Question about Siemens SL65
Phone cant be turned on
When i plug the charger the key pads light and go of, the screen cant came on, even when i try to turn it on using the power button.
  • Anonymous May 12, 2008
    mobile is not switching on
  • 74 Answers
It is problum from power switch replace it.
Posted on Mar 26, 2007
My phone will not charge
You probably tried taking the battery out and using an eraser, clean the terminals of the battery, replace do not power phone on, plug in charger and see what happens.
Aug 03, 2017 | Alcatel Lands Phones
Zte-warp n860 droid frozen on greendroid pic and indicator light shows that device is charging even if it isnt,when i plugged the phone back up to computer after it developed this problem the computer
Hi even i am using the same ZTE warp phone, even i was not able to receive calls are make calls , my phone was getting freezed, even i visited the ZTE warp boost store, they failed to fix the repair, they informed to to contact customer care, when i called customer care regading this information , they took my e-mail address and my information and they informed me that to upgarde the software, so the software link has benn sent to my mail, then later i upgarded my phone , my problem was solved, so i would suggest u to contact customer care
Mar 17, 2012 | ZTE Warp
The screen on my phone went completely black and will no longer turn on from what iv tried i cant hear or seen anything and there is no sighn of water damage what do i do?
I will try and keep this short. I have a Motorola Razr (puchased in the USA..... this will make sense later) and I lend it to my brother when he visits me from Canada. (Roaming charges for Canadians using their phone in the US is insane) He too has a Motarola phone that he brought with him. The Charger that he brought with him was for a Canadian phone. Apparently, you cannot use a charge for a Canadian phone, on a USA contracted phone..... I'm not sure why, but it is the case. He attempted to charge my USA phone with his Canadian Charger and the screen went blank. The phone was still on and could even receive calls. Even when the calls came in, the screen still remained blank. I won't bore you with any more details.
Here is how I fixed it:
- Unplug phone from Canadian Charger
- Take the battery out of the phone.
- Plug in USA built charger (without the battery in the phone)
- The phone attempt to charge
- Screen should turn on. Wait till screen indicates (Cannot charge battery)
- Plug battery in.
- Hold down power button to turn on the phone.
- Phone should be in working order.
I don't claim to be an expert. This may only apply to my particular situation. Hope it helps if you happen to use the incorrect charger. Take care.
Mar 22, 2011 | Motorola Mobility RAZR V3
I Cant turn on my Sony Ericsoon W995 i put it in the charger and it coming a red light i dont know what to do
The battery might be drained so wait a little longer before turning it on.
You can try though to plug the charger then try to turn on the phone.
The power button is located in the same location of the clear button.
You might need to press a bit harder and longer until you see the screen light up.
See picture below..
Mar 11, 2011 | Sony Ericsson Walkman® W995 Cell Phone
My razor will not turn on and will not charge. when I try to turn it on the lights on the key pad flicker and the screen is blank
Please chech your phone charger with any other compactible phone for its faults.may be the charger is not working properly & its is not able to charge your phone
Feb 25, 2010 | Motorola Mobility RAZR V3
HP DV928US When battery in or charger plugged in
fails battery out so leave it out they love to short.
so when it fails test 2 is, hit the F10 or ESC key promptee
went it fails to boot, check BIOS key first, if BIOS fails.
be more clear.
what does it do when it wont turn on.
BIOS dead. screen 100% dead, and not even text
BIOS works even with HDD and DVD drive pulled.
that is the acid test on PCs.
the screen must say, hit F10? or ESC to enter setup, means HP BIOS. it must or power is no good. get a new power pack
the shut down tell me lost power, that can be the power pack 19vdc
or the jack at the mobo if failing to said pack.
try side pressure on that jack if at anytime the power button fails.
it self shuts down, I got that but lets fix , cant boot first.
that is how to fix this.
power on failures, are you saying the power key fails. some times
and the fan does not run every time.?
Also,
this old LT uses CCFL back lamps.
that love to fail. so when it shut down did the fan die.
did the HDD stop spinning ear to bottom? if not the CCFL is failing.
using and external monitor proves this every time,
do the flash light trick?
http://www.pcdied.com/monitors.html#flashlighttest
Aug 29, 2017 | HP Pavilion dv6928us Notebook
I cant seem to turn on the phone, and its just a blank screen. i checked with the battery with another same phone and its battery is still full and it can be on. however, when i use the phone, i just cant...
ok so you are saying your battery is ok.Then it could be your charger or phone that is the problem.You are best going to a suppliers shop where you can try another charger.If battery and charger are ok then it must be the phone, and ask for a replacement.
Hope it helps!
Dec 22, 2009 | Computers & Internet
Motorola w375 wont turn on?!?
Most likely, what has happened is that the camera charger, even though it fits, puts out different voltage and amperage than the motorola charger. You've either (hopefully) just damaged the battery, or the phone itself has become damaged. I think Verizon, or Suncom also has phones with that same battery. I would recommend trying one before buying it. If it works, great... if not, you'll need to either have the phone professionally repaired, or replaced because it most likely fried the power relay circuitry in the phone. Unlikely that your problem is software though.
Aug 04, 2008 | Motorola Mobility W375 Cellular Phone
My MDA won't turn on even when its on the charger.
THE SCREEN AND LIGHTS HAVE BLOWN YOU NEED NEW PHONE
Apr 11, 2007 | T-Mobile MDA
My phone not turn on
Check the mobile using another battery then it works normaly this is the problem due to battery.Recharge old battery using external charger
Feb 23, 2007 | Motorola Mobility RAZR V3
Cell Phones Logo
291 people viewed this question
Top Siemens Cell Phones Experts
michael galang
Stormi  Paulk
Stormi Paulk
Colin Stickland
Colin Stickland
Are you a Siemens Cell Phone Expert? Answer questions, earn points and help others
