Got problem on my local area connection, i couldnt connect to internet
  • s_wasiak May 11, 2010
    Are you using cables or via wi-fi cos you are about to create small home network.If wi-fi for all computers it is going to be easy but if cables let me know and I will tell you step by step.It is not so easy
  • 66 Answers
If you are connecting to internet through network internet server try to check you IP address usually 101.0.0.0.1 be sure that it would not be conflicted to the other pc who are connected to the server. (Open(right click) My Network Places then click properties then right clikc the Local Area Connection at General Tab click TCP/IP then click properties then configure the IP address and the DNS Server of your pc.
Posted on Jan 06, 2009
My i pod is connect to my wi fi but will not connect to internet
Wifi allows connectivity for device to device as local area networks. Where connecting the ipod to the computer is a local area network. Also, the computer can use wifi to capture worl wide web connectivity of the internet. The computer requires to have subscription to an internet provider server to make wifi make full capacity observeble beyond device to devcie captures. It is possible to have local and networking across distance with the the wifi.
Feb 08, 2011 | Computers & Internet
Wired nor wireless connections for my ps3 wont work
if you setup your wireless in adhoc mode like useing the pc wirless it wont work because ps3 doesnt see adhoc wireless.
and for the ethernet connection is the pc setup right. you have to enable internet sharing on the accuall interface that has internet..
If local area connection 1 is connected to internet and local area connection 2 is plugged into ps3 then under local area connection 1 settings you have to set share this connection and in the drop down menu select local area connection 2. other than that you need to buy a router.
Sep 20, 2009 | Sony Playstation 3 (PS3) Console
Internet Won't Connect
Press Start->Connect To -->Show all connections.
If the Local Area Connection icon is crossed with a red X, right click it and choose (Enable, or Repair).
If there is no Local Area Connection icon, you must create a connection.
In the left panel in Network Connection window click create new connection.
1.The wizard pops up
2.Click Next.
3.Put a (dot)mark in Connect to the Internet .
4.Click Next
5.Choose Set up my connection manually
6.Click Next Choose the type of connection you have with you ISPN (dial up, etc.)
7. Click Next , and follow the instruction from here.
Hope it helps you find your way to a solution
Aug 30, 2009 | E-Machines Computers & Internet
What is a local Area connection? My laptop doesn't work, but my desktop does?
Local area connection is the wired network interface card on the computer. On a laptop you'll see the port on the side or back. If you have a internet cable conencted to the port you'll be able to access internet on a wired conenction. Most likely you are conencted wirelessly on the laptop so it shows the local area connection disconnected.
Jul 28, 2009 | Computers & Internet
My internet explorer is not open while the local area connected
try cleaning internet history and run any program to clean computer from internet usage.if worst comes to worst try a system restore. hope it helps
Jun 11, 2009 | Compaq Deskpro EP PIII-650MHz/ 128MB/...
Cannot find local area connection to access internet
IF YOU HAVE A ICON OF A COMPUTER AT THE BOTTOM OF THE SCREEN IN THE BOTTOM BAR CLICK IT AND YOU SHOULD KNOW WHERE TO GO FROM THERE
Dec 22, 2008 | WiFlyer - Portable, shareable WiFi base...
Can not connect to internet
what connection you use? a dial up or broadband acces?
if u use a broadband acces (maybe from office) u need to fill in gateway and preffered dns that your office use.( u can see the number from another computer)
You can find the setting in : control panel--->Networks Connection--->Local Area Network
- Right click on Local Area Network, choose 'Properties' ----> Internet Protocols(TCP/IP)
Thanks
Nov 06, 2008 | HP Pavilion dv6000z Notebook
If it says that your local area connection is unplugged then you cant have a cable plugged into the ethernet socket on your pc into a router or there is a break in the cable.
Feb 10, 2008 | NetGear WGT624 Wireless Router
Computers & Internet Logo
David Payne
David Payne
