Question about Brother DCP 115C All-In-One InkJet Printer
Nothing on display on dcp-115c
When power is connected the red ! lights up and the printer bleeps twice while "photo capture" blinks twice too, and then the printer stays dead. nothing on the display, only the red ! lights up. already tried to disconnect power and connect again while pressing "menu" but same result.
Mix-it-up
  • 832 Answers
SOURCE: brother dcp 115c : print head clogged (Red & Black not printing).
read the whole (!!!) post here:
http://www.fixya.com/support/t224245-missing_dot_in_all_colors
Its the same issue.
Posted on Oct 18, 2007
Mix-it-up
  • 832 Answers
SOURCE: I cant to move my DCP-115 to the maintanance mode
First button is MENU then start b/k copy then 4x arrow-up....
Posted on Mar 01, 2008
Mix-it-up
  • 832 Answers
SOURCE: Brother DCP-115C unable to clean
you need a new waist ink absorber box from a service partner which can be found at brother homepage of you country.
After replacing the box you have to do a reset.
search error 46 or unable to clean here in the forum. it has been written many times.
Posted on May 05, 2008
SOURCE: New HL-5240 printer red status light upon powering up
My HL-5240 did the same thing, Here is what I found:
Look at the back of the printer. Pull down the back cover. Look to the right and the left of the exposed internals of the printer and there should be another handle/knob you can pull down. Pull these both down simultaneously and check to make sure there isn't a piece of paper in there! This was a shock to me! My office printer was held up for days until I found this hidden door in the back! I felt like an idiot that it was from a stupid paper jam!
Posted on Sep 05, 2008
SOURCE: Printer unable to clean
the printer has a counter for the supposed amount of ink the absorber pad can absorb.
i have reset the counter using the following and now it works. In theory you need to get a replacement pad but i haven't been able to find one yet. My printer is now working fine
following is the solution to reset the counter for the old fault
> Brother DCP110c Reset Counter
> 1. unplug at side of unit, switch on while pressin menu2. Enter 8 press
> set enter 0 press set
> " by using the up arrow key & SET keys."
> 3. press the mono start key several times untill the purge count appears
> on the LCD.
> 4. enter 2 7 8 & 3 by using the up arrow key & set keys to reset the
> purge count to zero (like in 1)
> 5. press the stop/exit key to return to the initial stage of the
> maintanance mode.
> 6. enter 9 twice by using the up arrow & set key’s to exit from
> maintenance mode
Michael
Posted on Mar 09, 2009
Brother DCP-115C printer unable to init.
Here's what the manual states in the troubleshooting section:
Unable to Change
Unable to Clean
Unable to Init
Unable to Print
Unable to Scan
The machine has a mechanical problem.
-OR-
A foreign obstacle such as a clip or ripped
paper is in the machine.
Open the scanner cover and remove
any foreign obstacles inside the
machine. If the error message
continues, disconnect the machine
from the power source for several
minutes then reconnect it.
Check the Brother website here:
http://welcome.solutions.brother.com/BSC/public/eu/gb/en/faq/faq/000000/000500/000065/faq000565_001.html?reg=eu&c=gb&lang=en&prod=dcp115c_eu_as&Cat=11
Sep 02, 2012 | Brother DCP 115C All-In-One InkJet Printer
Tip
DCP-340CW MACHINE ERROR 46 the Photo Capture and red exclamation mark lights...
Clean the ink overflow pads you will have to almost take the printer to bits, they are underneath the print head dock position, these cost about £25
In the mean time you can RESET this purge count back to zero using theMAINTENANCE 80 menu, to continue using the printer for a while untilyou get the new pads. But it on a tray as if they are full they maystart to leak onto your desk....
1 . Press (MENU) (MONO START)then (^) OR <the up arrow> four times, the Photo Capture and RedExclamation Lights will then flash.
2. Press (^) eight times until you see <8> then press (SET)
3. Press (^) twice until you see <0> then press (SET)
You will now be in MAINTENANCE 80.
