Question about OTC EuroLine 4260 Matrix Printer
Custom size check printing using the OTC EuroLine 4260 Matrix Printer
Hi, i have a custom size check printing (8.05 inch 11.00 inch) to be done using the OTC EuroLine 4260 Matrix Printer but by default the printer is having some predifined paper sizes that it supports.. like A4, A3, Tabloid, Letter.. Iam able to add a custom paper size from printer server properties thru the printers & faxes tool under control panel. But even after adding this custom size form it does not show me in the printer page for making it as default. Now if i print the checks .. thru tractor feed .. the printer prints the first check properly then it skips to go the next page and starts printing on the third check that too half way thru it( that is it skips more than one and half check ) kindly guide me to solve this problem.. It is kin of urgent .. The printing is done from IE. thru a web application (.net) The check is basically Dynamically Generated HTML. more than a thousand pages... Thanks in Advance..
3 Suggested Answers
SOURCE:
SOURCE: Replacing 850XL
from wher we buy the cartridge of full transmatic DMP80(850-XL) at wat price.
Posted on Oct 02, 2008
SOURCE: sir i have a otc 850 xl printer but i have no
hi go to driverguide.com sing in and find the driver, download and install
Posted on Jul 31, 2010
I WANT TO SET PAPER 15'x12' . KINDLY HELP SIR
Press START - Printers and faxes - right click Tally Line Matrix T6050 Printer - select Printing Preferences - find menu Paper size, select paper with size 15"x12". If not found, select used define or customize - insert paper size (width and height) - OK.
Set paper size on Microsoft office word 2007 - select Page Layout - Margins - Custom Margins - select tab Paper - on Paper size, select Custom size - insert height and width paper (15"x12") - OK.
Hopefully help
Sep 23, 2011 | Tally Line Matrix T6050 Printer
How to add custome page size to tallygenicom 6306 printer with windows xp i have to use width 15in height 12 please rplay soon
Ok, I think the problem you are having is when printing from a version of Windows, basically the problem is the 6306 can only print 13.6 Inch Wide, it looks like you are trying to define a paper size 15 inches wide.
As the paper size defined is wider than the capability of the printer, you do not see this paper size within Windows.
The solution to the problem may be much easier than you might imagine as it is very unlikely you actually want to print 15 inches wide, you more than likely want a paper width of less than 13 inches but are including the sprocket holes and margins at the side of the paper.
Simply define a paper size the width of the printable area of the paper, so long as this is less than 13.6 inches you will then be able to select this within Windows.
Sep 21, 2011 | TallyGenicom 6306 Matrix Printer
I have created a custom paper size 14' * 4' but i am unable to select the same paper size to set the page setup.
The maximum paper width the 6306 can print on is 13.6 inches, you will not be able to select a custom size form larger than the printer is capable of handling.Simply set the for size to 13.6 inches or the maximum width you will be printing.
Aug 11, 2011 | TallyGenicom 6306 Matrix Printer
Hi, One of our client using epson lq-300+II dot matrix printer to print their invoices in custom defined paper (using crystal report). It was working fine when they were using windows xp. Now they...
Hello, Please, if you can change back to the former operating, is either the printer type is not compactable with the new windows(Windows7). But first you have to check the net to see if you can try upgrading the software of the printer. Please if you've done this let me know what happened next.
Mar 26, 2011 | Epson LQ 300+ Matrix Printer
Hello All, I am facing an Issue with Printer. My Paper size is 8.65 inch X 8.9 inch. If I take continuous prints than after printing first page, Printer start printing after some space.( I concluded that...
go to start -> settings -> printer an faxes - > click file - > server propertiess -> click on create a new form -> give new name 8.5x6 -> set width 8.50in and height 6.00in - >save and exit open crystal report -> file -> printer set up -> click properties > click advance - > select paper size into 8.5x6 and save ok finish
by iswarpaniyur@yahoo.com
Sep 04, 2010 | Epson LQ 300+ Matrix Printer
Tally 6212 - Landscape Documents Printed Vertically
You do indeed have problem-- the printer is doing what you are telling it to do changing the print from Portrait to Landscape on a dot matrix printer has the same effect as that on a Laser printer, it rotates the print by 90 degrees.
