Question about RCA HD50LPW175 50" HDTV
I HAVE A RCA DLP TV AND THE LAMP KEEPS BREAKING EVERYYEAR I have an RCA DLP tv. The model number is M50WH72SYX2, serial number H986C6031. Purchased a year and a half ago, just a few months after the year warranty ran up. The tv would shut off and then the green light would blink 5 times. I called their customer service team and was told it was the bulb. They wanted $399.00 for a new lamp replacement. I found the replacement bulb for $100.00 and replaced the bulb. The TV seemed to work okay for a while afterward, but now it's beginning to shut off in the middle of watching the tv. We noticed if we had it on for a few hours in the morning, then shut if off during the day, we wouldn't be able to watch tv again for a while. So, we usually dealt with that. But now, it's to where we turn it on and it shuts off again in less than 2 hours. We know it's not the bulb because when we turn it on the next day, the colors are still there...We have it quite a ways from the wall, but it still seems to overheat?? I can't quite figure out what to do, other than buy a new tv, but that can be so expensive. Any suggestions?? Thanks!
  • tjdavis84701 Jan 07, 2009
    Thanks for the help -- Though I am states away from him. He's in Austin and I am in Utah... Don't think he'd make a house call to me that far away. Sounds like this guy really knows what he's doing... I may try and call him, perhaps he knows someone in my area that may be able to help.
    Thanks for trying.
    Problem Solver:
  • 8 Answers
I just fix this problem easily.
go to austincitysearch.com. Review for Dean TV
Posted on Jan 07, 2009
I heard a "pop".
HD50LPW62 is Not projection,Projection TVs have 3 Tubes R/G/B.
Your TV is DLP which has Lamp and Color wheel, Ballast board, Lamp Fan.
You need to Check the Lamp,You will need to remove the back in order to see the Lamp.
Lamps are easy to replace.
Mats Electronics has Lamps 1-800-628-1118
Jul 21, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a rca m50wh72s dlp tv was watching the tv one day and then herd a loud pop noise and the tv went black i try to turn it on it makes a funny rubbing noise like plastic on plastic and then the power...
Sounds like the color wheel or lamp I would check the lamp first to insure thats its not broken as they can make a pop when they fail sometime (Breaking) then I would check the color wheel you will be able to tell if the color wheel arear has the noise coming from it. If you need more assistance let me know.
Jun 13, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hi, I'm looking for supplier> 1 projection lamp
50DSZ644 is an LCD Flat Panel TV, there is no replacement lamp. Here is a link to RCA TV Lamps and associated model numbers.
easyab@hotmail.com
Feb 10, 2011 | Thomson 50DSZ644 50" DLP Rear Projection...
TV model number is M61WH745 it keeps blowing the blube this will be the 4th one in 5 years
first the correct model # is M61wh74s.
there are two differnet lamps that may have been installed at the time of manufacture. you should remove the lamp access door and use the lamp part # printed on the label pasted to the inside of the access door. To use any other or a sub (which are only good for about a year) will down grade the brill of the picture and cause undue load on the ballast (supply cirucit for the lamp). Additionally if you are in an area that experiences frequent brown outs (power reduction to the home) I strongly suggest using a UPS (uninterruptable power supply) to power your DLP TV.
Jan 02, 2011 | RCA Televison & Video
The picture is not bright in a light-filled room. Will a change of DLP lamp help? Are there different lamps that will improve picture quality?
Yes.Depend how old is ur DLP tv,the Projection Lamp only a light source,mostly depended on the Light projection Engine itself.Get the original RCA DLP lamp or same lamp model now inside the tv,will help and work best for ur tv.Just don't get generic DLP tvs lamp,it cheaper poorer quality.
Dec 17, 2010 | RCA HD61LPW167 61" HDTV
Please Help. I have a 56" DLP Samsung and the lights just flash
Sounds like the lamp might be burned out. The Lamp should be replaced every couple years. If they are not replaced they will eventually burn out. Replacement is not that difficult and just requires a screwdriver. The lamp is located at the back of the DLP TV on the left side. The lamp can be purchased online from Samsung for about $130 dollars. You might be able to find a aftermarket one for less. Just use your telivision's model number located on the right side of the TV on sticker to cross reference the bulb that is needed or there might be a sticker on the back at the lamp housing that has the lamp part number. And make sure to spend the extra money and get the Lamp with the housing together. You can buy just the lamp for cheaper but that will require you to remove the old lamp from the housing and they are fragile. Much easier installation with the housing/lamp combo.
Jan 12, 2010 | Samsung DLP HL-P5663W 56" TV
No picture good sound good lamp can change channel
I have the exact same TV and have had the exact same problem. I talked to a TV repairman who said it has to be my deflection board. I just found this out today so I am looking all over the web for a deflection board. I hope this helps! Tyson
May 31, 2009 | RCA M50WH185 Television
RCA Scenium DLP
Usually that is an indication of a bad lamp. A lamp can be ordered and replaced yourself. Use the model number of the television to order the correct lamp.
Jan 30, 2009 | Televison & Video
Make sure the tv is at least a foot away from the wall so it can circulate air and keep the bulb cool. Try to avoid turning it on and off multiply times in a short period of time.
Oct 07, 2008 | Televison & Video
RCA 50" dlp lamp dead?
There are many different problems with RCA televisions. One could be a color wheel. Another could be a bad ballast. www.Lamp-Replacement.com has a guide and solutions for your RCA lamp 265866 or 270414. The problem is most likely a bad ballast, which is supposed to pre-charge your lamp and ignite it. If you aren't even getting to that stage, you can trace the problem to another component or power supply.
Sep 01, 2007 | Televison & Video
RCA HD50LPW175 50" HDTV Logo
281 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
