Question about Maytag Washing Machines
I asked for help recently regarding the mold building up in my Maytag washer. I have not received an answer let alone a response so I am requesting a refund of my $9.99. Deanna White deannak 734, password 6095b
    President:
  • 373 Answers
As far as the mold the only thing you can do is get the component replaced. or spend a few hours with a tooth brush and bleach . if you get it replace i strongly suggest that you take the light out and keep the door open thsi will prevent any more mold.
Posted on Dec 12, 2008
Maytag MZD2667HEB icemaker leaking water into icebucket forming an iceball
This is most ofen caused by the inlet water valve bypassing water when it is supposed to be shut off. Reach back to the rubber water fill tube and check for ice build up. If the tube is also frozen defrost it with a hand held hair dryer.
The failed inlet water valve can not be repaired. They are molded together and cannot be taken apart for repairs or cleaning. The inlet water valve is item 14 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5171422&diagram_id=28494089#d28494089
The internal water lines for this just push into the body.
I apologize for a late response. I answered another post and when I posted ny comments your post appeared so I answered it.
Thanks for choosing FixYa,
Kelly
Jun 16, 2011 | Maytag MZD2766GES Side by Side...
I have that moldy/mildew smell in my Neptune TL. I called about three years ago and they told me to run cascade through it. Now it is back and worse than ever and nothing seemed to help. My husband took...
yes there was a huge class action against maytag they are building rubbish we have machines here that are 4 months old and maytag wont cover there warrentys .. and they were the best washers you could ever buy till they were bought out by china. but they settled in 2004 but there are still many going on here is a link to get you strated.
good luck with it next time buy lg. how do we know there good? we have fixed 2487 washers this yr alone and only 4 of them were lg they are great machines.
http://www.consumeraffairs.com/news04/2005/maytag_lawsuit.html
Aug 03, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Mold
the best thing iv found to kill off mold is,,,"vinegar" white is best! but any will do,,mix up a good drop in a bucket and wash the mold off,,,it kills it stone dead,,, works on any thing you can wash with water too! wood,, walls,,,window's,,,doors,,,inside of boats,,,for your washer tip a bottol full of vinegar into the washer then do a warm wash with nothing in it,,(no washing powder!!!!) just plane water,,,also if when its not in use you could leave the door open thats good as well,,it needs a change of air going around it to stop this mold building up,,, your house may smell a little like a chip shop for a day or so,,but whats best,,,lung problems at a later date????and mold all over your house??? it spreds you know!!
Jun 27, 2010 | Maytag Neptune MAH5500B Front Load Washer
Smell of mold and mold on rubber in front loader
If you don't leave the door open when not in use and not wipe the door dry and the door gasket dry, mold will build up as there is no air to let the moisture escape into. Makes sense, manufactures do no not say this in their manuals, I think they should !
Mar 20, 2010 | Maytag Neptune MAH6500A Front Load Washer
Mold on the seal
on a 5500 you can scrub the seal with bleach and majic eraser. ths should remove it . it was caused by leaving door closed too long and not letting maching dry out . to prevent any front load from having this problem put a hand towel in the door opening . .
Nov 22, 2009 | Maytag Neptune MAH5500B Front Load Washer
I have a Maytag Neptune Stacked Washer and Dryer, the front load washer door has mold on the seal really bad. The repairman replaced it once saying it was a recall. He said to leave the door open, which we...
Hi, Some of the best information that I have found has been on YouTube. Go there, and type in "smelly washer" or "moldy washer". There are a number of good tutorials there.
Best regards, --W/D--
Aug 01, 2009 | Maytag MAH2400A Front Load Washer
How do I get rid of mold on the seal ?
Bleach and water solution will get rid of the mold but will not deter future buildup. To prevent future growth of mold leave door open to dry out. Mold likes to grow in damp dark places. Hope this helps
Jul 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
Moldy door ring Maytag Neptune Frontloader & poor cleaning
This is an extremely annoying problem and a very effective solution is baking soda! You should place around 200 grams of baking soda into the empty drum and then run a full cycle hot or boil wash.
This is a very effective method of reducing and preventing mold in a w/machine. I would recommend you run this "maintenance" wash once per month to prevent further build up of mold in the machine.
You can purchase a replacement door ring if the mold is extremely stubborn. However the Baking Soda also has the effect of neutralising any residue and odour that may be associated with it.
Hope this helps. Please remember to rate my answer. Thank You.
Jul 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
Black mold on washer door seal
this is a very common problem with the neptune washers.
use a javex and hot water solution and scrub the rubber boot.
you should also do an acid wash. (hot wash with bleach, and no clothes) if there is mold on the boot it is inside the washer as well.
There is a way to prevent this. when the washer is not in use, hang a small towl on the washer door, and do not close the door.
this will allow for air movement in the washer
May 27, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Ask me test request
Thanks for helping with the Ask Me questions I had. Posting this Ask Me test as a Toilet Hardware issue was great. LOL I'm responding now to get the request off my profile page, and to let you know I saw that you got screwed with a TFT from that response to the premium dryer problem you did recently. Your response was right on.
Oct 04, 2008 | Home
Washing Machines Logo
49 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
