Question about LG 50PC3D 50 in. Plasma Television
Tv not turning on with renote control
Can anyone please help me out.
I have a 50" LG model 50PC3D, every time I try to turn on my tv using the remote control it does not turn on, bu if I do it manually it does. I tried the remote control in my other 50" LG TV and it works. What could this be?
Thanks,
Luis
  • 1 more comment
  • psydoc Jan 03, 2009
    set works only manually, and not with remotes (for 2 yrs worked with the LG remote, and with Time Warner cable box remotes programmed to the LG). First stopped working, tried lots of fixes, and finally worked, but apparently a random fix. then went out again, and nothing works. suspect the IR system has gone out....
  • Anonymous Mar 09, 2009
    I replaced batteries and reprogrammed the remote that came with cable box. This worked for about a day. There appears to be something wrong with LG tv.
  • Anonymous Mar 17, 2009
    remote won't work with tv. its worked for over 2 years, know it doens't turn on tv. manually it works. It slowly went out. First, it would work, than for 2 hours it wouldn't, than it would work again. Now, it doesn't work at all.
    Problem Solver:
  • 5 Answers
Are you using cable card? unit has major issues when using card
Posted on Feb 19, 2010
Lg 50pc3d plasma
Procedure is
Step 1: Turn on the device (VCR, DVD, TV, Satellite receiver etc.) you wish to program.
Step 2: Press and hold the "CODE SEARCH" or "SETUP" button on the remote until the indicator light turns on, then release.
Step 3: Press and release the button for the device you are programming (VCR, DVD, TV etc.). For AUX, press AUX button, then the device button you are assigning to AUX. The indicator light will blink then remain lit.
Step 4: Enter the three-digit or four-digit code (depending on your GE remote model) for your device using the number buttons. After your code is entered the indicator light will turn off.
Step 5: Aim the remote at the device you want to control and press the POWER button. Your device should turn off. If your equipment does not respond to the first code listed in the documentation, repeat steps with the next code. If the device responds correctly to other functions like Volume or Program up/down, no further programming is required.
If you can't find a working code for your device or your brand is not listed try the "Code Search" method described below.
The CODE SEARCH function
Step 1: Turn on the equipment you wish to program.
Step 2: Press and hold "CODE SEARCH" or "SETUP" until the light turns on, then release.
Step 3: Press and release the button for the device you are programming (VCR, DVD, TV etc.). The indicator light will blink once, then remain lit. For AUX, press AUX then the device button you are assigning to AUX.
Step 4: Press and release the "POWER" button until your device turns off. Wait at least two seconds between each time you press "POWER". Note that you may have to press "POWER" up to 250 times!
Step 5: When your device turns off press the "ENTER" or "SAVE" button. The indicator light will turn off. Check other functions to see if your code is correct.
Jul 07, 2013 | Universal Remote Control Televison & Video
Hi there I have a lg 50pc3d plasma. It does not turn on. When I power it up it clicks and then clicks again and Turns off but the red light on and when i press TVinput or input and channel up/down from...
Power supply board is dead.That the board,where the power a/c plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Aug 10, 2010 | LG 50PC3D 50 in. Plasma Television
Problems with LG 50PC3D 50 in. Plasma Television
are u using cable card? this unit has major problems when using a cable card.
Sep 10, 2009 | LG 50PC3D 50 in. Plasma Television
I have a LG 50PC3D when I try to turn on the TV the green light
This is a common problem.i recomend using your warranty if it still applies.if not, try hooking it up to a playstation and play with it.
Sep 07, 2009 | LG 50PC3D 50 in. Plasma Television
LG TV renote not worknf on 4 new sets
If you have a cable box (otherwise known as a set-top-box) that you have to turn on when you turn the tv on, and you use to change your cable channels, the LG remote will not control it. The LG remote is strictly for the tuner built into the television, and is not capable of controlling the cable box.
You probably see "function not available" because you are viewing the picture on an external input of the tv (component, composite, etc). Your tv cannot tune stations in when it is set to an external input that you use to watch DVD's, cable boxes, games, and other devices. The tv is telling you that you can't change channels if it is on an input.
I hope this helps you...
Jan 20, 2009 | LG Televison & Video
LG Plama tv 50pc3d does not want to turn on.
Unplug power cord- safety first!
open backcover
check powersupply- top center right is p.s.
top left side of powersupply you'll see 5 capacitor 3300uF 10V.
see any pop up on top? replace it All with same rate or 16v is O.K.
do not use temperature rate 75c. Use 105C.
if you know how to solder. you could save $300 at least! Mahalo!
Dec 18, 2008 | LG 50PC3D 50 in. Plasma Television
Remote problems
Replace batteries of your LG remote.
Oct 11, 2008 | LG 50PC5DC 50 in. Plasma HDTV
LG Plasma TV 50PC3D
The TV should be under warranty. Send back. Sounds like the panel is faulty (half the value of the set).
Feb 06, 2007 | LG 50PX4DR 50 in. Plasma TV
LG 50PC3D 50 in. Plasma Television Logo
309 people viewed this question
Computer Repairing
Computer Repairing
