Question about AEG U7101-4 Electric Double Oven
AEG U7101-4 Top Oven tripping the fuse after a few minutes
Hi
The top oven of my U7101-4 is cutting out and tripping the main fuse after about 10 to 20 minutes use. It doesn't happen with the grill, only the oven
I'd appreciate a bit of advice on this, if its the element, how do I get to it and is there a part number.
If not the element, what could it be please?
  • AEG Master
  • 3,463 Answers
It is more than likely the oven element, as it gets
hotter the insulation in the element is breaking down and causing the trip to operate..
Remove the panel at the rear of the oven and you will see the element there, undo the screws and pull the element towards you, carefully, detach the 2 wires and remove the element.
Be careful not to lose the 2 wires behind the oven rear.
Replace with new element.
Cannot give you a part number, you will have to go to aeg web site.
Posted on Dec 12, 2008
The top oven of our AEG D5701-4 is slow to heat.
Hi it could be the element on the grill it maybe burning out, what slows the grill to get hot quicker. best to turn of the mains or by the main switch. and get a toorch to check around the element or use a continental reader check if it is receving 240volts
Mar 09, 2010 | AEG D5701-4 Electric Double Oven
Oven gets too hot AEG B3101-4
Hi I am Vortash This sound like the thermostat cut out switch and if it is glowing hot then you have a serious DANGEROUS fault
it means that it is not disconnecting as it should and has shorted ot .. please get it changed immdeatly as it may short to the oven body causing it to become live .. now that should mean that the house fuse should blow .. but on the slight chance it don't you would be electrocuted if you touched the oven please call a domestic service engineer now Regards Vortash
Apr 13, 2009 | AEG B3101-4 Electric Single Oven
Recently wired a double oven with isolator switch
Hi, there's definitely a electrical problem.
First, use the bottom oven only for about 15 minutes and check if it doesn't trip.
Second, use just the grill (top oven) for about 15 minutes and check if it doesn't trip.
The reason is sometimes grill elements are corroded and only trip after a few minutes.
Also, if both ovens work ok on their own, then it could be your fuse box not strong enough, or the isolator switch fuse be only 13amp. If your oven is more than 3Kw (check the label on the door for info) then you need a 30amp fuse to hold when both ovens are on.
Cheers
Feb 19, 2009 | Zanussi ZDF490 Electric Double Oven
Aeg b3101 oven / grill cutting out
Ther are a couple of possibilities that could be causing your problem.
A thing called the safety stat could be cutting the oven out, it is designed to cut off the oven in the case of overheating This is what brings on the cooling fan. Sometimes they cut out prematurly for example you may not have enough vetilation, check for restricted or blocked vents.
The stat itself could be faulty again causing the oven to cut out,and then as it cools down it resets itself and so on and so on.
The thing to do after you hve checked evrything else is toichange the stat.
It is usually located on the top of the outer oven compartment, it is about 1" or so long with a feed in and out of it
Plz rate my solution.
Thanks, and merry xmas.
Dec 20, 2008 | AEG B3101-4 Electric Single Oven
Top oven (and Grill) have stopped workingMy 3 Year old AEG Competence D2100-4 Double oven has malfunctioned.  Bottom (main oven) works fine but top oven and grill have ceased to function.  The fan will run...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Nov 12, 2008 | AEG D2100-4 Electric Double Oven
AEG Competence Double Fan Oven Fault
Sounds like oven element is faulty, disconnect it and try again, if it does not trip, then it is definately the element..
It is easy to replace.
Plz leave feedback.
Sep 22, 2008 | AEG B2100-4 Electric Single Oven
AEG double oven- fan assisted not heating up
you oven element has failed.
it is located at the back of most electric ovens sometimes at the top,,
the insulation of the element has failed and when you come to remove it you will see visually see the damage... its easy to replace as there are only wires attached to it and only a few screws to undue to get to it..
hope this helps cheers
the washdoctor
Aug 24, 2008 | AEG B2100-4 Electric Single Oven
Oven cuts out after ten minutes and comes back after cooling down.
thermal cut out fuse, costs about £30, my company fits them for £78 all in in essex
Nov 19, 2007 | AEG B3101-4 Electric Single Oven
We have the same problem with our oven, AEG B2190-1.It started on on Christmas day[worst day of year]gets up to temperature after 10-15 minutes cuts out everything switches off until the oven has cooled down, The oven is only 18 months old. We have been told that it is a thermostat problem.
Dec 10, 2006 | AEG B2100-4 Electric Single Oven
AEG U7101-4 Electric Double Oven Logo
518 people viewed this question
Top AEG Ovens Experts
ashburton
Sal De
Steve
Are you an AEG Oven Expert? Answer questions, earn points and help others
