After charging when i turn it on it has no power already
SOURCE: samsung sgh a437 cellular bluetooth connection
You must press pair code like 00000 or 12345 and do the same in car
SOURCE: samsung sgh p310 wont charge
check to make sure it is connected properly and whether the pins in the phone's charging slot are not broken, because I have a samsung SGH-D807 and I forced the charger in the slot and the pins got broken, it won't charge. I have to repair it.
so connect it properly and check to see if the pins are broken, if not, try another power socket to plug the charger in, not all sockets are compatible with a charger.
SOURCE: sgh p310 wont charge
Hi!
Please check your charging port if the pins are still OK. Please also try a new charger. Perhaps your charger is already defective.
Have fun!
*Your vote is highly appreciated. Thanks in advance!
SOURCE: samsung SGH-A437
Check the manual usually they are like 1111 1234 or 0000 by default. if that doesn't work try last 4 of phone number and this code *#8999*8378# - Service Menu should allow you to reset phone to default and fix the issue
SOURCE: reset phone lock on samsung a437
Just copy paste the url of the site:
http://www.metacafe.com/watch/711995/how_to_unlock_your_phone/
Regards:
VOTIT
Dont forget to rate;
