Question about HP Pavilion a305w (DM181AR) PC Desktop
HP computer doesn't turn on
Computer doesn't turn on. Green light is blinking on the power supply. I disconnected all the cables and reconnected them again now the green light on power supply is on and when I power press power on button on computer, the fan starts to turn on but then nothing happens.
Power supply is ATX 250-12z. Computer is HP Pavilion a305w.
  • 2 more comments
  • info319 Dec 13, 2008
    I got hold of ATX power supply and I pluged it in. Hurray! it works.
    There has to be a better way to diagnose this problem. Even better if the power supply is fusible or has a circuit breaker which can trip in case of power overload.
    Thanks.
  • David Dec 30, 2008
    i plugged my hp in to the belkin powerstrip at my parents house, and the fan kicked on in the psu, the light turned on on the psu, then i didn't here the bios beep, or the hdd start up, so i looked at the back to check that the power cable was in all the way, and the light was flashing green. I then unpluged it, and tried without powering the motherboard, and pata/eide drives, then the fan wouldn't work at all. when i reconnected everything the fan on the heatsink for the processor moved, but would not spin. I then tested the outlet for power and determined it had approx. 120 volts of power. i then tested the psu to see if it was shorted, and the ground pin was grounded to the case (good) but the two others, power and neutral, were grounded to the case as well (bad) thus i'm assuming there is a short to the case from inside. Also with the psu case taken apart there is a clicking noise from inside, cannot figure out where yet.
  • Anonymous Feb 17, 2009
    I have the same power supply and trouble on my HP Pavilon a620h. The rear power green light is blinking but the pc will not power up. Tried disconnecting and re-connecting all power cables to no avail. Front switch seems to be alright but I don't have a digital meter with me. Could not find any overload or breaker switch.
  • Anonymous Mar 23, 2014
    Won't start. There is power. But when press the power button, the fans start spinning, but it doesn't start the POST.
  • 59 Answers
Your power supply is bad--you will need to replace. I suggest looking at tigerdiect for a replacement.
Posted on Dec 12, 2008
Blinking green light, will not power on
Did you have a surge protector that your computer was plugged in if not it may have done something to your power supply good luc hope this helps Merry Christmas
Dec 09, 2017 | HP Pavilion a810n (PP164AA) PC Desktop
My seagate freeagent 1tb is blinking whit lights and my computer does not recognize it. Help me
***Please NOTE***
Touch the drive and put your ear to it, to test if the drive is spinning and working. Do this while it is powered on. Also, try disconnecting the USB cable, reboot the computer, re-connect USB cable to another USB port on computer. If you still have the same issue, try the below solutions.
  • Make sure the computer and external hard drive are powered on.
  • Disconnect the external drive's USB or the eSATA cable, which ever one you're using.
  • Disconnect the power supply plug from the external drive.
  • Power off the computer.
  • Disconnect the computer's power supply cord for 60 seconds.
  • Reconnect the computer.
  • Power on the computer.
  • Connect the power supply to the external drive.
  • Connect the drive's USB or the eSATA cable and check for detection.
If the still no detection and still blinking lights on the drive, check the power supply to the drive.
Check to see what the led light on the power supply is doing.
If it's blinking, power down the drive, unplug data cable and then reconnect the power supply to another electrical outlet. If it still blinks repeatedly, then you power supply is bad.
If the led is solid (lit and not blinking) follow the same steps from above to connect it to another outlet.
Next, plug the power supply to the external drive and power it up.
If the power supply starts to blink repeatedly, then your controller board inside the enclosure is bad.
Thank you for the opportunity to help you.
Jun 04, 2011 | Seagate FreeAgent Pro 1TB External USB...
After a storm the other night my Proview PL866s amber light is blinking - however when I press the amber button (which usually turns green and then it works) nothing is happening except blank screen and...
If this happened after a storm, the monitor may have been subjected to a power surge, which unfortunately might have killed it.
If you have another monitor (or a friend who has one) try plugging that other monitor into your computer. If the second monitor works, yours will need to be replaced as the input was probably destroyed by the power surge.
If the second monitor also doesn't work, there may be a problem with your computer, most likely with the power supply (this is the part most often damaged by a power surge). You may want to have it examined by a professional computer repair person at that point.
Hope this is helpful!
May 16, 2011 | Proview PL866B 18 in. Flat Panel LCD...
WHEN I PRESS POWER BUTTON NOTHING HAPPENS
Disconnect the Power cable / A/c adapter/Battery from computer.
