Question about Blodgett 911-DOUBLE Gas Oven
Blodgett Oven won't light
I have a model no dfg-100-3 with new gas valve, temp probe, etc. Some times it will not light untill you blow on the pilot a little any ideas?
  • 520 Answers
You are improving the voltage across the flame sensor . it probably is just short of being in range, failure to meet the proper micro amps the sensor produces will cause lock out and no ignition. sometimes you can simply adjust the sensor to hit flame better and it will work much better...
Posted on Jul 02, 2009
    Scholar:
  • 192 Answers
Go here,find what you seek. Great Co.
BLODGETT
44 Lakeside Avenue, Burlington, VT USA 05401
Toll Free: (800) 331-5842 Phone: (802) 860-3700 Fax: (802) 864-0183
Posted on Apr 24, 2009
Dfg100 oven will light , get to temp, shuts off but wont light by itself again
to confirm check the Ohm draw on the temperature probe, i am not sure what is the correct one but you can check online at blodgett if probe okie then you will have an issue with the temp controller there possible the potentionmeter is worn out.....good luck
Apr 16, 2014 | Blodgett DFG-100 Gas Single Oven
Blodgett DFG-XCEL spark but no flame
You need at least 24 volts for the gas valve to open
Jan 21, 2014 | Blodgett DFG-100 Gas Single Oven
My oven is gas and has an automatic pilot...but there is no spark ,,,,I can smell a little gas but no ignition
I suspect your silicone carbide ignitor is weak.
I have a nice video on my blog cover page HERE on silicone carbide ignition.
You can get parts, and service manuals for your machine HERE
Feb 21, 2011 | Blodgett DFG-100 Gas Single Oven
Oven is very sporaditic, will heat up get to temp , go to load mode then shut off. Sometime after an hour or two sometime after 15 minutes
Your pilot light is probably blowing out. If you follow the pilot light gas line from the pilot flame back to the main valve, you will see a screw about the size of a pencil in diameter. If you take that screw out, there is another screw down in the hole you just uncovered. You have to have a very small screwdriver to reach that screw. If you turn the little screw counterclockwise, the pilot light flame will get bigger. A lot of times this will help. If you have a drafty location, the pilot will get blown out and that shuts the main gas valve off.
Sep 22, 2010 | Blodgett DFG-100 Gas Single Oven
Gas smell at start up
Be sure that the igniter has a good ground. I mean make sure you clean it well. Be sure its fastened well. And of course that it is close enough to burner. Air flow in building can also hinder lighting.
Nov 14, 2007 | Blodgett DFG-100 Gas Single Oven
Main Burner not lighting
This is caused by a faulty pilot safty valve. it will be the tee looking valve with the red dime sized button in the middle.
Hope this helps You
please rate me
Oct 18, 2007 | Blodgett DFG-100 Gas Single Oven
Blodgett 911-DOUBLE Gas Oven Logo
654 people viewed this question
Top Blodgett Ovens Experts
Dennis Boxerman
Dan Webster
Dan Webster
butch welch
Are you a Blodgett Oven Expert? Answer questions, earn points and help others
