Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Refrigerater Light The light won't turn off when you close the door to the refrigerater
  • 86 Answers
Hi there check plastic angle bracket on bottom of door is not broken as it pushes the fan/light switch.Hope this helps
Posted on Dec 23, 2008
I have a Samsung double door refrigerater with bottom freezer.The freezer has developed a problem. I noticed there is a frost build up. What might be the possible cause?
Most frostless freezer build up due to door no close completely closed, leak seal, leave it open too long.
-Try this:
-Remove all the inside stuffs then unplug or turn it off, open all door for 4-6 hours then clean and dry and plug back in
it will last for a while.
Good luck
Mai
Apr 24, 2017 | Samsung Refrigerators
Refrigerater light not working on whirlpool gold
Turn power off, remove bulb and use a battery and piece of wire to check if it works OR use a circuit tester to check if there's any electrical resistance (if yes, bulb is shot and needs replacing) otherwise replace bulb and turn power back on.
Does the light normally come on when the door's opened? If it does then there's a switch that opening the door MUST operate. Find it, and with the door open, operate the switch. The light should turn on &off. Clean the switch - often fail with time and a buildup of gunge.
Mar 30, 2015 | Whirlpool Refrigerators
My refrigerater is still iceing up ,in the freezer part,causeing the refrigerater too be warm ,and i have already changed the heater and the thermostat.
if you have a full freezer and a not so full fridge a brand new one will do that but check your door seals as well
Apr 23, 2012 | Refrigerators
Refrigerater door won't close because lightswitch stays extended in on position. Door switch doesn't have food nor debris on it to prevent it from being pushed in when door tries to close.
I'd remove the light switch. IT should pop out of the side. You should unplug the refrigerator first, pry switch out. Tape up terminals. Push wires into hole where you can still reach them. Plug back in and be sure door closes. If all that works, buy a new switch and re-install
Jul 18, 2010 | Frigidaire Refrigerator Light Switch -...
Food (vegetables, fruits) on the refrigerater side freezing
Your model has a control damper inside the vent. The damper opens and closes with changes in temperature. It has a pig tail spiral thermostat on the side and if it goes bad the door sticks open or closed. Sometimes it is just frost but you will need to get to it. I will send photos and links in a moment, Thanks Sea Breeze
Jan 20, 2010 | Amana ARS266ZBS Side by Side Refrigerator
I have a ge gss22kgpacc side by side, the freezer is working, lights, etc. all working, but the refrigeratoe side is not working, any insight? thanks, mike
on most units they have two controls refrigerator control is electric t-stat that runs compressor freezer control think of it as a door colder freezer door is barely open warmer freezer door all the way open all cooling coils are in the freezer and a fan moves the air to refrigerater side possible problem fan not running
door freezer control all the way closed
light switch broken light staying on door gasket not sealing tight find door switch press verify light shuts off and fan starts
look for torn or damaged door gasket can look from outside with light and see if gasket contacts case on all four sides
freezer is cold enough so compressor is ok hope this helps good luck ron
Dec 12, 2009 | GE Refrigerators
Model gss20iepcbb freezer side works fine ...fridge
freezer is cold enough so compressor is ok hopr this helps good luck ron
Dec 10, 2009 | Refrigerators
Light on inside of refrigerater works sometimes. it just goes off sometimes for days then it will come back on
Sometimes light is used as a heater function in the appliance inorder to keep temperatures stable.
But it is also possible that your door switch is not functioning correctly.If you suffer from bad performance this can be the reason.
Jun 30, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
MY Maytag Wide by Side freezes in the produce drawers.
When a unit freezes in the lower drawers this is usually due to a thermistor which is not functioning properly. If you can provide your model number I can try to locate your schematic to your unit showing the thermistor that you would replace to alleviate this issue. I will await your reply as to the complete model number of your unit.
p.s if you had ice up the top of the unit as well then you would look at the damper door otherwise known as the diffuser door in some units or the control for the door as the problem area in your unit.
Thank you,
Rick
Jan 21, 2009 | Maytag 26 cu. ft. Wide-By-Side...
Hose from door dispensor hook to refrigerater
it should hook up to a water line with a coupling at the bottom of the freezer door. take the kickploate off and then look underneith the refrigeraqtor and there should be a clear plastic tube there3 to hook up to.
Aug 04, 2008 | Maytag MZD2669KE Side by Side Refrigerator
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
77 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
