Question about SanDisk Sansa e250 MP3 Player
My Sandisk shuts down on me
My sandisk keeps shutting down on me when ever i want to play my songs it just freezes then goes to the goodbye background but then comes back on i dont no what to do
Go to your menu screen by briefly pressing the power on button. Then hold the power button while in the menu. This will re-start the player and it should fix your problem. If this doesn't work, contact technichal support. =)
Posted on Apr 16, 2007
Song screwups Sansa c250
You can try to reset the device by pressing the power button for about 15 to 20 seconds..if that doesnt work I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Nov 11, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Freeze on goodbye - Sansa e250
make sure to turn off hold/lock
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Oct 22, 2008 | SanDisk Sansa e250 MP3 Player
Freezes, then Shuts Off
-Tha Mp3 Doctor
May 24, 2008 | SanDisk Sansa e250 MP3 Player
Sansa shutting off during song
this is normal for this player - it goes to sleep fairly quickly - se p.35 of manual to see how to change frequency of shut off
Apr 18, 2008 | SanDisk Sansa e260 MP3 Player
Sandisk keeps skipping/freezing songs!
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
-Tha Mp3 Doctor
Apr 13, 2008 | SanDisk Sansa E280 MP3 Player
Refresh data base freezes
If your SanDisk is locking up try holding the power button down. It will force it to shut down. If you continue to get that error you probalby need to update/reload the firmware. Check out the sandisk.com website. Go to the music and video link and then select forums under support. If memory serves me correctly I had to download the file to my PC and then copy it to my Sandisk to get it to load. I lost all my songs but it fixed the problem.
Dec 19, 2007 | SanDisk Sansa e250 MP3 Player
Certain songs wong work
get a refund. It needs to be relicened on the net
Nov 09, 2007 | SanDisk Sansa e260 MP3 Player
Sansa c140 screen frozen
Try a "hard reset". Press and hold the power button for 15 seconds to shut off. With the device off, press and hold the vol + and the center select button. Power it back on, see if that works. You can add to the question if you have more questions. Best of Luck.
Sep 27, 2007 | SanDisk Sansa c140 MP3 Player
Help! my sansa is randomly shutting down!
-Tha Mp3 Doctor
Aug 07, 2007 | SanDisk Sansa e200 MP3 Player
Frozen MP3
For Sansa or Sandisk problems, contact http://www.sansacommunity.com/ This site is dedicated to Sandisk products and can help you. Good Luck
May 12, 2007 | SanDisk Sansa c140 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