4.Press the (MONO START) its a toggle until you see PURGE:6451 ( I guessthis means you have cleaned the heads over 6,450 times their thresholdlevel.) you will need to enter the code <2783> to RESET it.
5. Press (^) twice until you see < 2 > then press (SET)
5. Press (^) eight times until you see < 7 > then press (SET)
5. Press (^) nine times until you see < 8 > then press (SET)
5. Press (^) four times until you see < 3 > then press (SET)
The Printer will beep then reset counter will be at ZERO <0000000>
Its the PURGE that will increment by a variable amount each time youclean the print heads the amount will be between 100 and 130. When thiscount gets to about 64,000 the error 46 will occur. That's about 510times you can clean the heads before the pads need cleaning.
Almost forget to EXIT the Maintenance mode enter 9 twice by using theup arrow & set key's to exit from maintenance mode in the same wayas entering the 2783 code, or power down the printer.
on Feb 06, 2010 | Brother DCP-340CW All-In-One InkJet...
Red will not print after cleaning several times
There may be a problem with the printer's mechanism, electronics, or even the software. You should probably contact the company, and explain the situation. Presuming you have an internet connection, they may be able to correct the software via your computer, over the internet. You'll just have to allow the company access to your machine.
Oct 22, 2009 | Brother DCP 115C All-In-One InkJet Printer
My DCP-115C printer was missing red colour.
Yellow is one of the colours used to produce a shade of red.
I don't know how but ther must be a way to print a test page to see if the print heads need cleaning I've never used a brother.
Sep 26, 2009 | Brother DCP 115C All-In-One InkJet Printer
DCP-340CW purge counter reset
n the mean time you can RESET this purge count back to zero using the MAINTENANCE 80 menu, to continue using the printer for a while until you get the new pads. But it on a tray as if they are full they may start to leak onto your desk....
1 . Press (MENU) (MONO START) then (^) OR <the up arrow> four times, the Photo Capture and Red Exclamation Lights will then flash.
4. Press the (MONO START) its a toggle until you see PURGE:6451 ( I guess this means you have cleaned the heads over 6,450 times their threshold level.) you will need to enter the code <2783> to RESET it.
Its the PURGE that will increment by a variable amount each time you clean the print heads the amount will be between 100 and 130. When this count gets to about 64,000 the error 46 will occur. That's about 510 times you can clean the heads before the pads need cleaning.
Almost forget to EXIT the Maintenance mode enter 9 twice by using the up arrow & set key's to exit from maintenance mode in the same way as entering the 2783 code, or power down the printer.
LOL
Check me out at www.windowstipsclub.co.uk
May 04, 2009 | Brother DCP-340CW All-In-One InkJet...
Brother dcp 150c problem
dear sir/maddam
i have printer Brother type DCP 150 C,
Now in the display show ERROR MC 48-49,
we can not sovling this problem,
please advice
Feb 10, 2009 | Brother DCP 115C All-In-One InkJet Printer
Paper jam
see here how to open your dcp (same procedure as the mfc215):
http://www.hstt.net/refill-faq/inside.html#Brother_mfc215c
The flashing of lights means that you are in the maintenance mode.
Apr 18, 2008 | Brother DCP 115C All-In-One InkJet Printer
My printer have problem
you need a new waist ink absorber box.
Search this forum for error 46 or unable to clean. the procedure is explained many times (identical for all brother inkjets)
Apr 17, 2008 | Brother DCP 115C All-In-One InkJet Printer
The error messageunable to init
you have to replace the print head.
But to be honest: its cheaper to buy a new dcp 135c or 130c with warranty and new carts incl.....
Mar 12, 2008 | Brother DCP 115C All-In-One InkJet Printer
Brother dcp-115c printert
Take all carts out. Close cover. Wait a minute. Unplug machine from power. Wait a minute. Plug machine to power again. Machine demands carts. Insert carts as demanded by display.Set date and time.
Nov 05, 2007 | Brother DCP 115C All-In-One InkJet Printer
Brother DCP 115C All-In-One InkJet Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
