Question about HP PSC 2175 All-In-One InkJet Printer
Scaner failure, did not finich with initializing.
I had been trying to print . All it does is click when power is turned on and then has clicking sound from scaner's carriage with notice: scaner failure. Printer does not work.
  • Anonymous Dec 18, 2008
    have the exact same problem. nothing seems to fix it.
  • nilserb Dec 22, 2008
    exact same. brought it into computer shop to get it fixed. it did'nt do it there so I took it home again. Iut was finee for another 6 months and its gone again this morning
Unplug
Press cancel and right arrow simultaneously. keep pressed as you re-plug and allow lights to flash. Bob is your uncle
Posted on Dec 22, 2008
0xc18a0206
Hi Richard,
There are few troubleshooting steps that you can perform to fix this issue. This issue is related to Printhead Failure ( that holds the cartridges )
1. Disconnect the Power cord from back of the printer ( printer must be power on when you do this )
2. Wait for 10 seconds and plug the cable to Printer
3. Wait for the printer screen to display the menu
4. Try to print test page.
Or Try the Step Below
This is easily fixed with the following key sequences. You do NOT have to open the printer and unplug a circuit board.
1) press * and # at the same time
2) press 1, 2, 3 and "support R0632M" should display
3) press > and "information menu" should display
4) press > and "configuration menu" should display
5) press OK and "hardware failure status" should display
6) press OK "failure status: clear". Press OK to clear
7) press CANCEL
8) press CANCEL
9) press CANCEL
10) turn printer off, unplug power cord for 2 minutes, plug cord back in then turn printer back on.
NOTE: I did this and the fist time the error came back. Do the sequence again (as I did) and the error will be replaced with the usual print cartridge initialization screens. Print a test page to make sure.
OR
Check this link as well for more detailed information -> Click here
Sep 17, 2012 | HEWLETT-PACKARD Photosmart D7460 InkJet...
My HP Photosmart C6280 asks me to replace the light blue ink cartridge and says it is unable to print until we replace the ink cartridge. We have replaced it three times and the same message appears. The...
Follow the below steps on the front panel of the All-in-One printer:
A. - Press and Hold the "Print Photos" & "Red Eye Removal" buttons. Release both buttons.
Display should say "Enter Special Key Combo"
B. - Press and release in sequence "Red Eye Removal", "Print Photos", "Red Eye Removal"
(try both and see which one will get you to system config menu )
display says "enter special key combo"
1. Press and release in sequence "Red Eye Removal", "Print Photos", "Red Eye Removal"
2. Press and release the right arrow button until the display says "System Configuration
Menu".
3. Press and release the "OK" button.
4. Display should say "Hardware failure status". If not there already, Arrow Key over to
5. Press and release the "OK" button
6. Display should say "Hardware failure status: Clear. Press OK to clear".
7. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared.
Press Cancel to continue".
8. Press and release the "CANCEL" button as many times as necessary, so that, either the
"Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears.
PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the
printer and wall outlet.
it is now powered down and unplugged.
10. Wait 30 seconds for the power to get discharged and then plug the power cable into the
wall outlet first and then into the back of the printer
11. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
12. If the printer has already initialized, then go to the next step. If not, the printer
will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do
not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
13. To verify printer functionality print a SELF TEST PAGE.
Aug 31, 2011 | HP Photosmart C6280 Printer
Why is my samsung clp making a clicking noise?
Is the printer making a clicking sound when it is printing? Or is it just making a clicking sound but there are no light and the printer appears to be dead except making a clicking sound?
I know of a cause for either case.
Case 1. It is clicking when printing. Sometimes the toner cartridges are not seated properly in the imaging unit, and causes the gear on the cartridge to slip making a clicking sound as the gear is being turned. Try pulling out the cartridges and try turning the gear. It should turn smoothly without binding. If it binds, there is not much you can do about it except replace it when it goes empty. Reinsert the cartridge and check that it inserted completely into the imaging unit.
Case 2. Printer is dead, not printing except making a clicking sound. This is due to the power supply board failure. Usually the failure is due to a blown filter capacitor on the power supply board. The power supply is located on the right side of the printer. Remove the right side panel to get access to the board. The board can be either repaired or replaced. Hope this helps you.
Feb 22, 2011 | Samsung CLP 300 Laser Printer
Printer won't print; says scanner only after
Follow these steps to resolve your problem..
Solution #1 Power cycle both devices (Printer & Computer)
  1. Turn off your printer.
  2. Unplug the power chord at the back of your printer.
  3. Completely shutdown your computer.
  4. Unplug / disconnect the USB cable at both ends (printer & computer)
  5. Wait for at least 1min.
  6. Plug the power cable back in to the printer make sure that the other end of the power cable is connected directly to the wall outlet.
  7. Turn on the printer.
  8. Check if you can make a copy, if yes proceed to the next step.
If not, and you are still hearing some unusual sounds on the printer go to the last step.
Solution # 2 Check if you can now print using your computer
  1. Plug the USB cable back in to the both ends (printer & computer)
  2. Download the Print diagnostic utility (click on Download below to download the tool)
  3. It will ask you to run or save it. (save it, so that you can use it on the next time that your having problem with printing issues)
  4. Run the software.
  5. Highlight your printer by clicking on it.
  6. Click on Diagnose.
  7. If you have to the FIX button available, click on it.
  8. After fixing the issues, restart button will appear. click on it.
  9. Check if you can now print.
DOWNLOAD (print diagnostic utility)
Solution #3 Call HP and have your printer trade in (last step) Call HP @ 1-800-474-6836, If the printer is no longer covered by the warranty charges may apply.
