Question about Hampton Bay 52 In. White Redington III¿ Ceiling Fan w/ Remote Control & Light Kit
Hamilton Bay Remote Control Ceiling Fan
My ceiling fan runs about 1/2 speed on high and medium and does not run at all on low. The remote LCD indicates the fan is operating in the opposite direction. The LCD indicates the fan is going forward and fan is going backward.
Can you be more specific?
Posted on Aug 29, 2008
Rempte light comes on but does not activate fan or light?? thanks
Posted on Apr 22, 2009
My hunter remote control ceiling fan doesn't go real fast. the highest speed is what a normal fan would do on medium. is there a fix?
if you have pull chain switches in addition to the remote control, your pull chain switch may be set to Medium, which would make the fan run on a maximum of medium speed.
May 16, 2010 | Hunter 52" Ceiling Fan With Light And...
I have a hampton bay ceiling fan which will only run on the fast speed. I have changed switches but still only the fast speed. I have touched each wire to the load wire to see if it was the swith but no...
Hello Brother,
Installation:
Hang your ceiling fan on the Quick Connect fan bracket and wire the ceiling fan according to the manufacturer's instructions. The three wires coming from your ceiling should match the three wires coming from your ceiling fan: black (positive or hot), white (neutral or negative) and green (ground wire).
Use the high, medium and low keys on the remote to adjust the Hampton Bay fan speed, then use the light key to dim the light and the off key to turn off the fan.
For REMOTE CONTROL FANS you cannot use with any variable speed or slide wall switches. The remote control function must be used with on & off switch outlets only.
Speed Controls Click here Capacitors Link
I hope This Helped you,Thanks for Contacting FixYa...
Apr 22, 2010 | Hampton Bay Heating & Cooling
I have a ceiling fan with remote, remote will not turn fan on high, how can i fix this
The fan probably has manual pullcord switches - one for the light and the other for fan on/off/speed. The fan control pullcord needs to be at maximum setting.
Switch the fan on using the remote. Then set it to high using remote.
Now use the pullcord switch (probably cycles through off, low, medium, high, off with each pull). Set it at its fastest speed, and leave it there.
You should now be able to select highest speed from the remote.
Happy to try to help more if that does not work.
Feb 25, 2010 | Hampton Bay 24750 Huntington III Ceiling...
HB ceiling fan is getting slower and slower bi the day
Solid-state controls change the level of power in the fan motor to control the speed of the fan. For instance, when you switch from medium to high on a solid-state fan, the speed control mechanism increases the power of the motor. Solid-state controls are generally equipped in fans with controls that have predetermined settings, such as low, medium and high.
The solid state device in or around the fan motor could be defective and in need of replacement.
https://www.hunker.com/12003281/how-does-a-ceiling-fan-speed-control-work
Dec 07, 2017 | Hampton Bay 52 In. White Redington...
My Hampton Bay Miramar 60 in ceiling fan, works good on the med setting low and high both go slower then Medium. I have remote control all the other function work okay.
Mine just died!!! Can't get the control in side, and they don't have them in stock at home depot anymore here. OK. All hampton bay fan have a lifetime warrenty... they will take mine back, paid $229, but will only get $106 because they had a close out!!!
Good Luck!! I know I loved my fan, going to miss it beauty
May 05, 2009 | Universal Remote Control Hampton Bay...
Hunter fan with remote control was 3 speed, now only 2 speed
It sounds like fan motor is okay. There are two motor windings -- one low speed, one medium speed. Low winding gives you low speed, medium winding gives you medium speed, both windings give you high speed -- so I would say if you get high speed, both windings are good.
The remote (the hand held transmitter) controls the speed by raising and lowering the frequency of the current which is 60 cycle coming to the fan ceiling box. If the fan speed -selector switch (usually a pull switch) is set to high, when the remote (transmitter) signals the receiver to change speeds, the frequency of the current is changed by the receiver (the receiver is usually in the fan housing).
Sounds like you'll need to replace the remote system -- these come in sets, both transmitter and receiver, and cost about $30. If you're not experienced with wiring fans, you should get an electrician to do the job.
Apr 21, 2009 | Hampton Bay 24002 Ceiling Fan
Speed
The Receiver for the remote is defective. Try calling the toll-free number listed on the top of the motor housing of the safety label.
Jun 26, 2008 | Hampton Bay 52 In. White Redington...
Hampton Bay 54 In. 5-Blade with remote control at wall.
1. Set the remote to run the fan on high.
2. Pull the fan speed chain until the fan reaches high speed.
3. All speeds should work normally now.
The remote is modulating the maximum speed as set by the pull chain.
Dec 29, 2007 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Ceiling fan does not reverse with remote
Just reporting that I called Hampton Bay about the remote not working to reverse the fan. I was told that I needed to have the fan running on low and then press reverse on the remote control. If that doesn't work, customer service told me to press reverse while running the fan on medium. (Some fans are set to reverse on low and others on medium.) Nowhere in the manual is this addressed. I had been pressing reverse with the fan turned off, which seemed to me a logical thing to do. Live and learn.
Aug 25, 2007 | Hampton Bay 24750 Huntington III Ceiling...
Hampton Bay Ceiling Fan At Slow Speed
I recently replaced my hampton bay fan for the same reason (slow at all speeds) and discovered scorched and melted capacitors and wiring inside the fan. My suggestion is to stop using fan and replace immediately.
Aug 10, 2007 | Hampton Bay 52 In. White Redington...
Hampton Bay 52 In. White Redington III¿ Ceiling Fan w/ Remote Control & Light Kit Logo
3,914 people viewed this question
Top Hampton Bay Dryers Experts
Craig Butler
Craig Butler
Steve Allison
Steve Allison
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
