Question about Maytag 30" Built-In Single Electric Wall Oven - Black
Maytag wall oven MDL mew5527ddw makes a clicking noise like a relay continuously picking and dropping. If I open the door the noise stops. Very intermittent. Also temp is off by about 100 degrees.
None of the buttons work only clock
Posted on Dec 30, 2010
How can i tell if the hi limit thermostat in my maytag wall oven is bad
test with a multi meter on each end of the wire prong connector, place each end of ur meter prong on both 1 and 2 of the connectors, and test for continuity ohms or a close circuit. have ur meter on a low ohms setting as the level of ohms is low. if it shows an open circuit or no continuity, its defective. Infinity is the meter not showing anything like a number 1 and not moving?
Apr 26, 2015 | Maytag MEW6530DDW 30" Electric Single Wall...
Jenn-Air Maytag double wall oven makes loud buzzing noise
There is a cooling fan for upper and lower oven they run at the same time no matter which oven in use it is fed from the oven manager no way to trouble shoot without pulling oven out some models use same fan for both so you could have a blower on hand remove back panels to access fans take a lead off fan to determine which one noisey
Feb 03, 2015 | Jenn-Air Ovens
Constant beep beep beeb from Maytag
forum.appliancepartspros.com/oven...ranges-cooktops/5209-maytag-ove...
https://www.maytag.com/product-help
Jun 30, 2014 | Maytag 30" Built-In Single Electric Wall...
Wall oven bottom element not heating has been tested and is good, oven makes a clicking noise on and off
Clicking noise usually a relay in the control board for the heating.I would check there.
Feb 02, 2011 | Frigidaire Ovens
Cleaned bottom oven. Top oven door won't open
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Apr 11, 2010 | Maytag Appliances 27" Electric Double Wall...
Maytag double oven is locked and won't open
Hi. Has a fault code been displayed and a continuous beeps? press and hold the cancel & cook & hold buttons together for about 3seconds then door should open.
Hope this helps.
David
Sep 13, 2017 | Maytag MEW6630D Stainless Steel Electric...
The oven touch bottoms are starting to not work acouple at a time do you think the control panel is going or is it the control box be hind it . Model mew5527ddw maytag wall oven
it certainly sounds like it's just the touch pad/membraine that may be going and not the timer/control by your description. does the touch pad visually look worn, i.e.cracking, discolored etc. ? there is a method to check those membranes with an ohm meter and about half a dozen hands, ha ha. (just a side note, on the control where this component plugs in can become contaminated with dirt and grease as well as other debris, at times I've been able to successfully clean the "ribbon connector" with some alcohol and a pencil eraser). but I'd suggest you call a tech if it comes to that.
the panel itself should be part # 5765M482-60. that is again based on info you provided, specifically the model number. also it will likely be packaged indicating it is a "whirlpool" item, don't worry, maytag is now under the whirlpool juggernaut.
hope that helps,
good luck
Sep 28, 2009 | Maytag Ovens
Maytag wall oven overheating
have it cleaned
Jun 30, 2009 | Ovens
GE JKP45 double wall oven shuts off
This sounds like a loose connection (solder joint) on the main control board. I had one that had a similar problem. checked the price of a control board $350. I took the control panel off, took the board apart and found a loose connection on one of the relays. resoldered the bad connection. oven works fine now.
Nov 07, 2008 | GE JKP45 Electric Double Oven
Thermador SC302T clicking noise, locked door after power outage
iodine, open the upper oven, look thru the grill below the control panel on the right side and there is your model number. The issue here is that when the power came back on the oven run thru a test and your lower lock motor has failed. It will need to be replaced. Yes the only way to stop this is to shut off the breaker.
Feb 03, 2008 | Thermador SC302T Electric Double Oven
Maytag 30" Built-In Single Electric Wall Oven - Black Logo
242 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