Feb 19, 2011 | HP PSC 2210xi All-In-One InkJet Printer
What does error oxc18a0106 mean?? I have replaced all the ink cartridges this afternoon and still won't print
error detecting ink volume and will need to be cleared by resetting your printer. here are the two ways to reset it.
Reset to default setting
1. While your printer is on, unplug to power cable from the printer.
2. Press and hold the "OK" and "HELP" buttons while you plug the power cable at the back of the printer.
Full reset
1. Press & hold " * " key...(asterisk sign)
2. While holding the " * ", press "#" key and then release both keys."Enter Special Key Combo" will be displayed.
3. Press "1", "2" and "3" to display Support.
4 Press ">" right arrow button and release when System Config Menu appear, then click OK
5. Press arrow key to display Hardware Failure Status, click OK.
6. When Hardware Failure Status:Clear appeared, press "OK" to clear.
7. Press "OK" again to display "Hardware Failure Status Cleared. Press Cancel To Continue".
8. Press "CANCEL" as many times to display "Welcome To Photosmart Express" or "Ink System Failure".
9. The last part is to turn off the printer and unplug at the back, wait for 30 sec, then plug and turn on the printer, if asked, press "OK" to continue and allow the "One Time Ink Initialization" to procede..After this try to print
Don't forget to rate this answer.
Thank you for using Fixya.
Sep 11, 2010 | HP Photosmart 3210 Printer
Error : Oxc 18a0206
here.. check this out. a solution to your problem.
These are reset instructions designed to clear most of hp errors starting with 0xc...It works on different hp models.. it could work on you too.
Semi reset
1. While your printer is on.. unplug to power cable from the printer.
2. Press and hold the "OK" and "HELP" buttons while you plug the power cable at the back of the printer. Try these steps to reset your printer to default setting.
Full reset
2. While holding the " * ", press "#" key and then release both keys..."Enter Special Key Combo" will be displayed...
3. Press "1", "2" and "3" to display Support...
4 Press ">" right arrow button and release when System Config Menu appear....then click OK
5. Press arrow key to display Hardware Failure Status...click OK....
6. When Hardware Failure Status:Clear appeared, press "OK" to clear...
7. Press "OK" again to display "Hardware Failure Status Cleared. Press Cancel To Continue".....
8. Press "CANCEL" as many times to display "Welcome To Photosmart Express" or "Ink System Failure".....
9. The last part is to turn off the printer and unplug at the back...wait for 30 sec, then plug and turn on the printer...if asked, press "OK" to continue and allow the "One Time Ink Initialization" to proceed..After this try to print...
If you find the reset solutions helpful...Please rate this solution and vote YES ..thanks..
Jul 30, 2010 | HP Photosmart 3210 Printer
When I am printer Hp 3210 Messe error like this 0xc18a0206
Semi reset
Full reset
Jun 07, 2010 | HP Photosmart 3210 Printer
Ink system failure. States ink system has failed, unable mto print. Error 0xc18a0201
Try the following tricks:
Press and hold the “left arrow” key.
Press the “Setup” key and release both keys.
Display should say “Enter Special Key Combo”
Press and release the “Ok” button Press and release the right arrow button until the display says “System Configuration Menu”.
Press and release the “Ok” button.
Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
Display should say “Hardware failure status: Clear.
Press Ok to clear”.
Press and release the “Ok” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
Press and release the “Cancel” button as many times as necessary, so that, either the “Welcome to
Photosmart Express” screen appears, or, the “Ink System Failure” screen appears.Please do not try to Print at this stage.
Using the Power Button, turn the unit Off and unplug the power cable from back of the printer and wall outlet.
Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer.
Turn the unit on. The printer may display message “Use only the power button to shut down the printer” followed
by “Press Ok to continue”. Press Ok. If the printer has already initialized, then go to the next step. If not, the printer will start the
“One time ink initialization process”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
To verify printer functionality print a Self Test Page. If Self Test prints, then printer is ready for use.
Good luck, Thanks for using FixYa.
Jun 03, 2010 | HP Photosmart C6280 Printer
HP C6180 won't align print cartridges
hi Alignment of ink cartridges is very essential for the for the printer to print so first of all be sure that you are using geniun ink cartridges now lets try a reset on your printer press the # and 3 button on your printer together and then unplug the power cord from your printer and keep pressing the buttons now wait for 5 sec and while pressing # and 3 replug the power cord wait for the printer to initialize and see if it prints alignment page if no page is printed then click on the start button of the computer and then go to printers and faxes and then right ckick on the icon of your printer and click on printing preferences now go to the features tab and click on the button that says align print cartridges wait for the alignment page to print and now try and see if it prints fine
Aug 26, 2009 | HP Officejet J5780 All-In-One InkJet...
Scan Error Message
Hey there Shawn. Your OJ 6110 has a scaner crash. You have to replace the scaner craddle at a Authorised HP Service.
Mar 28, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP PSC 2175 All-In-One InkJet Printer Logo
100 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
