace Both STK ICs they are big black ics STK392-180s is best ICs Call Mats 1-800-628-1118 This should have you back to watching TV again.
Sep 19, 2009 | Pioneer SD-643HD5 64" Rear Projection...
Pioneer SD533HD5 repair, blown STK's or bad power assy?
Go back recheck everything 6amp fuse in middle of power supply board that will blow, also solder everything that looks like poor connection pioneer always has a lot of cold solder jionts.CK all pico fuses they are green,yellow look like resistors but are fuses.
Jun 15, 2009 | Pioneer SD-533HD5 53" Rear Projection HDTV
Panasonic ct-32sl13g blowing fuse by power supply
You will need to remove the back of the TV. Don't worry, it's not that bad.
There are 4 screws across the top, one on each side, one right next to where the power cord goes into the back of the case, and the two more by all of the video connections **These are the most important to remove because they attach the main board to the back of the case.
Once you have remove the screws then the entire back of the set will slide off. If you look where the power cord attaches to the board you will see a small fuse. This is a 6.3 Amp 125 volt fuse. You can replace it with a 6.3 Amp 250 volt fuse from your local Radio Shack. A four pack costs between $3 and $5.
Make sure that you check that it works before putting it all back together. Check for any loose connection cables while you're back there. I found a few when I did this.
Apr 15, 2009 | Panasonic CT-32SL13 32" TV
Replaced fuses & they keep blowing
there could be a shortage in any of the dc line that cause the fuse to blow up again, either overloading or chortage will cause this, try to see for any sign of other componenet failure, wires that has been bended and cripped, transistor that has been twisted or alike
cheers
Sep 04, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
No power
I'm having a very similar problem, basically its a fuse that is blowing out, I think the transformer is sending too much power it's way.
Jun 14, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
3 amp fuse blows every time
first if you have a can of air or air compressor blow out back if using an air compressor dont blow directly on stuff up close and dont let to much air out at once then if you have another 3 amp try it if not around the prongs wrap aluminum foil around them to were they all connectput it back in then it should work
Feb 06, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Not turning on
Power supply board pull,then remove original solder on 5 volt
regulator pins then resolder + replace 4 amp fuse........T.
Oct 25, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
4a fuse blown
1)pull chassis.remove power PCB==the one with large heatsink w/convergence IC's on it 2)Observe four regulators also on same heatsink Remove solder from all reg. pins-clean PCB 3)Resolder 4)solder any/all bad connects 5)replace 4 amp fuse 6)reassemble & test
Oct 05, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Turns off on its own with a pop sound and is blowing a fuse
90% it is convergence board problem. Need to replace STK392-110 IC.
Sep 16, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneersd533hd5
Had the exact problem on 11/14/06. Ordered a power supply board, which was $300+, got it in and when I went to replace the part, found that the old part had a blown fuse (a lot cheaper). Of course if I had put in the new part it would have fixed it also. CHECK THE FUSES IN THE MIDDLE CIRCUIT BOARD (there are 3 boards).
Nov 10, 2006 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer SD-533HD5 53" Rear Projection HDTV Logo
288 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
