Question about Mitsubishi WS-48613 48" Rear Projection Television
Mitsubishi ws-48613 no power
Purchased in 2003. worked fine the night before and tried to turn it on-no power, did reset came on for approx 15 minutes then turned back off on its own, will not turn back on, fuse looks ok
  • 10,594 Answers
It seems problem of weak capacitors in power supply and deflection board.
If you have little experience of TV repair and good soldering skills, then check above said boards for weak capacitors.
You also need to have service manual of WS48613 which can be obtained from Manual Zone.
Service manual has schematics and technical information of TV to help in repair.
Posted on Dec 12, 2008
TV keeps turning off & resetting every 15 minutes & up to 10 hours. When it is running the picture is PERFECT & BEAUTIFUL ! Can anyone tell me where to start after the DM Elec. caps ?
WHY DOES IT KEEP TURNING OFF - Fixya
www.asksbook.com/support/t24227796-keep_turning_off
Apr 24, 2014 - These, like most newer tvs have self-checks that shut the tv off if the fault could .... Mitsubishi WS-65511 65" Rear Projection Television Logo ...
[PDF]871D3547B10 (V21 OG) 52 through end.indd - Mitsubishi
https://www.mitsubishi-tv.com/asset/file/owners_guide/WS-55511.pdf
Projection Television Models ... WS-65511 WS-65611 WS-65711 WS-65712 ... which can be determined by turning the equipment off and on, the user is encouraged ...same stationary images on the screen for more than 15% of your total TV
Jan 19, 2016 | Mitsubishi WS-65511 65" Rear Projection...
My TV won't turn on - it was working fine when I turned it off and now it won't turn on...
have you checked the fuse at the back??...this just might be your problem. It is located on the power supply side of the motherboard.
Good luck and thanks for using Fixya.
G..
Jun 29, 2011 | Mitsubishi WS-48613 48" Rear Projection...
Ws48613- loses pix and sound(not power).
Thanks so much for getting back to me. Hope you enjoy the plasma.
May 22, 2009 | Mitsubishi WS-48613 48" Rear Projection...
My tv wont turn on??!!
there are six capacitors on the DM board 1000uF 16 v that go bad, repace them with 680uF 16 v. 105C. the capacitors are clustered together. on the DM board the DM board is the board that is enclosed in the metal box. the repair is not an easy one so have a tech help you. this is a known problem.
Jan 04, 2009 | Mitsubishi WS-48613 48" Rear Projection...
Mitsubishi WS-48613 made in 2003
have not solved it but wanted to reply. do not appreciate your original offer for informatiion and help when all it was an attempt to get one to sign up for and pay for your service. i will seek help from someplace that is not trying to scam me.
May 21, 2008 | Mitsubishi WS-48613 48" Rear Projection...
Mitsubishi WS-48613 No Video
If you have no video and audio then IC9c25 on Sig. Bd.
Jan 14, 2008 | Mitsubishi WS-48613 48" Rear Projection...
Mitsubishi WS-55859 projection tv
how many times does it blink does there seem to be a pattern?
try this:
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
Dec 18, 2007 | Mitsubishi WS-48613 48" Rear Projection...
Mitsubishi WS-48613
Did you try reset? Unplug AC cord for a while,plug in try again...
2) With paper clip, activate reset thru access hole on front of
TV ( consult owners manual) recheck.....................
3) Leave set unplugged from AC overnight.................T.
Please rate this solution........................
Nov 11, 2007 | Mitsubishi WS-48613 48" Rear Projection...
TV picture goes out and then comes back, TV eventually turns off
Probable bad DM module = repairable by qualified Mits.tech.....
Nov 13, 2006 | Mitsubishi WS-48613 48" Rear Projection...
Mitsubishi WS-48613 48" Rear Projection Television Logo
121 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