Disconnect External peripherials.
Hold down the power button on the computer for 10 seconds.
Reconnect the power cable or A/c adapter and battery or the computer
Try to turn on the computer
check for Led's on the computer
If still no display ,shut down the computer,disconnect power cable.
Open the computer tower,remove memory modules,reconnect power cable and turn on the computer.If you get a beeping sound after turning on you should be getting beeping sound suggesting the mother board is not bad.Turn on the computer and disconnect power cable from computer.
Reseat 1 memory at a time if you have 2 memory module or if single memory module reseat in different memory slot,swap memory module.
Reconnect the power cable and turn on the computer if it boots to desktop possible issue with 1 of the memory module.
Disconnect the harddrive ide cable from the harddrive .Turn on the computer.
If still unable to power on .Shutdown the computer and disconnect power cable.Remove video card,sound card ,modem card if any .Connect just the vga cable from monitor to the integrated video port.
Connect power cable and turn on the computer.
If computer turns on possible issue with one of PCI or PCI express card.
If still unable to power on.Disconnect the power connector pin from the motherboard and reconnect it back.Turn on the computer check power power led on motherboard,also check if the processor fan is spinning. if no go then issue with motherboard. GOOD Luck.!!
Aug 27, 2009 | Insignia D400a PC Desktop
I have an HP Pavilion a384x. It will not turn on
First with the computer turned off make sure the switch on the power supply is set to 115v.
If you turn the computer back on and you still get a flashing green light on the back of the power supply and a constant light on the front of the computer with no video, then try replacing the power supply with either a new one or a known working good one.
If that doesn't do it then it has to be the motherboard at that point.
Keep in mind normally on those power supplies, the green light should be constant. So it has to be either the power supply is bad or the moterboard is bad and you'll know when you put a new or known good working power supply in the computer.
Aug 03, 2009 | HP Computers & Internet
Will not pwer up. Greenlight blinking on back
The green blinking light can mean there is a problem with the power supply.
Try unplugging the computer from the wall, and turning on the pc on switch.
After a few minutes, try plugging it back in.
If that does not start things up, you may have a bad power supply.
If the power supply is bad, these models take standard power supplies. You should get an ATX 350Watt or higher power supply.
They are easy to replace, unplug the power from the wall, disconnect all the cables inside the computer. Unscrew the four phillips screws outside the back of the computer where the power supply is attached to the case.
Remove and replace.
If you don't feel comfortable with this, a good local computer shop can help you out.
Apr 13, 2009 | HP Compaq Presario SR1330NX (PP161AA) PC...
Computer wont start up. Blinking green light in the back of tower
I've had that happen twice to my Vaio desktop and there was a very easy fix. I'm not a techie, but I found a recommended solution online when this first happened six months ago. I couldn't find the solution again, but I fortunately remembered the steps.
Remove the side pane to access your motherboard cables, etc. Locate the connector on your motherboard that contains the wires going from your power supply to your motherboard. It will be a large, rectangular connector with a lot of individual wires It is not a ribbon cable but should be located next to a ribbon cable connector andnext to a geen blnking light on your motherboard (when the power supply is plugged into the wall). Note: This green blinking light is in addition to the green blinking light on the back of the PC.
This next step is important: You have to disconnect the connector noted above from the motherboard WHILE the power suply is plugged into the wall. Wait a few seconds and plug it back in. The blinking reen light on the motherboard should now be a solid green light. The PC should now power up.
It worked twice for me; I hope it works for you.
Mar 05, 2009 | Sony VAIO VGC-RB42G PC Desktop
Hp pavillion desktop will not power up. Blinking green light at power supply
Step 1 : Turn off the system by pressing the power button for 5 - 10 sec until the power LED is off. Removed all cables including the power cable (Exclude monitor cable and KeyBoard/Mouse).
Step 2 : Press power button for 5-10 sec again to drain fela power.
Step 3 : Reconnect the power cable at the back of the tower/computer and power on the system.
**If the same problem exists, Call HP tech Support (800-474-6836) because there is a high possibility that you have a bad Motherboard or Power Supply on the system.
Oct 28, 2008 | HP Computers & Internet
HP FLAT SCREEN TV BLINKING POWER LIGHT/BLACK SCREEN
sounds like the power supply has gone bad.
Jan 04, 2008 | Computers & Internet
HP Pavilion a305w (DM181AR) PC Desktop Logo
2,373 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