The correct solution of to define a custom size of paper which is the same size as the paper you are printing on.
If you are using Windows 2000, XP, 2003 etc you can create a Custom Size paper in the following way;
  • Ensure you are logged in with administrtor rights
  • Open the Printers Folder
  • Go to the FILE DROP DOWN MENU
  • Select SERVER PROPERTIES
  • Ensure the FORMS tab is selected
  • Tick the CREATE FORM button
  • Enter a NAME for the form
  • Enter the dimensions (be careful of the units you are using --- best results use inches)
  • Do NOT set margins printable areas etc
  • Click on the SAVE button
One you have created the custom size form you should be able to select this by name in the printer driver properties and the software package you are using.
Jul 28, 2009 | Tally Line Matrix T6050 Printer
TallyGenicom 2265+ not printing with custom paper size
There may be a number of causes for the problem you are seeing. There are a number of places which may hold the origin to the page length problem you are seeing, in order of precedence these are;
  1. The page size set in the software package printing the 6 x 4.25 cards
  2. The page size set the printer driver printing to the printer
  3. The page size set on the printer
I would recommend the follwoing;
  1. Set the form length on the printer to 6 inches (i am assuming this is the length of the card)
    The form length can be set through the menu and is normally set in lines (normaly the print size is set to 6 LPI) so the form length should be set to 33 lines
  2. Create a custom form size in SERVER PROPERTIES on the Windows XP machine to match the form size you are using.
    Ensure you select this form size in both PRINTER PROPERTIES and PRINTING PREFERENCES
  3. Try printing some Windows Test pages to see if these respect the page size selected withing the printer driver properties.
If the Windows Test Pages do not print correctly I would recommend checking how you are creating the CUSTOM SIZE form, perhaps create a new form and double check the form properties one it has been saved to confirm these are correct.
Check you are using the correct printer driver for the printer, you should be using the 2265+ printer driver. As a test you may wish to install the GENERIC TEXT printer driver or the EPSON LQ2250 driver, these will be included in the Windows Add Printers Wizard and should print OK to the 2265+.
If the Windows Test Page prints OK I think you would need to look at the software package printing to the printer. Ensure the correct page size is selected here also, perhaps try printing from another software package selecting your custom size form to see if these print correctly.
It is passable your software package is sending escape commands to the printer to call up the page size, I note you say Genicom printers printed ok from Win 98. The 2265+ may not have the same emulations as the Genicom printers.
You can print a menu print on both Genicom (if these are available) and 2265+ and compare the settings on these.
I do not believe the 2265+ has a Genicom emulation as standard, but you may be able to load an alternative version of firmware into the 2265+ which provides the Genicom emulation. If the data going to the printer contains Genicom Escape command to set form length this may resolve the issue.
You may need to contact your TallyGenicom support department for the firmware (I think it may be called 7265+ firmware)
If you are able to provide Hex Dumps of the data to the TallyGenicom support people they should be able to say what is going wrong with the form length setting.
May 07, 2009 | TallyGenicom 2265+ Matrix Printer
Do i can customize my paper size in MS Excel 2003
When you are in Excel, go to Print Preview, then Printer Properties. There should be a box that says "Custom Size." There you can input your paper size and name it so you can recall it anytime you want.
Dec 18, 2008 | Epson FX 1170 Matrix Printer
Paper size problem
hi there, your problem is in page setup. make a custom size and it will print inside your paper sheet. ty
Dec 24, 2007 | Epson LX-300 Matrix Printer
OTC EuroLine 4260 Matrix Printer Logo
41 people viewed this question
Top OTC Office Equipment & Supplies Experts
k24674
Marvin
Marvin
Are you an OTC Office Equipment and Supply Expert? Answer questions, earn points and help others
