Question about Radio Shack (15-2147) Remote Control
Cannot get the menu button to do anything other than sleep timer
With my dadio shack remote 15-2147 the only thing on the menu button is slep timer i need to program channels
  • 4 Answers
SOURCE: trying to program my Radio Shack 15-2147 remote to my emerson tv
I need the Sony TV code for 3-in-one remote
Posted on Dec 14, 2008
  • 537 Answers
SOURCE: needing code for radio shack 15 2147 for a duraband tv
Check this link on OwnerIQ
http://tv.manualsonline.com/ex/thread/view/idThread/57583
You may have to register to get it
Posted on Mar 09, 2009
  • 50 Answers
SOURCE: radio shack 3 in 1 remote need to program a sanyo tv
Try this link: http://support.radioshack.com/support_video/44686.htm
If you don't have luck there, then try this one: http://support.radioshack.com/support_video/16726.htm
(Click on "Manufacturers' Codes")
You will find other stuff there too...like manuals etc.
Hope this helps!
P.S., If this answers your question, please use the "Fixya" rating system to rate me!!
(Otherwise, reply with your results and we'll see if we can help any further.)
Thanks!
Posted on Mar 17, 2009
SOURCE: remote control Radio Shack 15-2147 Toshiba HDTV DVD - HOW TO?
The code for a Radio Shack remote control for a Toshiba TV with a DVD built in is: 1945! It worked for me easily! Good luck.
Posted on Mar 22, 2009
SOURCE: Radio Shack 5 in 1 remote has no p button
NOTE: To program a TV/DVD, TV/VCR/DVD, or TV/
VCR Combo, use the TV key.
1. Turn on the device (for example, DVD player)
and, if needed, load media (for example, DVD).
2. On the remote, press a device key (that is, VCR/
DVD, CBL/SAT, or TV).
3. Press and hold P until the red LED blinks twice,
then release.
4. Enter the first four-digit code for your device.
The LED blinks once as each digit is entered. If
the code is correct, the LED blinks twice.
NOTE: If the LED does not blink twice, repeat steps 2
to 4 and try entering the code again.
5. Aim the remote at the device and press Power
(or Play, if it does not have a Power key). The
device should turn off. If it does not, repeat
steps 2 to 5, trying each code for your brand
until you find one that works. If you cannot find
a code that works, see “Searching for Your
Code”.
6. Repeat steps 1 to 5 for each device you want to
control. For future reference, write down each
working device code in a safe place.
Posted on Sep 12, 2009
CAN ANYONE HELP i'm having a problem keeping the timer from going off and shutting the whole tv off. My kp-46wt510 sony widescreen from 2003 is doing the same thing, picture is bowed in the middle and...
Most likely you have turned on the sleep function. 2nd button from the left on the top of the remote hand unit. Keep pressing until "sleep off" appears on-screen.
Or
Timer in user's menu is activated to turn off TV a specific time. Go to timer menu and adjust timer, then push cancel on the remote, this should reset timer to zero. Same with current time, adjust and select cancel, this should reset current time.
If you do not have the original remote, you are in trouble. Service tech will have remote.
easyab
Feb 23, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
SONY HDTV-LCD MODEL - KDF-42WE655 turns itself off. Lamp light indicator flashes red. Should I attempt to reset ? It is approx. 4 years old
I'd wager that somewhere in the menu settings, there is a "Sleep Timer". Check the menu for the sleep timer, which turns off the TV after a set length of time. Also, check your remote, there might be a "Sleep" button that would do the same thing, press it multiple times until it reads "Sleep: Off" or something similar.
Dec 19, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Can't set sleep timer on my mitsubishi cs-40505 tv. I do not have the original remote. How can I set the sleep timer?
U can't do it without the original remote.Go in the tv menu by the manual button control might could set the sleep timer.This is a extra option on most tvs.
Jun 07, 2010 | Mitsubishi CS-40505 TV
TV will not come on with remote or power button
The following instructions are for the Emerson EWC1303/1903 tv/vcr. That's the closest match I could find to the Spongebob Squarepants 13' TV
If it's actually in Sleep mode, do the following:
TO CANCEL THE SLEEP TIMER
Press the WAKE UP/SLEEP button on the remote
control until “SLEEP TIMER” appears.
To view the time left for sleep timer press the WAKE
UP/SLEEP button twice, then press the MENU button
on the remote control to exit the sleep timer setting
If unsuccessful, try unplugging the TV for 1/2 hour, then plug it in and try turning it back on either manually or with the remote. Either of these should solve your problem. Best of luck to you!
May 08, 2009 | Emerson SpongeBob SquarePants TV
Sleep Timer on remote does not work
First try to access the sleep timer menu from the controls on the TV to verify the TV is working.
If that works then the remote has the problem.
Now try this;
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
If this does not work, then you may need a new remote unit.
Mar 10, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Olevia TV Remote doesnt work Sleep Timer
The TV is in 'showroom mode'. To fix: Click: Menu --> Picture --> Mode --> Power up then select: Home. Then click menu until you exit the settings. You will now be able to use the sleep timer.
Mar 10, 2009 | Bose Cinemate Digital Home Theater System...
Can't set the sleep timer
I have the same problem. Does anyone have a fix?
Dec 23, 2008 | Panasonic TH-42PX50U 42 in. Plasma HDTV
Sleep Function???
In most cases you can set the sleep timer by accessing the menu. Or if it is a learning remote find a button you dont use and teach it the sleep button from your OEM remote.
Apr 15, 2008 | RCA RCR460 Remote Control
Timer on television
The user manual is available here:
Pioneer website - PDP5060HD
Setting of the sleep timer is on page 58, quote:
You can also use the menu to set the Sleep Timer.
1 Press HOME MENU.
2 Select “Sleep Timer”. ( / then ENTER)
3 Select the desired time. ( / then ENTER)
4 Press HOME MENU to exit the menu.
Nov 17, 2007 | Pioneer PDP-5060HD 50 in. Plasma...
Sleep
THe only way to use the sleep function is if your tv has a sleep function. If not then that button won't deep anything for you. Otherwise you should just be able to hit the sleep button.
Nov 06, 2007 | Radio Shack (15-2147) Remote Control
Radio Shack (15-2147) Remote Control Logo
27 people viewed this question
Top Radio Shack Televison & Video Experts
Computer Repairing
Computer Repairing
xxxxxx xxx
Are you a Radio Shack Televison and Video Expert? Answer questions, earn points and help others
