Question about Panasonic DMR-ES10 DVD Recorder
Fault stops remote being used
Panasonic eur7720 kbo displays fault 'Remote DVD3' and will not allow remote to be used and hence recordings made. Is there a simple solution?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 112 Answers
Press ENTER and the number shown on the unit (1, 2 or 3 - in your case, then, 3) together on the remote control for at least two seconds to restore control.
Posted on Apr 24, 2009
When i use my remote for panasonic dmres30v dvd and vhs player it not working the screen shows mode 3 signal
You can try to reset the unit to factory defaults (you may require the user manual for this) or you can try to reprogram the remote to match the 'MODE3' or 'DVD3' display on the unit itself.
While the unit is on, point the remote at it, press and hold both the [3] button and [ENTER/OK] button - TOGETHER for 5 to 10 seconds, then release. Should work. Failing that, refer to the user manual for resetting the unit to factory defaults (if possible without the remote) - this manual should be available from the Panasonic website as a pdf. - free.
Try the above suggested step with the remote first. Hope this helps a tiny bit.
Jul 01, 2011 | Panasonic DMRES30V DVD Recorder/VCR Combo
Dvd recorder
The following should give you access to a service menu containing controls for macro-vision and region coding. You can change the regional settings from there.
1. Set your player to Standby
2. Press Title, Clear and Power
Jul 05, 2008 | Sony RDR-VX525 DVD Recorder/VCR
During my recent transfer to a new flat i lost my remote control for my panasonic dvd recorder type DMR EH67. I bought a universal remote control but i did not have the full functions of my lost one. In my...
You can try changing the command mode of the (genuine Panasonic) remote itself, press and hold [ ENTER/OK ] and the number [ 3 ] button together for 5 - 10 seconds, then release. Then try the remote with the unit. If it still shows DVD 3 on its display, no matter which button is pressed, reset the main unit to factory default as outlined in the user manual (assuming this model recorder has a tuner, there would be channel buttons on the front - try pressing and holding [ CH/UP ] and [ CH/DOWN ] together - for 5 - 10 seconds, until 'SETUP' appears, then release). This may or may not restore your DVD unit to the default (DVD 1) command mode. (Don't forget to reset the remote back to DVD 1 if you do reset the main unit - press and hold [ ENTER/OK ] + the number [ 1 ] button together as above).
Your new remote may be set to DVD 1 by default while your unit is DVD 3 = different remote command modes.
May 02, 2011 | Panasonic DMR-EH67EG DVD Recorder/HDD...
All I get is Remote DVD3 what ever button I press.
Try pressing button number 1 and enter on the r/control
Sep 04, 2009 | Panasonic DMR-ES10 DVD Recorder
Error message "remote dvd 3"
PRESS 3 AND ENTER ON YOUR REMOTE OR VICE VERSA
Aug 03, 2009 | Panasonic DMR-E50 DVD Recorder
Hello, I have a Panasonic DMR-EH65 DVD with HDD, when pressing any button on the remote control the display says DVD3, machine will not operate, took it apart to check for any bad connections, reassembled...
You could try Changing the Remote Control code for your DVD recorder. If you have more than one Panasonic device, there's an option to give each device its own Remote Control code. The Default is DVD1. So for FixMick, it sounds like someone may have changed the Remote Control code on your machine to DVD3. For Dador, someone may have changed the Code to DVD1. So you'll need to change the Code on either the device or the Remote to make them match up (see page 19 of the DMR-EH65 Users Manual ... you can download it from the Panasonic website)
Sorry FixMick. I don't know why your display isn't working.
Mar 15, 2009 | Panasonic DMR-EH65 DVD Recorder/HDD...
Panasonic DVD Recorder DMR EX95VEBS remote control only displays DVD3 how can I reset this to get back to proper functions?
Dear FixYa
Thank you for your support. I have solved the problem on my DVD Recorder by reading other peoples solutions to this problem. My DVD display was showing DVD3 and all buttons would not work. So on the handset I pressed the ENTER/OK button and no. 3 button together for a few seconds, this cleared DVD3. I was so pleased that this worked. croneruk, 6/10/2008
Oct 04, 2008 | Panasonic DMRES15 DVD Recorder
Panasonic remote
Hi David,
i,ll try my best.
The best suggestion i have is 1:) take the batterys out of the remote, and leave out for about 12 hours. this should reset to factory-default.
also power off the dvd player. unplug and then replug in and setup again.
Finally try changing the tv output selection. i,e scart/aux/av et,c.
hope this helps you out.
regards Mike @ compurepair.
Jun 11, 2008 | Panasonic DMR-EH55 DVD Recorder/HDD...
Unlocking region code panasonic dmr-ex77 dmr-ex87
I have a panasonic dvd recorder. Model dmr-ex87
I was going through the options for the remote control and i selected dvd 3..Well this has caused problems as the remote only displays dvd3 when you press any buttons on the remote. How can i get it back on dvd1??
Apr 16, 2008 | Televison & Video
Dvd recorder rdr-hxd860
press stop button then the power button together the player will go off. put it on again the remote should work.
Mar 15, 2008 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Panasonic DMR-ES10 DVD Recorder Logo
100 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
