Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
Furniture attatchment the brush on my furniture attatchment isnt rotating the water will come out and the suction works fine and the belt looks ok
  • 48 Answers
On the attacment there is a slide move slide either up or down for brush to rotate.
Posted on Nov 18, 2007
  • 1952 Nov 22, 2007
    on the turbo brush there is a sliding switch you move this to make the brush spin , you canot have the brush spinning and suction at the same time,
The turbo tool for pet hair on my Hoover power vac doesn't rotate. I removed the brush and cleaned but still doesn't work. Suction is fine without the tool attached.
Have you checked the drive belt on the pet head? Mine comes apart and a thin belt is driven by the propellers which in turn drive the brush head via the drive belt. To check turn propeller and see if brush head rotates if not belt missing broken / jammed
Oct 21, 2017 | Hoover Vacuums
Brushes don't rotate during floor cleaning
Check that no strings or other debris is clogging the brush wheels. If it isnt that check that the belt isnt broken connecting the brush to the motor. If that is ok, most likely the motor is blown and not turning the belt.
Sep 20, 2012 | Hoover F7425-900 SteamVac V2 Widepath...
I have the bissell pro heat turbo microban cleaner. It's about 2 1/2 years old and maybe used 8 times. The brushes do not work and it's not suctioning up the water. I've checked the belt on...
You already said it, so check the carbon brushes. Once it is no longer able to push the rotor or stator it need to be replace. Carbon brushes are customized at the machine shop, so you should bring it so that you have a sample of the brushes itself. Just be observant when disassembling the motor so that you put it back to exact place.
Thanks for asking.
Jul 13, 2011 | Bissell ProHeat Turbo Deep Cleaner Upright...
The brushes and the belt are not rotating. The power seems fine and there is suction. I have no other history on this problem since I was given this almost new unit over Thanksgiving. Where should I be...
If you've got suction, but the brushes and belt are not rotating, then either the belt has come off the motor shaft, or the belt is broken and just looks OK.
Remove the bottom cover off the floor head and check that the brush roller turns freely. If it does, then check the belt.
Let me know if you need additional repair information.
Dec 16, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
No suction with attatchments
if you have cleaned all the filters, there are two you need to wash and the hepa on the back may need to be changed, but the hose is probablly clogged. You can usually remove the hose ( twist it where the hose connects to the machine ) and use a broom stick to try and push the clog out.
Jan 12, 2009 | Bissell Lift-Off(R) Revolution(R) Turbo...
No suction
you still have a clog in there something is keeping the brushes from spinning. Be sure to remove any hair/string etc twisted around the brushes. Make sure the belt hasn't slipped off the metal pin behind the brushes, this is what creates the rotation. The brushes have a hard plastic molding on each end that fit into the sides of the vacuum. Make sure you have these on the right way or they will strip out and you have to replace the housing and the brushes. Have you cleared any blockages from the feed behind the brushes? Be sure to take the hose and extend it out and run a broom handle or something down it to be sure you do not have something lodged in there. Good luck .. if you need more detail post back. These can be rebuilt if needed, hopefully it is just something lodged further down the suction canal.
Nov 10, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
No suction
Are you saying that the motor runs but there is no brush rotation ?
If yes then firstly switch machine on then when you pull handle back as if to vacuum the carpet the clutch drive dial must turn to (drive, start, on,) position if it is stuck on (park, off. Stop, p,) position rotate it to drive etc as you pull handle back providing the clutch & both drive belts are ok the brush will spin.
The clutch drive dial knob is situated looking from the front of machine lower left hand side approx 50mm or 2” in diameter.
Please do this test & let me know results
Regards Chris..
Sep 28, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Brush and belt no longer rotating
you probablly need a new belt clutch it should go to a vac shop it isnt an easy fix
Sep 14, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Bissell not removing any water from carpet
there is a washer type of deal that goes between the water container and the vacuum. if it isnt there , ther is no suction.
my kids lost mine-------------
Aug 31, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
71 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
