Question about Lexmark JetPrinter Z22 Color InkJet
Printer stops jobs for no reason
I finally got the driver installed - thanks so much for the advice! - but now every time I try to print a document, the Print Center comes up and stops the job after about 10 seconds. There's no error message; it just says "Job(s) Stopped." (I'm on a Mac, OSX, version 10.4.8) please help! thanks :)
  • Vanessa Wiebe Mar 23, 2007
    thanks for the advice--I tried looking in Mac help, but it didn't say anything, and I also went to where my printer was listed, deleted it, and then reinstalled, and that didn't fix the problem either. any other ideas?
  • 193 Answers
Your mac should tell you what do to. But go to where your printer is listed, OR delete your printer, then re-install. go through the motions.
Posted on Mar 23, 2007
All print jobs stay in queue with epson all in one xp600 series
Hi Violet,
There might be a number of reasons due to which your documents get stuck in a printer queue. Overloading and driver issues are the major reason behind this. If you are simultaneously printing hundred of documents then sometimes your printer jobs gets stuck in the printer queue. Then if your Printer drivers are corrupted then also while printing the documents sometimes it might get stuck in the print queue.If You Still Need Assistance Then Follow US For On : Epson Printer Support
Feb 05, 2014 | Epson Stylus CX6600 All-In-One InkJet...
I need to restart my computer everytime i want to print
Sounds like you have print jobs stuck in the print queue. Try deleting all documents in the queue and resending print job. Some print drivers choak on PDF documents. Try updating the print driver by download it from the manufacturer.
Try deleting printer then re-installing printer and updating the print driver.
Sep 21, 2011 | HP LaserJet P3005 Printer
Hi please help? My HP all in one deskjet f380 only prints certain documents, It starts as if its going to print, moving back and forth and then just stops and nothing is printed. The print job dissapears...
Try if one of these solutions help you.
1. Shut down you printer, wait a few seconds, start it again and try to see if you document is printing.
2. Install the printer again on your computer. This time, if possible use an other USB port.
3. If you can print PDF, you can try http://www.freepdfconvert.com/ and print your document after you mad a PDF.
Jul 07, 2011 | Office Equipment & Supplies
Hello! I've got problem with printer HP P3015. I installed and shared it. This shared printer I've connected to another PC through network. From any PC in the network unfortunatelly print time tooks at...
Get the driver from www.hp.com
while you are there check the firmware version. And upgrade to latest firmware. Follow directions to the letter. Do the "easy firmware installation", it's the first one listed.
Dec 12, 2010 | HP Laserjet P3015X Printer
Mac computer sends job to printer, green light blinks, but no printing takes place.
A few possible reasons
Print Driver is corrupt
Replace the print Driver
Printer memory set on the computer for a larger size then what the printer has.
Print a configuration page on the printer. (Press and hold down the large button for 7 seconds no longer than 15seconds) When the light flashes release the button.
On the page you will see the Memory size. Make sure you computer is set to the proper avail printer memory.
Oct 03, 2008 | HP LaserJet 1300 Printer
Samsung ML-2510 will not print from MAC OS on Macbook
I had the same problem and spent some time trolling the Net. But....I found it.
Run installer from CD.
Tthen go to system preferences > print and fax
Delete the ml-2510 by clicking the minus square
Click the add square..
Select the ml-2510 again, and make sure that at the bottom of this window, under the "Print Using:" field, you again select the ml-2510.
Click add.
That's it! You're good to go!
Aug 05, 2008 | Samsung ML-2510 Laser Printer
Odd behavior when printing
FrostPoptart -
An interesting issue. I think the driver may be causing the printer to 'misread' print jobs. I think installing the most current version of your printer's driver should resolve the issue; Rather than use the driver CD, however, use Lexmark's Driver Finder to locate your printer and download the most recent driver:
http://support.lexmark.com/cgi-perl/selections.cgi?ccs=229:1:0:-1:0:0&target=http://downloads.lexmark.com/cgi-perl/downloads.cgi&lxkprod=x3470&req=:::-1::
I hope this helps!
-thinstatic
Jun 12, 2008 | Lexmark X3470 All-In-One InkJet Printer
Printing-Supercalc 5-Spreadsheet-, Sideways
just to check if the printer and the printer driver is working properly, try printing a 2 page document.
if it prints out correctly - check the applications documentation / user guide for printing instructions.
Dec 28, 2007 | Office Equipment & Supplies
I had the same problem and found the solution on the Apple discussion boards. Apparently, OSX 10.4 installs the printer as a Lexmark 510 series, not a Samsung ML-2510.
Just add a new printer and change the type from Lexmark 510 series to ML-2510 series.
Worked a charm for me!
See: http://discussions.apple.com/thread.jspa?messageID=5955598
Aug 12, 2007 | Samsung ML 2010 Laser Printer
My printer not responding
Ok, so you have tried a reset and no good. Try this again but this time unplug it too, all cords and cables. Replug, turn it on. Wait. Once reset again, check to see no print jobs queued and if so, cancel all print jobs by clicking on start, control panel, printers, icon of printer, scrol to properties, cancel print jobs. Try reprinting now.
Sep 28, 2006 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark JetPrinter Z22 Color InkJet Logo
146 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
