When i put a dvd in to watch it i can play it and everything but i cant hear anything and i checked all the sound settings and everything seems to be at the same level and nothing is muted?
  • procuber Dec 16, 2008
    i dont really know how to check software settings i just thought that if i put in a dvd it would play. It comes up with windows media player and i can play the dvd but no sound is heard. i have an Acer Aspire 6530 laptop so the wires would be nothing but it has the dobly home theater surround sound and i dont know if it has something to do with that?
  • Mike Demaris May 11, 2010
    Have you checked your DVD software's settings? What software are you using?
    Have you checked your pc for loose or disconnected wires from/to your DVD drive?
  • 30 Answers
Yeah like what drwarpo said, it might either be the volume level on windows media, or the fact that you don't have the right plugins for the dvd maybe... try "www.wmplugins.com" (minus quotes) and search for "avi", also you should download "divx", just google it, every computer should have divx
Posted on Mar 13, 2009
  • 111 Answers
If you are using windows media player that is a common problem with some dvds use nero or a different program as ms does not have plugins for all variations in dvds
Posted on Dec 21, 2008
I have a JVC HD 52g787, the sound works but no picture, The tv comes on, but the blue light just blinks, then cuts off, I have sound no picture
The problem is usually from the power or the Y sustain at the left or right side of the display when one of the large capacitor or heat sync on the capacitor even the flat power cable connection it to a main power board needs to be checked too, if the fuses on the board are blown it will need to be replaced
But after replacingthe fuses and the capacitors and still no solution,youwill need to replace the all board ..
You can also trouble shoot first before going to the board of the TV..
How to Troubleshoot an LCD With Sound But No Picture
It can be overwhelmingly frustrating when an electronic device as expensive as an LCD television set starts having problems. Luckily many of these problems are easily troubleshot. While being able to hear sound coming from your LCD television but seeing no picture may seem serious on the surface, fixing the problem involves checking a few different settings to make sure everything is set properly
Instructions
Check the video connection of any devices plugged into the LCD television. If you can hear sound but are seeing no picture while trying to use something like a DVD player or cable box, the problem is probably that a wire is loose somewhere. Check the yellow video cables running from the DVD player to the TV and make sure everything is plugged in firmly and where it should be. Also check the coaxial cable running from the cable box (or cable outlet) to the television and make sure that wire is also screwed in securely.
Check the image settings on your television and make sure everything is set properly. Certain settings like "Picture" or "Brightness," if set to one extreme, can make the picture appear completely black. This could cause you to simply hear television shows but not be able to see them. Reset all picture settings on the TV to their original factory default settings to see if that fixes the problem.
Try another channel. If you're watching TV and not getting a picture, the first thing you should do is check a variety of random channels to make sure it is a problem with your TV and not with your television signal. If it is a problem with the television signal it is the fault of the TV station or cable service provider and there isn't anything you can do yourself to fix it.
Try the DVD on another DVD player. If you're trying to play a DVD and can't see any images, make sure the disc isn't defective. Try it on another DVD player or a computer DVD drive and make sure the disc works in the first place.
Hope it helped ..
Jul 17, 2011 | JVC HD-52G886 52" Rear Projection HDTV
Dvd conection
Check the settings on the dvd it may be set for headset only or audio off. Have u tried putting in headphones to see if you can hear anything?
Jul 11, 2010 | XO Vision XOD1735 Car DVD Player
Centre speaker no sound. I can hear the surrounding sounds but no dialogs! checked connections and speakers: everything seems ok. Reset to factory settings, still same prob. I think the centre channelk is...
Well, maybe the center speaker is burned.Can you hear any sound from the middle speaker !?
If you can't hear anything from it, replace the speaker with the new ones.
If you can hear a minor sound or scratch, then the sound board inside the tv set is damaged.
Dec 09, 2009 | Televison & Video
My DVD Picture isn't coming. I only hear sound.
Hi qfabsar,
I think you are missing the dvd video codec required by windows media player to play dvds. You could do a search on the net for the missing codec or copy and paste the link below then install ffdshow. This includes codecs for other audio and video filetypes. Always check for viruses and spyware when downloading anything from the net.
http://register.sonicdownloads.net/download/index.aspx?sx=b807beb4-bd67-4e7b-b03e-ea0705bdb7e4
Hope this helps.
Mark.
Apr 12, 2009 | IBM Computers & Internet
Cant hear songs
It sounds like your headphone/hold cable is faulty. Try plugging it into a sound device with a docking bay. If no sound comes out of there either then it's a faulty logic board.
Nov 19, 2008 | Apple iPod MA446LL/A MP3 Player
I get a loud beep on my laptop but cant hear anything else
There is a beep system in all PC's
One quick been means the computer is OK when starting.
one long continuous beep is defined as :
' Power Supply or System Board / Keyboard stuck '
Note: Alternately it could be a Memory module
However it's more likely that it's the above
If you check those two things, you are likely to find the culprit.
If not, you need to post your BIOS and
Feb 20, 2008 | Dell Inspiron 2200 Notebook
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
