Question about Plumbing
Twist Knob on bath will not move so bath plug will not release
To empty bath. I did prise up plug to empty but need to be able to resolve to fill/empty bath more easily.
  • christine573 Dec 15, 2008
    Yes there is a chrome twisting knob on the bath which you twist to raise and lower the plug in the tub to empty or fill bath.
  • Roscoe007 May 11, 2010
    Does it have a chrome looking plug , if so these were designed to pop-up , to drain your tub.Let me know.
  • 101 Answers
If its still not working these units unscrew, sometimes there not easy to remove... how old is this bathtub? or when was the drain last replaced? I'll wait to here from you!
Please remember to leave me a Fixya rating if Ive Helped !
Posted on Dec 16, 2008
How do I empty the canister? The red release button seems to be stuck.
Hi Julie, it's Jack at Dyson.
I'm glad to hear you've been able to resolve the issue and empty your DC44's clear bin. For reference, the correct way to empty the machine after use is shown in our official Getting started video guide.
If you'd like advice from our experts at any point, you can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
May 14, 2014 | Dyson DC44 Animal Cordless Vacuum
Release stop motion knob won't move
What are you calling a stop motion knob? Are you trying to stop the needle from moving while winding a bobbin?
Jan 31, 2014 | White Sewing White 3032
The air switch on my whirlpool tub will not toggle, i must hold the button in to keep motor running.
What you are experiencing when you push the Air Button down and it engages the BATH PUMP but when you release the the Air Button is a bad Air Switch in the BATH PUMP.
When you push the air button down it sends a column of air to move a small switch in the BATH PUMP. When the switch in the BATH PUMP is bad it will not engage.
What you need is a new Air Switch model TBS-339.
Rod
US Parts Center
888-521-6183
Feb 28, 2013 | Home
Delonghi air conditioner it has a triangle with an exclamation point inside. What does this mean?
There is a knob on the back and bottom of the air conditioner. Twist off the knob and unplug the little black plug and empty the water into a container. I had the same problem and this worked for me.
Jul 17, 2012 | DeLonghi PAC W130 Portable Air Conditioner
Sunbeam multiprocessor model lc6200 runs full speed all the time
As other contributes have said, remove all the screws from the base, the spindle can be released by caerfuly prising out the small plastic clip halfway up the spindle, it will slide easily off and the large spindle drive wheel can be removed. Push the control knob out from behind, the knob and e surround come out as one unit. Remove the accessories holder and remove the two screws holding the top cover on. Now turn the unit the right wat up to start to release the top. Carefully prise the top cover off, there are two plastic clips at the front. Now you have exposed the top of the unit and the safety switch actuator. Remove the screws, the hardest job is to release the actuator rocker arm. I could not release the pivot support, so took the rocker off the pivot. Now you should be able to lift the cover off the motor and Access the control board. There are two screw holding the control assembly in place and two which hold the circuit board to the switch. Replace the Triac and diac then reassemble.
May 21, 2012 | Food Processors
The valve (the little knob) on my blood pressure cuff is stuck. How can I enable it to move again? It won't budge either direction.
Hi
You don't give the brand and model number of your Blood Pressure Monitor.
Turn the device so the knob is pointing sideways, 90 degrees to the floor > drip a tiny drop of olive or vegetable oil near the screw thread > turn the device up so the knob is pointing towards the ceiling > wait for 5 minutes > use a cotton cloth to grip and twist the knob.
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it.
This helps Answerers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can.
If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Sep 06, 2011 | Health & Beauty
How do i change bulb in air conditioner panel ny my 2001 jetta
Behind the center knob for the heater controls there is a single small bulb that lights the whole heater control.
Move the switch to the vertical position, move the gear shift out of the way(shift to D or 1 with engine off, and set the parking brake). Use a pair of pliers with a rag to protect the knob and pull the center knob out. The bulb is directly behind it. The best way to remove and replace the bulb is with a piece of rubber vacuum hose. Gently push the hose over the bulb, then pull, the bulb should come out stuck in the hose.
You can install the same way, push the bulb in, then gently pull and twist the hose to release.
Be careful to align the bulb to its socket. If the knob is vertical the taper of the bulb base should also be vertical.
Then just push the knob back on, remembering that it is aligned to a vertical position
Jan 09, 2011 | 2005 Volkswagen Jetta
Hi my name is eddie the heater blower little lights on the dash have gone out and my mirror light has gone out to
Then just push the knob back on, remembering that it is aligned to a vertical position.
Need more info on the mirror light. You mean the light in the mirror switch?
Jan 06, 2011 | 2002 Volkswagen Passat
Remove the shift knob in a 1999 dodge dakota
The shift knob on a manual trans should twist off. Sometimes it takes a bunch of force. Are you replacing the knob? Then channel locks will work fine.
Mar 05, 2009 | 2001 Dodge Dakota
Belt
Remove sole plate and beater bar.
Remove control knob by prising between yellow plastic side of knob and casing using wide bladed screwdriver.
There three torx headed screws holding the clotch assembly in place. Two are visible but the third is accessed via a circular access holein the main casing.
When these three screws are removed the clutch assembly can be pulled out. the thinner belt driven by the motor needs easing over the motor shaft.
There are two screws holding the end plate onto the clutch assembly. remove these, twist the end plate and remove. note where the fibre clutch plate and the metal plate fit and replace this belt.
On opposite end prise off spring washer and this assembly comes off the reveal the belt.
Refitting is the reverse.
Have a look on you tube and type in replacing clutch on Dyson DC4 as there is a 10 minute vidio that is quite good!!
Hope this helps!!!!!
Dec 12, 2007 | Vacuums
Plumbing Logo
508 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
