Question about GE WBSR3140DW Top Load Washer
I have a GE Washing Maching and when the water is drained from the washing machine it comes out from the bottom and goes all over my floor. Is this from the pump? I am a single woman and don't have the extra money to call a repairman so I am trying to fix it myself. I don't have the model number with me right now.
I would be happy to help you through this. The first thing to do is get the machine up off the floor onto a base that allows you to slide under machine on your back with a flash light. Make sure whatever you decide to lift machine up onto is very stable and durable. Bricks, blocks, or a utility cart maybe. You need to look under machine to see where the leak is coming from. You want to make sure it is not going to fall on you. The machine is not that heavy, just awkward to lift or move because of it's size. So, you could slide something under each corner, one at a time, or ask a friend to help lift it onto a base. Now you are ready to go. Don't worry, this is really easy.
Get a towel, flashlight, and start machine on a small load with shortest cycle set.(probably delicate). After you start machine, slide under and and try to find where water is leaking from. The pump is going to be a plastic circular shape thing with ridges on outside. Probably dead front center and attached to motor. If water is leaking anywhere from plastic circle thing, then this is your problem. BUT, also follow all the black hoses that are under machine. Sometimes leak can be a cracked hose or loose attachment. That is real cheap and easy. The hoses are attached with metal ring deals. You take a pair of channel locks or big pliers and squeeze them to open. There are 2 or 3 hoses that attach to pump that will need to be removed if this is where leak is coming from. Then, the pump is only attached with meatal clips that you pull out to release pump from motor. No tools needed. Take the pump to sears or local appliance shop and I guarantee they will have replacement. I just paid $59.99 for mine. It took me less than 30 minutes total to replace. Feel free to ask more questions. I love this kinda stuff. Good luck and let me know how it goes.
Tim....Denver, CO slamarama@comcast.net
Posted on Dec 13, 2008
Oct 18, 2012 | Whirlpool Washing Machines
Mar 23, 2011 | GE WBSR3140DW Top Load Washer
Nov 22, 2010 | Maytag EPIC MFW9700S Front Load Washer
Oct 02, 2009 | GE 3.2 cu. ft. Washer
Sep 17, 2009 | GE WJSR2070B Top Load Washer
Sep 16, 2009 | Washing Machines
Mar 11, 2009 | GE WBSR3140DW Top Load Washer
Dec 21, 2008 | Kenmore 24032\24036 Top Load Washer
Oct 08, 2008 | GE Washing Machines
Dec 29, 2007 | Washing Machines
647 people viewed this question
after a wash there is a little water left in the drum and some water on the floor in the front corners of washer is this normal?
