Question about Sylvania 6719DC 19 in. TV/VCR/DVD Combo
My tv turns off after I turn in on
When i turn on the tv it is normal but a couple secounds later it turns off by itself . How do i fix it?
  • Anonymous May 03, 2009
    Hi, I had this same problem. You might want to save yourself some money and open the tv up yourself. Obviously make sure its not plugged in while doing so and look for anything really obvious out of place or loose parts that dont look right. I found a piece of a VHS tape stuck in the VCR and it might sound crazy but I no longer have this problem. Give it a try if not it might be time to get a new tv. GOOD LUCK!!
    Problem Solver:
  • 6 Answers
The problem under the vcr loading mechanism. You need to replace the clear led in center of board.
Posted on Jun 03, 2009
TV would shut off by itself and then several minutes later be able to be turned back on. A day later it shut off by itself, turned itself back on, shut its self off then a huge pop sound as purple and...
That tv is very old and it just reached its life expectancy. It could be repaired but it will cost you more than a brand new tv. Black Friday coming up and you will find a great deal.
Oct 29, 2013 | RCA HD52W59 HDTV Projection Television
GE TV Model 35GT695 - Problem Turning TV ON
Sounds like a solder problem. Look over the circuit board real good ffor cracked solder joints especially near the flyback and your Horizontal output and regulator transisitors. Could also be a defective capacitor look for signs of bulging or leaking capacitors.
Jan 15, 2008 | Televison & Video
I had the TV on earlier tonight. Turned it off. No problems. I turned it back on a couple of hours later and it started OK .. normal sounds of the tube 'kicking in'. I had volume, and then the entire...
Try a different source on the tv to see if the tv is toast. Ten years is quite old and tvs have come on a long way since this one. Alternatively try a different tv on the cable box.
May 03, 2011 | Panasonic CT-36SX31 36" TV
I have a acer aspire T135 and when I turn it on to boot I get the red and green light with a loud whirring noise from the cpu anyone know what is happening and how can i fix it please
sounds like the cpu fan and that would also explane the green then red lights also open the tower access panel but first unplug the unit,wait 30 secounds or so plug the tower back in then look at the fan sitting on the motherboard or main processer see if it turns on and make sure it keeps running they tend to start then if there is a problem they eigther don't turn on at all or turn off a few secounds later Im thinking later would explane the lights
Dec 17, 2010 | Acer Aspire T135 PC Desktop
Model number DP50747 The tv just turned off by itself. When you turn it on there is no sound or picture just a black screen. Only had this tv about 1 year. Can you help me?
I had the same problem with my sanyo tv a couple weeks ago, I took it to the repair shop, turned out it was a bad diode. $60.00 later I could watch my tv. I don't know if this helps, but I strongly suggest taking it to a repair place rather than trying to fix it yourself.
Sep 04, 2010 | Sanyo Televison & Video
TV won't stay on
One of two things can be the problem...one the bulb is bad...two the ballast is bad. If the bulb is not bad then the ballast is...it can usually be fixed by replacing a resistor on the board itself...it is labeled R3 and is a 1000 ohm resistor
Jul 25, 2010 | Toshiba TheaterWide 46HM84 46" Rear...
Sceptre X32GV-Komodo keeps turning on and off
I replaced my own part and it works as new again .Go to ( Power-On.com )Look up part #LCD225-6M Power supply it only cost $65.00 and ups shipping was $10.46 2 day later I got it and 15 mim. later we were watching TV again
Mar 15, 2009 | Sceptre X32GV-Komodo 32 in. LCD Television
RCA Colortrak plus. Model# F32672SB Serial # 807560570 Chassis # CTC187CJ3 Manufacture Date Feb 1998 Service # F32672SBFM3 4/21/08- TV worked fine last night. This morning worked for about an hour. ...
It's probably a cracked solder joint in the power supply / horizonal drive stages. As the unit heats up the joint is seperating and breaking connection. It could also be a component failing when it gets hot. Usually the voltage regulator or Horizonal Output Transistor (both mount to heat sinks).
If you know how to solder and want to tinker, unplug the set for a couple days (to let the power capacitors discharge) and resolder and crystalized it cracked joints on the board(s) where the power stages, and flyback transformer are located.
If you decide to operate the set with the back off, please be careful. The high voltage on a TV can be 30,000+ volts.
Hope that helps,
Geno
Apr 21, 2008 | Televison & Video
T.V. TURNING OFF AFTER ABOUT 5 MINUTES.
Go to Samsung.com for solution. There is a switch that just needs to be repositioned behind access door on rear. Fixed my HL-S5086W ok.
Feb 13, 2008 | Samsung HL-S5086W 50" HDTV
Tv keeps turning itself off
you must contact service bycouse you need the asistance
May 25, 2007 | Toshiba MD20F51 20 in. TV/DVD Combo
Sylvania 6719DC 19 in. TV/VCR/DVD Combo Logo
214 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
